View Full Version : Acura Integra Type-R
- OT: GSR & TypeR keys mixed up?
- ATTN!!! All Autocrossers. Thoughts of my spring rates for GC/Koni
- Never post here but need some opinions for selling my ITR?
- Is any Toronto R meeting still going?
- Question about parts from Japan? What parts have the biggest mark up?
- short throw is hitting off my exhaust?
- Need help finding JDM part's?
- need advice on suspension for my R
- Good paint and dent shop in socal for ITR??
- Misc type R parts for sale
- What are the best rims/wheels?
- Camber adj, opinions please...
- VAFC question
- is it possible to restore my black ITR seats back to black
- Will stock brake system hold up ok at track?
- Does Anybody know were i can get these bulbs?
- camber on coilovers questions
- Oops - need torque for upper & lower engine mounts
- who in NC owns/owned this ITR... now wrecked?
- Tranny Problems or clutch?
- Driving in the rain...
- test pipes?
- wheel help type r
- rear wheel drive conversion?
- OT:About Relays
- valve lash specs please
- has anyone ran the new turbo neon's ??
- Which Tires??
- Tracked the car at summit point today!!
- Rear heat shield by axle, needed?
- spoon calipers w/ 15x7 advan rg's
- The gory details... inside the demise of #55 (56k good luck)
- IntegraR from the far West
- License Plate Bumper Bracket.
- ot: so-cal py owners w/ extra py paint
- Smoke coming from exhaust
- Where in the HE11 did all this come from?
- Removing Stubborn Header Burn Marks
- Need rubber seal for JDM hood
- J's intake noise!
- Story of my life (1998 - present)
- Exhaust Sound Clip
- Which Head Bolt For b18c5 Head On To JDM b18c Block?
- Adjustable Rear Sway Bar for R?
- NGK or DENSO
- My radio when racing
- Cold Air Intake or Short Ram ? Which works best on the R?
- HELP! Integra Factory Body Kit
- Pics of My R with the sunroof (Updated)....
- just purchased hondata, del sol seats, and hopefully RC 310's
- socal: san pedro photoshoot (lota pix)
- Looking for JDM Integra radio block off plate.
- Anybody ever heard of/ seen a "thingy" that plugs into your cabin fuse box to get 12v from?
- ?? How do u get the pins out of an OBD 2b connector??
- quick ?: Looking to buy a leak down tester...is this the right one guys?
- Pics of My R (Yes its got a sunroof)....
- Type R or GSR
- jdm itr front end owners: city light replacement.
- Finally went around!! (not a good thing)
- where to purchase extended O2 sensor??
- rota slipstream durability?
- New pics and some tech
- new wheel search: 15x7 options for under $275/wheel
- Question about EBC brake rotors
- NE1 going 2 Bristol Tenn.?
- What do u use to clean JDM seats with?
- What is the diff. between the LS injectors and type r injectors??
- Please help me in identification of this noise (i searched)
- I need an 01 Black passenger side fender....
- Brief question about header
- will S2000 wheels fit a ITR
- evap purge solenoid local?
- Toronto ITR Repair Shop Recommendations?
- J's Racing CF Intake
- how much to replace a set of ITR rims
- need asap help - JIC Suspension install
- Question for JDM Conversion Guys.
- Toda Sports Injection Kit Users
- CA Street legal Horsepower?
- ok just blew my motor again... can an s2000 motor be transplanted???
- shifter rattling
- bad idle problems
- FS: TB, injectors,pistons,etc
- Volk Racing - Gram Lights
- Anyone here live in Nort West Florida
- ISO Falken Azenis in NC
- question about type R 3rd gear
- pics of ITR
- General Fuel Pressure question
- quick ? - where is the fuse for fuel injection? doing a comp test
- Yes, another VAFC question......
- Rear Trailing Arm Problem
- I got my st corsa cam gears!!! They rock! THANKS TWEAKMEISTER!
- how to identify a real type-r head ?
- 3 dyno 3 different shop NO GAIN
- ...is this '97 dead?
- Top this...my second type R STOLEN tonight!
- Whats the median [header topic]
- legend rotors redrilled to 4-100 PCD?
- BAR-Honda cars seized in France!
- understeering question
- would flat-top pistons be counter-productive in an allmotor build?
- Happy 4th of July!
- Does this VAFC hack work on NA motors?
- 2 ltr. 220+ Hp crate engine from MR. Gasket
- NSX Rotors and Calipers install help & tips plz!!
- Problems with the JRSC on my Type R
- Jun 2.0 stroker kit.... what is the R/S raito spec?
- Type R qiiiiiiiiii sound
- A letter to you from Mugen........
- OT: Stock ITR cat FS if anyone needs it
- Exhaust Piping - Stainless vs. Aluminum..
- 1998 turbo charged type R should i buy it??? help info inside!!!!
- ITB's
- CW and PY sightings on 91 Fwy So Cal
- Jun 4 onwners - Chime in! Where are the dyno results that you guys promised
- jun 3 +NITROUS!
- do all the type r heads...
- Best place to order stock honda parts by internet?
- IAT sensor on ITR manifolds. Where is it located and any pics?
- Passenger Axle Removal: need any special tools?
- tranny or driveshaft problem??
- Kenji's P28 Throwing CELs
- check it out
- Good shocks/springs for new ITR's??
- Low Temperature T-Stat and T-switch Questions???
- OT: Off to Germany
- Need help with injector choice for modded B18C5 motor
- Faulty injector? Possibly from bad gas? Please help.
- 2000 ITR STOLEN
- Need to borrow/rent Power FC Commander Unit in Houston
- itr car cover.
- Expo3 - lap times at BeaveRun?
- hyerfest
- the one thing that crapped out on me that i would have never thought would....
- FYI: CTR cam and Skunk2 Stage2 cam PROIFILE & PICS
- Stock height of a TypeR?
- any consequences in setting vtec point lower?
- updated new pics of ITR1244
- Shift knob???
- May need new head gasket, any suggestions...
- were you an expo sponsor? - sparco distributor/retailer click here
- carsound died. which cat now?
- Check engine light when cold.
- where to smog in the south bay, ca
- Mugen - What a Bunch of Cheats and Liars
- Problem with brakes after bleeding
- picked up a new header/exhaust
- need help with wheels.....
- Which in-car camera mount is better?
- Overboost.com did a piece on the Type-R meet at Kiwi's
- Toronto R Crew - DarkNights Show
- Stupid fuel filter question.
- type r meet on overboost.com
- Low idle when AC is on.
- Anyone have APEXi Pro Series Damper?
- Replacement Antenna Mast
- Thermostat Specs
- True or False? New ITR heads from acura not P&P?
- Injectors mapped?
- Have you guys seen this type r ad?
- NSX calipers behind Stock Euro ITR wheels.
- Going to the drag strip tomorrow, tire pressure question.
- JDM Booshit
- tein SS pillow ball mount
- front fender removal help
- is there any trick ways to pass the sniffer test?
- JDM Type R radiator?
- FS My R What do u guys think
- Helper springs
- shifted at 8K and bent valves??
- I need your .02 cents...
- Want to change my suspension setup...
- dyno results
- OBD I and OBD II
- Quick question about itr cat. converter
- what is part number 14111-P73-J00??
- The ITR at Lowes for the 'summer shootout' series.
- I need help from the typer guys.
- Wheel bearing replacment problem....
- My Gingerman Video from this Spring...
- Integra Type R Exhaust Diameter
- Is this a 2.5" collector'd A'pex GT?
- OT: 3rd generation iPod installed in the ITR
- What the hell is this nintendo cartridge slot doing in my car?
- The Great Header Test Question -- Comptech Header
- jdm itr features?
- Those of you with JUN 3s, where do you have VTEC engage?
- OT : Is it safe to leave the R in a PARKING GARAGE for a few hours in Philly?
- Mugen in court trouble?!?
- motor swap
- Quick question on Clutches: B16 and B18C5 bolt pattern difference
- DIY camber measurement tool?
- Field's VTEC controller compared to Apex'i VAFC...
- How to fix bad gas problem?
- Something is seriously WRONG with my dyno plot, can you guess what?
- JDM ITR rear glass
- Anyone heard of a JDM ITR 4-2-1 header?
- OT: Nascar $65.00 Pepsi 400 Tickets worth it?
- Paintless Dent removal meet for so cal, who's interested.
- Back from the dyno... (PICS - Spa Francorchamps F1 Track)
- Where to buy the radiator hose conector with a water temp bung in it?
- Too Much Oil
- Will other floor mats fit Dc2?
- Serial numbers on a 00 ITR...
- Acura CD Player and Integra
- cam gears/ ignition timing
- Semi OT: Who all signed up or is signing up for the Pittsburg Thunder event?
- The end of an era....
- Hoods - Please Help
- off to japan where to go
- ONE MORE TIME!
- Upgrade Bushings? Tools needed?
- 91-93 NSX brakes on 96 ITR
- What Street Silencer i sould buy (apexi, greddy....)
- How to clean Comptech Air Filter?
- OT: That's not a torque damper, this is a torque damper.
- clutch/flywheel/final drive suggestions?
- spoon caliper clearance
- Clutch/flywheel/final drive suggestions
- Car shipping companies?
- Selling JDM Rear Strut bar and a few other parts . . . R guys get first dibs
- got into an accident...need advice
- Who's got J's Intake here?
- daily driver
- Getting the most out of a B18c5 without removing the heads
- ITR with H&R springs
- Urgent Help Removing ABS
- what are you guys lashing your valves to ?
- what spark plugs are you guys running ?
- valve adjustment noobs: ask me
- Help, JDM hand brake cover owners...
- Head gasket and compression numbers
- Car bogs under acceleration!?
- Stock ecu - '98 vs '00
- 01 ITR engine 4Sale and other Parts
- Damage to tires while mounting?
- Stainless Steel Brake Lines
- Wrecked Type R - What to do?
- Cheap Replacement rotors?
- how to detect a true itr catback
- Re: Is there a way to amplify the whistle created by the AEM CAI?
- H&R Sport Springs / Azenis 205.50.15 (Rubbing?) [Searched!]
- Question: How to remove rear seats
- email of Apexi USA?
- Field SFC Tach Question
- ITR axles vs others
- Largest tire question.
- lht mc brace: pictures please!
- Saw 2 PY ITR's with W. VA tags on I-81 south Sunday evening
