View Full Version : Acura Integra Type-R
- Engine Splash Guard (connected to front bumper)
- New clutch, possible issue?
- ITR Prices skyrocketing or what?
- Help me decide on Cams.
- B18CR Hard start
- Addition to the Family
- Bump Stops Are Springs Too
- Found the auction 97 type r
- OEM Driveshaft
- JDM B18C-R '96 ECM Terminal Arrangment
- Phoenix yellow type R
- Burning Oil
- 98+ Spec JDM Rotors/Calipers/Pads vs. 98+ Spec USDM Rotors/Calipers/Pads
- How to adjust 96 Spec JDM ITR Headlight Level
- Time for another 90K service on my R
- Type R 00-0187
- JDM titanium shift knob dimensions
- ITR #376 any idea of whereabouts
- Decat Power Gains
- 1997 type R Integra auction
- Outrun's Type R Expo 18 West picture thread
- Replaced new TPS sensor, still cannot adjust correct TPS voltage
- JDM 98/00 spec, side impact beams?
- Overheating issue???
- LOW REV PROBLEM HELP
- b16a2 intake manifold on rebuilt stock jdm itr motor
- Piston /valve contact
- can I program an aftermarket door key
- MPC from forks and rear MPC LCA
- Mugan intake rep
- Where do you guys source OEM parts?
- Totaled my type r today
- DC2 tie rods, difference between LHD and RHD?
- 2001 Acura Integra Type R - looking for factory paint
- ABS Issues.. Please help!!
- Spare wheel well wrinkles
- ITR Coil spring insulator/isolators?
- valeo 62202402
- I haven't started my itr in YEARS... what should I do before starting it?
- JDM ITR importing
- VTEC just kicked in yO
- Where do these rings go on the cylinder?
- ‘96 Spec DC2R B18C Issues
- In Search of 98-#1042
- 2018 Summer Tires for 98 spec JDM DC2 16" Rims
- TYPE R ARMREST BADGE REMOVAL?
- K-swap costs
- Alignment, is there something wrong?
- Type R shown in new RDX commercial
- Possible Relay Box?
- Nice History of Realtime Racing, ITR etc
- B18C5 Bearing Size
- 4x114.3 trailing arms
- CAR Mag Ranks Type R Models
- Audm dc2r rims value
- DC2 Type R leaking roof + spare tyre well *NON SUN-ROOF*
- Öhlins suspension dc2 type R
- JDM ITR rear swaybar issue
- Planning on rebuilding and have just a quick question
- honda integra type r dc5 ball joints
- 10 year Old toyo proxes r888
- DC Sports ITR Racecar
- Acura Integra Type R K swap
- NEED HELP- fresh ITR rebuild cel code 01 and Positive crankcase pressure?
- 98+ spec type R motor crazy idle
- DC2 Type-R Lug Nut Type?
- camshafts
- type Rat mobile
- Eibach Meet 2018
- OBD2 TUNING??
- Track Mat for DC2 Application
- Looking for car pricing advice.
- What does a brand new set of checkered ITR floor mats go for?
- jdm vs usdm ignition parts?
- The End of an Era
- Windscreen strength
- Type R Expo - West
- Comp test thread
- Itr 98-0563 build/restoration thread
- 16x7 +42 Volk TE37 Picture Request
- New wheels for the Type R
- JDM DC2 ITR Hood Rubber Weather Strip
- Cracked transmission case?
- What part number is this??
- Engine hesitating - help requested
- Power Steering leak what to use
- Cam shaft upgrade
- HELP removing JDM ITR Steering wheel from JDM steering column
- ITR hood dimensions? Need help!!!!!!!!!
- Type R Expo 18 -- Announcement
- 00-0016 Restoration Begins
- CW ITR at the junk yard in Japan NBD
- Who wants a 97 Type R
- 1998 ITR #33
- OEM Type R wing/spoiler from Japan
- 1999 INTEGRA Type R charging voltage
- OG roll call
- ECU TO GSR HARNESS PLS READ
- 4-1 Mugen ITR header Value??
- My Honda Integra Type R
- Road & Track February 2018 ITR Expo mentioned
- People shocked -> Someone Is Asking $35,000 for a 2000 Acura Integra Type R
- suspension bushings which set?
- STUMPED: CEL P1399 Pending: Have compression, fuel pressure, and spark
- What does "smog certificate ready" mean, for cars sold in CA?
- Cars For Sale and WTB: Integra TYPE-R's - 2018
- Parts For Sale and WTB 2018
- Donut Media Reviews the Integra
- JDM DC2 steering rack
- Considering "Big Brake" Upgrade - ASR x AP Racing -vs.- ICB / RCrew Racing
- 97-0202 Build
- From Austria to Canada - Yellow on yellow rehab
- Catastrophe!
- Spark plug cover nuts
- OEM Rear Lower Control Arms
- Mugen rear strut bar
- Type R Amber cigarette lighter and ash tray bulb "cap"
- 98 TypeR in local wrecking yard
- Uk Member - 98 Spec JDM DC2
- Denso alternator in ITR
- How much is your type R insured for?
- My R may need a clutch replacement
- 01-0406 Stolen on 8/18/17
- B18C5 blow by - PCV valve and oil catch can help
- Rear end links - wrong alignment?
- Hesitation/Bucking when accelerating
- GS-R black box different from ITR?
- Ouch !!!! Type r
- Type R Short Film
- Color of needles in Type R clusters
- 97-98 usdm shift boot
- Outrun's NSXpo 20/ITR Expo 17 picture thread
- Key Programming
- how much is this worth???
- JDM HID Drivers Headlight Installation
- Window Run Channel Replacement Guide
- Header clearance and performance for ITR?
- Gauges
- 00-0138 ITR rescue from Australia
- What chin spoiler is this?
- Question: Suspension bushings set, which one?
- What do you guys think of this ITR?
- PLEASE HELP! Need some help putting back my AC and PS.
- Integra type R owners in the central Florida area
- New R owner! New to the Honda game.
- Pre-Expo Northeast Type R Meet 2017
- Custom ITR plate , concept look
- Replacing ITR Rear LCA Bushings
- JDM B18C Type R
- Front suspension help
- Recent 1997 ITRs on BaT
- DC2 ITR Alternator
- Badge search for 97 itr 249
- 98-0408: State Farm supports texting while driving
- 98 cabin harness versus 00 cabin harness
- Does anyone have this photo?
- 2001 ITR Registry
- Looking for a trust worthy boosted Honda guru in OC Cali area
- How many bolts in the pressure plate?
- JDM Cat to USDM O2 sensor
- Survivor R restore 00-0512
- Did spoon/mugen ever make racing gloves?
- Parts For Sale and WTB 2017
- New CTR & ITR Photoshoot
- Where to buy parts?
- Type R video with old school Accord R and Civic R
- PistonHeads ITR Article
- 2000 USDM ITR Phoenix Yellow (New Owner)
- ITR vs GTR Solenoid Seals
- Remanufactured rack and pinion assembly?
- 15 inch wheel options for jdm dc2 type r
- Difference in Rear Trailing Arms - 97 - 98-01 ??
- Is this anybody here?
- Smaller size O2 sensor
- Jalopnik Integra Type R article
- Looking at my first R!
- Midwest Eibach Meet
- P73 vs P72 AC Mount
- 98+ jdm itr tranny 4.7
- Spoon header 4in2--Did they make a Spoon 2in1 section?
- Distributor for 1998 EUDM B18C6
- 00-0089 Armrest on Ebay
- 98 R DOWN AND OUT
- Rear liners + 01-0658 itr
- ITR w/ AC Kit, anybody have the .pdf instructions?
- SARD cat for Jdm exhaust
- What up y'all having issues with my acura Integra 96,
- Guy on ITRCA who had new gsr mats for sale
- Help me fig out why acura is lagging
- Assistance Needed: Clutch / Timing Belt diagnostic issue
- Parts For Sale and WTB: May/June 2017
- Was there a 1997 JDM Integra Type R?
- HELP! ITR motor was rebuilt, think they missed an oil galley plug
- 1997 ITR IACV Part Number?
- front wheel bearing hrv
- I finally finished my suspension overhaul...BUT
- 2000 PY ITR Clean Title JDM Front
- Door Ajar light/Alarm pass door keeps triggering
- My Cement grey 01 ITR build
- Reprogramming my transponder key
- B18C+ 9K rev limit= EaR Candy
- helpp newbie b18c1 questions
- Favor/request regarding a dash vin tag
- Parts For Sale and WTB: April 2017
- Off topic message to Dr. DC2 if you're even still here.
- New Member
- Best Intake for ITR
- More Honda Ferrari similarities
- Nurburgring Advice Please
- Not to badly price if any looking for one.
- Restoring 2000 ITR PY 00-0883
- Factory keyless for 2000 ITR
- 1997 type R morning ride wash and oil change
- Track tire size for TE 37 15x7 +43
- ITRCA down
- Spoon Caliper Clearance
- JRSC build recommendation
- Sticky Throttle?
- Ferrari F360 or DC2R/K20
- Not a bad type r deal
- '96 Spec JDM, For Sale in Japan
- 2000 nhbp integra build
- Antenna Conversion
- ITR Expo 2017 - Road America 09/06 - 09-07
- Varis DC2 wide body kit in the works... I think
- Is the OEM B-Pipe Resonator Stainless???
- OEM Door Hole Seal Glue?
- ITR/Spoon B Pipe and Spoon N1 flange bottleneck
- The Honda Trifecta
- Fair Price to ask for ITR Crank?
- My 98 Dc2 Rhd ITR
- Horror of horrors: milky residue on underside of oil cap
- Cars For Sale and WTB: Integra TYPE-R's - 2017
- Parts For Sale and WTB: Jan/Feb/March 2017
- 696 is out and 97 is in.
- Putting my R back to stock ride height...BUT
- Featured Garage --- ITR Surgery
- Dc2 b18c4 turbo
- 2001 PY #971 previous owners
- B16 (SI) VSS in TYPE R?
- Need your opinion on this issue
- New Type R Badge
- Testing Waters - 2000 PY ITR
- Loud Squeak When Turning Right
- Cars For Sale: Integra TYPE-R's - Dec 2016
- For Sale and WTB: Dec 2016
- 2001 dc5 jdm type r
- Bridgestone Rival-S 245/40/15
- Meanwhile in Japan
- Low Mileage ITR popped up for sale
