PDA
View Full Version : Classic Hondas
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. Pictures from the Old School Japanese car meet...
  2. 86 Accord LX Main Relay/Fuel Pump
  3. What do you think...
  4. 87 CIVIC ProJect NEed HElp
  5. 1982 Hondamatic motorcycle cm450a questions
  6. 87 civic sedan
  7. PICTURE OF A OLD CIVIC TOY CAR I HAVE THOUGHT U GUYS MAY LIKE
  8. Atlanta area Old School Japanese Car Meet...
  9. What are some easy bolt on engine upgrades for a 1983 honda civic?
  10. electric guru help
  11. parts car
  12. 84 Accord won't budge
  13. i need help with a elite honda 80
  14. 1978 civic V8 [video link inside]
  15. Help With My Accord
  16. 86 CRX HF..... WHAT IS THE BEST MOTOR TO PUT IN?
  17. Sealzall for carburetor gasket sealant?
  18. 1983 honda civic is ticking when accelerating and choking out at high rpms IMPORTANT
  19. d16z6 into a 1984 hb dx
  20. 1985 CRX 1.5L smokes once warm
  21. 1972 Honda AZ 600 on eBay. LOOKS AMAZING!!!!
  22. 1st gen prelude
  23. Finally, the search is over 1986 Prelude Si
  24. 85 CRX Si Fuel Pump HELP
  25. Japanese classic car show pictures
  26. a few questions
  27. Japanese Classic Car Show this Sunday in Irvine, CA. Who's coming?
  28. 1986 Honda CRX HF Problems
  29. Keihin carburetor throttle shaft diameter??
  30. Replaced Half shaft- now transmission kaput. HELP!
  31. Smogging an 84 Civic
  32. Jay Leno's 1964 Honda SM600 - video
  33. What constitutes a "Classic" Honda
  34. 88 crx short shifter fitment
  35. Does Honda Civic Spark Plug Holes Have Inserts?
  36. dohc Zc engine with the works...FOR SELL....check it out!!!
  37. on my 88 civic dx
  38. torque rod
  39. Couple engine related questions. 83 civic
  40. flywheel help
  41. Official Classic Honda's picture thread
  42. 1965 S600 Roadster with an F20C heart..
  43. 1984 civic cold start problem
  44. S 800 in France
  45. '86 Accord LX-i - DOHC VTEC
  46. Wanted: Front Struts for 1977 Civic CVCC
  47. My 83 Honda Civic. 56k beware ;)
  48. Starting problem.
  49. Honda S800 with added bite.
  50. 1983 Honda Civic 1.3 Blow-By? PCV? Help
  51. I never knew this forum existed
  52. 76' Celica 2K = S2000 motor swap in a old school Celica
  53. interchangable proportioning valves
  54. What is this and what does it do?
  55. Old School Japanese Car meet............Georgia...
  56. 86 CRX HF Skipping Problems and Running Rich
  57. 87 Legened
  58. japanese classic car show
  59. 86 crx b 16
  60. NOBBIE QUESTION : 1986 CRX SI
  61. Head question: 92 d15 head on to a 87 d15block will it work
  62. Transmission swap on 87 accord - DIY job or not?
  63. rough idle and cutting out
  64. 87 crx si problems!!
  65. First gen Bumper mod
  66. Noobie here! 1986 Accord troubles!
  67. Pic request and OPM question CRX differential
  68. 81 Civic- Needs Head Gasket Work
  69. Need Help wi 86 1.3 Civic carb tunimg
  70. crx Spyder restoration
  71. 85 crx si help!!
  72. Any accord cvcc owners out there?
  73. 1986 Honda Accord Surges
  74. fly wheel
  75. 1985 CRX 1.5 EW1 TDC - how do you know
  76. Accord-Hot weather-Intermitent rough idle and drive
  77. CAN SOMEONE HELP ME OUT ?
  78. 3rd gen spoiler
  79. '84 CRX alternator - what's interchangable?
  80. ***DOHCIVIC's 1977 Civic (CVCC)hatch***
  81. BEASTIE: My 1982 Honda Civic 1300
  82. My $500.00 1987 Accord.
  83. 15"-17" wheels??
  84. Quick question 3rd gen accord
  85. 1985 CRX New Project
  86. 85 CRX HF (5-speed) 1st gear knocking under load, 2nd, 3rd, 4th, 5th OK
  87. 87 Accord DX Front end swap.
  88. what other struts work with the Ground Control coilovers???
  89. timing and carb.air/fuel settings
  90. My 1987 RT4WD Honda Wagon...
  91. 87 Accord ECU question...
  92. 87 Accord Won't stay running when in nuetral or clutch is pushed in.
  93. 87 Accord Won't stay running when in nuetral or clutch is pushed in.
  94. Originality is the key(crx 1986 hf)
  95. Some pics of my 86 Accord Lxi
  96. 1987 Honda Accord Lx-i 5spd.... Need to know the location of the ECU please?!
  97. So this is where i'm at for lowering my wagon. Plz help
  98. D16A1 into 87 4wd Wagon
  99. 1972 Honda AZ600 Coupe
  100. 1st Gen CRX Mugen-style rear spoiler
  101. 87 Wagon COILOVERS help!
  102. Cannot locate replacement vacuum advance 1986 Civic
  103. Carb help needed!
  104. Old school Mugen stuff
  105. 87 prelude Si won't start after wire, rotor, dizzy cap change
  106. Idle Control and Vacuum Issues...
  107. timing off in my 1984 civic hatchabck dx
  108. 1986 crx si fuel hose leak
  109. Z600 what swaps can be done
  110. idling speed
  111. Accord with sunroof
  112. 1984 hatchback dx
  113. carb
  114. idling high??
  115. Old school Big Brembo for AC 88 !
  116. My S600
  117. 88 accord lxi no power
  118. Accord 1988++ Brembo 355x32 6 piston mono block caliper
  119. Just picked up a 86 crx hf and i need to know if i can put a d16z6 in it
  120. 87 Accord LX-i starting problems
  121. 1986 Accord headlamps won't retract, please help.
  122. Exchanging battery cables
  123. 1987 Honda Civic 5 speed transmission for sale
  124. 85 + 87 crx
  125. Removing turn signal and headlight switches
  126. Somewhat Honda Newbie
  127. Possible 1987 CRX purchase......
  128. 87 accord carb question
  129. Transmission fluid wicking up speedo cable (1985 Civic)
  130. Old School Japanese Car meet............Georgia...
  131. FS: 1976 Honda Civic CVCC Hatchback model
  132. 1987 legend electrical issue ????
  133. Selling 1987 honda civic 4 dr sedan.
  134. Need HELP ASAP!!! 1987 honda civic Troublez
  135. Ed Roth CVCC
  136. 1987 crx
  137. Looking at an 83 this evening...quick questions.
  138. 1987 Honda Crx Project help please.
  139. Low pressure fuel regulator... help?
  140. 1986 instrument panel lights
  141. 2nd head gasket
  142. 1979 honda accord issue
  143. Question about the 1st Gen Civic
  144. d15as
  145. i have a small problem!!
  146. 87 honda fuel pump
  147. Problem wih 1987 Civic
  148. Old School Japanese car show coming to SoCal
  149. Can anybody identify this car?
  150. 1987 A20A3 Motor and/or tranny into a '90 Accord?
  151. help with my 1986 honda crx si
  152. Carb Conversion for 86 Accord LX
  153. my totally stock 1986 honda civic crx
  154. What would you do? check it out...
  155. Will a motor from a 88 civic fit an 87 crx?
  156. 5th Gear Issues
  157. Ranchland Honda - 900,000 km CRX
  158. body kit help
  159. 1987 CRX HF carb to MPFI
  160. Has anyone done a cbr 900 swap into a CVCC
  161. 1984-1985 civic hatch spoiler. NEW
  162. NEEDED ECU**ECM??
  163. FS***CRX***Steet/Track Day/Auto-x***
  164. Compression Test Results
  165. blown head gasket
  166. 3 plug 87REX si computer needed BADLY!!!
  167. a few pre 80's hondas for sale in socali
  168. 85-88 crx parts
  169. Help with flooding carb on 88 crx dx please
  170. 87 civic SI idle problems
  171. where is 3geez???
  172. 99-00 Si seats in 87 Civic Si?
  173. 1970 n600
  174. 1987 honda civic battery drain? please help
  175. What crx wing is this?
  176. 82 prelude engine wiring and vacumn line diagram
  177. Ran out of gas in 83 accord, fuel pump hosed?
  178. 5spd transmission swap question
  179. Anyone need 87 CRX si PGM manifold with fuel rail and injectors?
  180. OEM brake upgrade for 87 CRX Si?
  181. d16z6 swap into carbed 87dx questions
  182. 85 civic 1500 no idle
  183. Pics from an old school Japanese car meet...
  184. OVERHEATING: '88 Accord LXi
  185. What is this wheel off of?
  186. rebuilding an 86' accord hatchback---new guy
  187. Blown head gasket? - 86 CRX HF
  188. 1985 Honda Civic DX carb'd to efi?
  189. WTB: Good/rebuilt EW1 engine for '86 CRX HF
  190. New to CRX's
  191. 85 civic hatch for 300 bucks
  192. 1987 Accord Carbed to EFI?
  193. is rpr down?
  194. Engine swapping
  195. *******Official RPR alternative thread*******
  196. 1979 accord
  197. 1983 Honda Civic DX 1500 Hatch - Lighting Problem
  198. Best CRX Springs 84-87
  199. need help lowering 87 accord
  200. rough idle when warm
  201. Our third CRX needs four windows replaced
  202. Saved a crx spyder from the scrappers today
  203. EW BLOCK W/ D16A1 HEAD
  204. 85 civic engine swaps
  205. 85 civic body
  206. where to find 1986 prelude performance parts?
  207. O2 SENSORS/'88 LXi Coupe
  208. 1987 crx motor swap.
  209. Help identifying transmission
  210. 87 CRX SI Idle Problem
  211. fuel pump wiring '83 1.5
  212. 1985 civic body kits
  213. 1987 crx fully adjustable front shocks
  214. How do you adjust idle on carb?
  215. accord deck latch broken
  216. Just Got an 85 Civic...Help?
  217. 86 civic si axle question
  218. 89 honda accord lxi
  219. trying to find out the owner of this car
  220. Some picts of the NOS mugen Variable Active suspension system...
  221. 84 honda accord car not running
  222. 79 accord distributor pickup coil resistance
  223. my first car 87 accord werid idle burn / leaks oil help?
  224. failed emissions inspection
  225. Front strut mount
  226. 87 accord idoling issue
  227. Hazard Lights Switch?
  228. 1981 1300 carburetor issue...
  229. '86 prelude si idles crazy!
  230. EGR Valve
  231. fuel filter location
  232. Why is my PGM-FI light on?
  233. what do you guys think of this car im getting?
  234. 87 SI Trans on its way out
  235. Old School Honda meet in Europe- Pictures!
  236. parts question
  237. Need advice on '87 Civic
  238. Seeing if anyone has done a B16A into the 84-87 4dr Civic's before?
  239. Oh, I hate being a newbie!
  240. horn 1989 accord not working
  241. Engine swap
  242. Recycle '85 Honda Civic near Seattle?
  243. Some new parts coming home soon
  244. newbee needs help
  245. A/C compressor Accord
  246. 88 honda accord lxi 4 door
  247. the new guy
  248. Got the CVCC done, with swap...
  249. 87 Honda accord Lxi hatch Troubleshoot
  250. Honda Young/oldtimertreffen Germany. Pics!
