PDA
View Full Version : Acura Integra Type-R
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335
  1. Oil pan nightmares...
  2. Type R Cams?
  3. Drop in camshaft upgrade
  4. What would stop you from buying an ITR?
  5. 01-1789
  6. S2k push start button question...
  7. JDM 96' Spec JDM - Options & Accesories
  8. oem jdm itr lip on 94-97 front
  9. Austin Getty (username: austin) – Middletown fire victim & support information
  10. Fact or fiction:does a new header really glow red on 1st use?
  11. 16x7 +42 on DC2R ?
  12. Water Pump
  13. Going back to Stock..
  14. Cars For Sale: Integra TYPE-R's - Sept/Oct 2015
  15. For Sale and WTB: Sept/Oct 2015
  16. Going back to stock ride height
  17. Are Type R's Overrated?
  18. Another R gone !
  19. HELP! Transmission issue and suggestions!
  20. 1996 JDM B18C Oxygen Sensor (Which one to use??) *Pics
  21. I NEED input real bad. what to do with my R's
  22. How much oil usage is normal when tracking ITR?
  23. JDM ITR Clutch Master Cylinder
  24. 98 LS with 96 spec ITR swap idle surge.
  25. Resonated test pipe for JDM length exhaust but USDM header collector?
  26. WEBSITE TO BUY OEM PARTS
  27. Hatch plastic clips
  28. swapped cam gears, marks out?
  29. How long should my ITR motor last.
  30. Advice Needed: Wiring harnesses (alarm, starter, etc.)
  31. new version vs old version Spoon coilovers
  32. car wont start
  33. Integra Turbo 700 hp tuned by Spyros Floratos B16a workshop
  34. JDM ITR radio
  35. Differences of different market DC2 Integras
  36. 98-0290 Raped + Recovered
  37. Jdm dc2 type r steering wheel
  38. non abs brake booster differ from abs?!
  39. Radiator Fan
  40. ITR Shell Value
  41. b18c5 spark plug ngk??
  42. For Sale and WTB: Jul/Aug 2015
  43. Cars For Sale: Integra TYPE-R's - Jul/Aug 2015
  44. A little untold story about IPS Racing & the Spoon DC2R at ITR Expo 3
  45. O2 Sensor Too Short for Test Pipe?
  46. CT Engineering Icebox question
  47. 99 itr OBD2A or OBD2B?
  48. Toronto/Vaughan ITR meetup - Tuesday
  49. I Need Some Advice
  50. B18c intake manifold
  51. How much does a DC2 Type R Ti shift knob weigh?
  52. Started my 60K service this morning
  53. tranny VIN plate question
  54. 2001 Integra Type-R Alternator, OEM or aftermarket?
  55. Reality check on tracking a stock ITR - need experienced advice
  56. identify this carbon fiber b series intake
  57. Integra type r rack and pinion bellows OEM part #?
  58. Auto Cross Alignment
  59. 2015 Civic Type R review!!
  60. EK9 ?
  61. JDM 4-1 Header - Best solution to keep a cat?
  62. Finally awaken after a long sleep
  63. 60K service time
  64. Recommendations for positive battery terminal
  65. Beware of '01 PY ITR in Eugene, OR!
  66. Rhd kseries integra for trade
  67. Takata Airbag Recall
  68. SOS UK Spec ITR Error Code Help Help
  69. Replacement Center Console Help
  70. JDM DC2 steering wheel cleaning recommendations
  71. Airbag bolts on a JDM DC2 steering wheel
  72. Track down a Integra Type R
  73. beat, get in here.
  74. Best gear ratios for 4.785 FD?
  75. Integra Type-R Fuse box
  76. Ohlins suspension
  77. what would you pay for ITR shell?
  78. "DOT-Compliant" JDM headlights
  79. Need advice on buying an integra type r
  80. b18c misses
  81. 13s CR NA build?
  82. Raging over code P0135 --- Need halp!
  83. Please Help!!!
  84. #00-1491
  85. For Sale and WTB: May/Jun 2015
  86. Cars For Sale: Integra TYPE-R's - May/Jun 2015
  87. Help to identify
  88. Socal ITR meet 2015 anyone?
  89. The future of the Type-R
  90. Bogging issue
  91. indentifing a B18C5 block
  92. my 97 type r
  93. Spun rod bearing. new crank or?
  94. a/c question
  95. what cat back and piping should I use with a jdm header
  96. key fob question
  97. Mikey's 98 ITR #0413
  98. ITR spare
  99. Are type r clones part of the "club" discussion?
  100. Distributor integra type r
  101. Going boost question?
  102. low fuel light question.
  103. Hardrace bushings
  104. 96 JDM ITR Suspension
  105. Saturday afternoon project...Inner fender well respray
  106. LMA's
  107. Valve seals or rings?
  108. Pacific Northwest ITR Meet
  109. rsx/ep3 calipers on my usdm itr 5 lug conversion
  110. rear hub Bearing Question
  111. RE11A
  112. Touch up paint for NHBP ITR
  113. Civic Type R to US
  114. #CoolStoryBro
  115. Advice for tires to jdm oem 16'' rims
  116. vtec not engaging
  117. Exhaust diameter
  118. JDM ECU question
  119. b16pr3 Intake Manifold vs p30
  120. 15 5x114.3 lightweight wheels?
  121. Koni Yellows and Stock Springs - use OE dust covers?
  122. Ground control
  123. Guess who turned 60 yesterday?
  124. TYPE R License plate OEM... where to obtain ?
  125. silver-gs-R's Resurrection of CDM #00-0177
  126. Eibach 2015
  127. Type - R Final Drive Question
  128. The Holy Grail.. 30K and climbing!!
  129. Proud new owner of 01-1295
  130. Another one bites the dust
  131. HELP! code p0336
  132. Ground Control Q
  133. Haven't started my R for 7 years !!!!
  134. Stock intake tube and aftermarket throttle bodies.
  135. need help understanding ohm readings
  136. clutch recommandation for n/a itr??
  137. jdm gsr knock sensor question
  138. looking for DC2 Integra Type R
  139. Engine code 45 too rich/too lean
  140. Integra type r info help
  141. Removing EVAP on a C5 w/ a Hondata P28
  142. My R got hit.
  143. New Civic Type R at Nurburgring
  144. stoptech ST-40 bbk.
  145. Stolen itr armrest on ebay.
  146. Cars For Sale: Integra TYPE-R's - Mar/April 2015
  147. For Sale and WTB: Mar/April 2015
  148. rebuilt my distributor and have a question...
  149. Help 97 type r question
  150. [Help Needed] JDM ITR Exhaust Length Question
  151. denso oxygen sensors... which ones?
  152. My 4th R #98-0635
  153. 98-0178 badge for sale on eBay
  154. what could be wrong with the set up ?
  155. shifter linkage area movement and rattling
  156. Removing trunk wiring from body ?
  157. Extended Ball Joint Clearance Question
  158. Acre Formula 700 Brake Pads
  159. Badge # 00-0874
  160. B18c5 Rebuild questions.
  161. Itr expo 15 - Gingerman
  162. ITR in Preston, UK
  163. Strange numbers on rear trailing arms
  164. jdm 36mm hubs what axle?
  165. Best Auto-Cross tire 205/45-16
  166. Question about wheel offsets
  167. Need some advice on 1/4 panel, bumper and door repair
  168. Stainless brake line fitting
  169. B18C5 - oil and antifreeze mixing
  170. b18c turbo jdm housing size
  171. Bringing my R to Cali
  172. Looking for badge #98-0914
  173. help with value please
  174. Help me figure out who makes my rear sway bar
  175. The absolute WORST fake Type R product ever made
  176. 2000 Integra Type R (FBP)
  177. Brand New in the box Type R Transmission question
  178. 01 Type R Electrical issue ( Melted BLS Wiring)
  179. wet cylinders??
  180. Anime-ness! Honda Integra Type R - Itasha 痛車
  181. Painting a ITR a different oem ITR color. Opinions???
  182. type r hesitates as i hit wide open throttle
  183. Canadian Type R production numbers.
  184. Acceleration / Cruising Stutter help
  185. Help with engine bay...pics
  186. The Hunt For Black Octobers badge #
  187. Cars For Sale: Integra TYPE-R's - Jan/Feb 2015
  188. For Sale and WTB: Jan/Feb 2015
  189. 138mm B18 type R rod
  190. B18C5 Block N/A setup Rebuild Help.
  191. coolant in reservoir keeps disappearing!
  192. B18c5 Ignition rotor????
  193. need some coilover feedback
  194. Integra Type-R wing risers
  195. Headers, CEL, Test Pipe
  196. Tuning on stock ecu?
  197. k swap questions
  198. B18C5 Compression?
  199. Maintaining JDM Engines
  200. ITR Expo 14 Photos
  201. manifold fitment
  202. USDM 98-01 Fogs vs JDM EK4 96-98 Fogs
  203. Caliper Rebuild Kit? OEM If Possible?
  204. Tire size recommendations 205/50/15 or 225/45/15
  205. Where to find jdm front hood bra?
  206. JDM headlight projector size
  207. 2001 py #89
  208. Help! I overfilled my oil... Advice needed
  209. ITR Buying Advice
  210. Stolen type r found
  211. Noticeable difference in driving impressions from a '97 and '98+ ITR?
  212. Need help jdm B18c type r intake manifold
  213. whats the best way to fix quarter panel rust on an R?
  214. Cars For Sale: Integra TYPE-R's - Dec 2014
  215. For Sale and WTB: Dec 2014
  216. Help!!! Catch Can / Crankcase Ventilation System on my 98+ Spec JDM B18C Type R Motor
  217. Dyno compilation video from bone stock to basic bolt-ons and tune
  218. AutoTrader Type R
  219. bad idle.. IACV?
  220. itr carpet
  221. ITR trunk bar length??
  222. B18C "r" swap into 2000 ITR - CEL Questions
  223. Type R Value Opinion
  224. 97-00022, 98-0729, 01-0031
  225. Help with Oil Catch Can Setup on 98 Spec JDM B18C-R
  226. What steering wheel have i just bought?
  227. Help with Suspension for HPDE
  228. How to make your car go fast ;p
  229. Official Honda 2015 Civic Type-R Concept promo video
  230. JDM Visor Install... Missing Support clips?
  231. real desmond evo wheels?
  232. Type-R Restoration question regarding header
  233. near imposible to down shift?
  234. Bone stock '01 dyno
  235. Advice on 2000 JDM(?) DC2 for sale
  236. What's going on with my JDM B18C-"R".
  237. Itr 330 finally home!!
  238. What's your favorite part about the ITRs?
  239. ITR front brake caliper / What is interchangeable?
  240. Mugen Cluster.... Is it real?
  241. Newb question on motor rebuilding
  242. Does all USDM engines have a green vin tag?
  243. 2000 ITR rolling shell $800??
  244. Working for that Fiesta ST point by
  245. Test Pipe Question...
  246. New to me 1996 DC2R owner
  247. Airbag lights clips-Don't have to plug all the way.
  248. Timing Belt Help..
  249. ITR 4-2-1 Header & 4-1 Header Size
  250. 16" Bronze Volk TE-37 on PY ITR -
