Classic Hondas All Pre-1988 Hondas.
1987 Accord Lxi Motor Mounts
Old 12-04-2014, 10:41 PM
grassyfields's Avatar
Default 1987 Accord Lxi Motor Mounts
I am new to this site and have always just been able to swap the easier parts under the hood. (Starters, Alternators, Power Steering, etc) I picked up this car really cheap and decided to try the water pump. That meant a timing belt change as well which is a lot more than I had ever done before.
It turned out well so now I'm going after the motor mounts since the car has now developed a real bad vibration when stopped at a light with the car in gear.
I have the car jacked up and supported and have jacks under the AT and motor. I have the bottom cross piece off with AT mount. I am working on the front mount but am stuck on the last bolt that is buried next to the rubber mount. I can see the bolt but I'm not seeing a way to get to It. Do I have to take off the front subframe piece? That seems like a bit extreme? Also, the rear mount looks very difficult as well. Any tips from those that have done these before would be appreciated. Thanks!
Old 12-09-2014, 04:04 PM
89turboaccord's Avatar
Default Re: 1987 Accord Lxi Motor Mounts
2 bolts take the bracket off the block.
bromozee
11-15-2012 10:28 AM
laserspeeddemon
05-03-2007 10:55 PM
nk2k2
05-14-2006 11:58 AM
PHOBIA
02-23-2005 09:57 AM
BLUE EH3
10-27-2003 09:19 AM
Quick Reply: 1987 Accord Lxi Motor Mounts
