- Anybody still have the Integra Type R Vector Art?
- Anyone have the PDF for the A/C installation?
- Replacing Axles in a 1996 RHD Integra Type R
- Sensor Identification
- Are these the Horn wires/connector?
- Integra TypeR whining sound
- low idel!!
- My '97 ITR mild resto thread
- Finally Landed (video) ITR!
- Stock ITR Muffler + Aftermarket B Pipe
- Just picked up this DC2R!
- Injector Clip Retainer
- Does anybody make perfect replica ITR floormats?
- DC1/DC2 JDM CAT - Same or not?
- 1997 Honda Integra DB8 Type R
- Stock b18c6 duty cycle
- Motor rebuilt
- Can't decide which one...
- Draining Fuel
- ITR 01-0431 Modification Thread
- JDM B18c type r CEL/reading codes
- B18C5 Swap 1998 CRV
- Engine cutting out at WOT
- ITR Insurance Options?
- Body shop in Los Angeles
- Jdm hid problem
- JDM front head light area hood seals, does anyone make a repro?
- Can I use jdm P72 obd2a ecu on b18c2 5 speed manual
- Noises from the engine or gearbox when In High RPM
- Motor Mount Issue and NVH
- Abs sensor part numbers
- Daytooonaaaa.... 01-0910 is still kicking.
- RIP 00-501itrspec
- Need help with ITR automatic climate control unit
- 15x7 wheels that will clear the calipers
- Unknown camshafts
- Power loss after installing new cams
- Clutch Replacement and Light Flywheel
- Right Rear Trailing Arm Assembly
- Vtec engages late
- Are GSR and Type R distributor really the same?
- JDM B18C SWAP
- Help identify part please
- Grams 1000cc injectors ruined?
- Integra DC2R 15x6 Mags- Backspace and/or Offset?
- Dyno attached - how to improve mid range
- b18c crank but no start
- JDM Integra Type-R
- 1998 Type R #0781 Info
- Latest ITR Setup - In Car Audio
- K swap or sell the ITR??? what would you do?
- So this happened...help!
- Spoon Street Radiator
- Moroso 5.5 q header fit?
- Quest to find my old ITR.. help me H-T
- Help Needed!! Rough running
- 97 ITR Rough and High Idle After IACV Replacement
- 98 Evap purge solenoid
- Bilstein B8 w/ itr stock springs
- JDM Momo steering wheel - horn intermittent - DC2
- Need some Help please with ITR setup!!
- Center Cap Size
- Jackson Racing-supercharger b18c5 2001 Acura integra type r Dc2 help!!!
- Jdm Itr headlight o ring/gasket
- Getting another ITR - high mileage
- Decals and Ornaments for ITR 2001
- USDM Battery in JDM DC2 Integra Type R
- Acura/Honda Integra DC2 Typer B18C6 OEM Honda camshafts
- S2000 breaks on Integra 98-spec type-R (Japan)
- Does anyone in the north east have a Trans I could borrow?
- Ac pulley bracket bolt.
- Welded letter Y on jdm itr block
- Is it true itr and gsr abs the same?
- From the bottom build
- Long Term Transmission storage
- ITR Intake Ideas
- New JDM ITR owner advice
- 2000 ITR black - yes, all STOCK
- Water in the little hole under carpet (driver side) !!
- Shifter linkage removal help
- 2001 Acura Integra Type R
- Help with my build jdm 97spec b18c type r
- 1996 Integra Type R x
- 95 Honda Integra Type R-what parts can i replace front brakes with??
- Rebuilding tranny? and FD suggestion
- JDM ITR 98 spec fuel injector spec
- Help!!! Is it a blown head gasket ?
- Prices of the ITR - 2023 onwards
- Clifford alarm swap issues
- Head gasket blown !!
- Vtec not disengaging?
- REAR 5 Lug JDM ITR Hub/Bearing
- SRS Toda Replica 4-2-1, will it fit?
- USDM ITR 5 lug with Rotora Big Brake Kit.
- What is the value of an ITR race engine?
- Sergeant Racing Coilovers
- Distributor Information
- Integra type r 96 jdm 4 dr
- Type R Spoiler DownForce Speed
- Underbody repairs - looking for advice
- About db8 carbon roof
- Resurrecting the R
- Lost keys!
- Badge #
- I'm going to own a Type R again
- Oem jdm type r bpipe with spoon n1
- Type r rhd oem oil filter
- Catch can setup can work?
- 500hp Integra Type R Dyno Video
- WTF? JDM ITR crank markings for bearings
- Dc2 type r wiring harness
- JDM Integra Type R DB8 Import Thread
- Skipping brake fluid replacement after testing?
- 1997 JDM type r evap
- B18c type r oil leak
- 1998 Integra Type-R #328 on Bring A Trailer
- New owner!
- New Integra Type R
- Car wouldn't start, two white plastic bump stops in footwell, fixed but interesting.
- Steering wheel with airbag (SRS)
- Aftermarket rear lower tie bar type r?
- Sad news...OG ITR owner Austin has passed away.
- Power Steering Pump
- Strange squealing sound
- Camshaft identification
- Which is the correct 98 Integra Type-R factory Radio??
- Yet Another High Distinction for ITR
- OG Roll Call 2021
- Help needed! Is this a legit DC2 Type R?
- ECU internal relay malfunction possibility
- is this a typer or a gsr?
- JDM 1999 DC2 Integra Type R badging question
- Exhaust
- Honda integra type R 97 issue
- Owners who lost their ITRs due to theft or accident
- Jackhammer sound on idle.
- 98 JDM ITR LSD Tranmission Noise
- Aftermarket Manual Transmission Fluid JDM ITR LSD
- thinking of selling
- What passes for a JDM Type-R these days...
- Boot Brace & Tie Bar Color Code
- 98 JDM ITR LSD Differential Backlash Specs
- ITR Seat Material
- Rays Gramlight 57CR Wheels 15x8 15 x 8 +35mm ITR Fitment
- Mechanics near me
- B18C Type R engine production in Japan ( short clip )
- Third gear gridding after full rebuilt
- B18c6 engine loom the same as the b18c
- Discontinued P73 Fuel Pressure Regulator
- My JDM 96 Spec covid Lockdown build
- Has anyone ever done a jswap in a dc2 ?
- Itr 4.9 final drive
- Re: Oem sides and rear also oem carcover
- Motor mount reference numbers
- EDM ITR front badge
- For future reference: 2001 PY JH4DC23151S001786
- Wrecked yellow ITR
- ITR gauge overlay removal
- Front sway bar bushings
- Honda Integra type R dual gauge bezel
- The Integra Type-R radiator thread
- DIY Carbon Fiber Radio / Clock Cover Plates
- DC2 indicator self cancel
- Integra Type R Registry App
- Milano Red Honda Integra Type-R sticker question
- LCA trouble
- Weird overboost issue
- How much power will I get out of my ITR 01 model
- 15" or 16" wheel options
- ITR Differential Bearings Mimmatched w/LS Bearings?
- Type r
- new itr owner. questions about hondata setup
- Switching reclining handle on DC2 recaros
- Overheating help
- Anybody know the whereabouts of 01-0720 ?
- ITR REAR SHOCK BOLT PART NUMBER
- 1996 Integra Type R (From Japan) CEL 8 Issue
- 00-itrx consol badge restoration
- Refresh
- Anyone have the pn for an original key blank with transponder?
- Using E10 in a 96 spec JDM ITR
- My ITR CDM 97!
- long term fuel trim / short term fuel trim high
- codes p0172 and p0170
- Integra type r coffee table feedback.
- OEM aerial - diagnostics
- Why won't this right-side axle go all the way into the transmission.
- Energy Suspension shifter bushing: Does this gap look correct?
- Compability between Integra and Civic EJ/EG
- Saw this on the CNN news app
- What is a VersaFIT
- ITR Aftermarket Rear LCA
- Rear Windshield - Moulding Replacement
- is there a difference between JDM and USDM itr rear seats?
- Cunningham Reunited with RTR ITR 42 - Video
- Auto Painter in San Diego or LA area for Black 2001 ITR
- ITR Leads Off Another Acura Commercial
- Rear bumper vin sticker
- Part compatibility with ls/ gsr for ac and ps parts?
- 97 CDM ITR
- Thinking of picking up a 00, but needs work. Not sure if its worth the project
- New record setting R on BAT?
- turbo integra
- Thinking about selling the ITR - What to replace with?
- Canadian 97-98 serial bin tags
- Help pricing a 97 ITR
- Next Mod for my R????
- 10mm cam oil rails don't fully tighten, why?
- Importing a 1996 JDM ITR into CA (in 2021)
- ITR rear shock mount bolt
- Suggestions?
- USDM ITR Header same as 97 Spec JDM ITR Header?
- Acura RSX questions
- jdm 96specR abs??
- What springs are these? Seller claims they’re itr...
- Canadian itr same spring rates jdm 98 spec itr?
- Failed emissions test (high CO) and rough idle when engine is warm
- Authentic Mugen Gen 2 Wing
- JDM ITR Weather Strip
- Battery just died, should I go lithium? Thoughts?
- What's your suspension setup (street)
- Cluster not working.
- afr 22 en frio
- SPOON TYPE LSD
- What Horn Buttons Fit the DC2 Type R Steering Wheel?
- Need help asap cps lost signal code 9 ?
- Identifying authentic bare "B18C5" head, what to look out for?
- Type R sealed behind barn wall
- What brand/viscosity of Engine Oil to use on a JDM Spec ITR?
- Autocar Compares ITR and CTR
- OEM ITR Rear Spoiler - Fibreglass?
- GS Being Ebay as ITR
- Cold start idle problems
- Gap for piston rings
- JDM ITR Rear Spindle vs. USDM ITR Rear Spindle
- what is the diameter of the jdm itr headlight (HID)
- The Rusty Barnacle Restoration - 98-0111
- Dc2r non srs steering wheel
- New (old) ITR owner
- Interior loom removal help
- Motor1 Article
- Throttle Bodies
- ABS & Wheel Lift
- Great Integra Type R article: From boy racer to modern collectible (Petrolicious)
- 98 spec dc2r 16’s restored
- Header for B18cR
- Toda Spec B cams… thoughts?
- Metal Valve Stem replacement question
- HELP!!! Spoon Shift Linkage Bushings Kit Install
- which header of these two
