Classic Hondas All Pre-1988 Hondas.
1986 Honda Accord stalls or won't restart.
Old 08-21-2013, 07:50 PM
Ragusano's Avatar
Default 1986 Honda Accord stalls or won't restart.
1986 Accord w/FI. The car will always start when cold. When excelorating from stoplight it sometimes stalls. Also, after driving and then turning off the car it will not restart until the car sits for awhile (up to 2 hours). The mechanic can not seem to replicate the problem at the shop. New coil, distributor, idle sensor, fuel pump relay.
Old 08-23-2013, 11:23 AM
2ndGenGuy's Avatar
Default Re: 1986 Honda Accord stalls or won't restart.
TW Sensor, I bet. You probably have the same thing I had happen to my 89. Check the two sensors on top of the thermostat housing. The wires broke off of both of those sensors on mine. Got new plugs at the wrecking yard and connected them up.
Do you have a check engine light? You should read for codes, it will confirm.
Old 08-27-2013, 07:47 PM
Legend_master's Avatar
Did you replace the fuel pump relay yourself? That is a very common problem, and used ones tend to also be bad.
Old 09-04-2013, 04:03 PM
Ragusano's Avatar
I had it put in at Firestone after I bought it myself..
Old 09-04-2013, 09:06 PM
How about the TW sensor as mentioned above?
nova1370
04-30-2012 07:07 AM
90Accord Man
01-16-2011 02:54 PM
lisam
04-09-2009 02:20 PM
streetskater4182
04-28-2008 08:25 AM
lord_old
06-01-2004 05:52 PM
Quick Reply: 1986 Honda Accord stalls or won't restart.
