OBD2 TUNING??
hey all, this is my first time posting something up on here and im sorry its because i need help. my names mike and i just bought a 2000 acura integra type r. i know we have gone over this a number of times but im hoping something has changed since the last thread i was reading from 2005. is there any way to tune the stock p73-023 ecu that comes with this vehicle? i want to build and turbo this thing and hopefully make close to 500. my main problem is i cant find a way to tune the obd2 ecu and i cant go obd1 because i want to pass nys emissions as well. i actually would rather run a cat with 2 o2 sensors anyway but if i build it, theres no way for me to just swap ecus and pass emissions..i dont expect the obd2 ecu to even start the engine after its built to 500hp let alone run right with no check engine light. is there any way to tune this obd2 ecu or at least make the obd1 communicate with obd2? i know the latter is a long shot but its 2018..someone please surprise me.
update...AEM FIC6 piggyback on obd2 ecu should work. the piggyback doesnt give as much tuning ability but can get my type r to 400-500hp while still retaining obd2 communication w/o CEL. thanks guys!
it is possible. its sad that after 22yrs of OBD2 i still cant get a simple and geniune answer from any Honda forums on this subject. i figured it out myself. thanks for reading the post at least, i guess.
If you're willing to try to push 500whp on a 20 year old 1.8L 4-banger with a piggyback solution then good luck with that lmao. You'd be better off having a chipped OBD1 ECU with a proper tune for regular driving then just swap in the OBD2 ECU + FIC6 with conservative tune just for emissions testing.
You asked if you could tune an ITR OBD2 ECU, you can't because the microcontroller at it's heart isn't rewritable and it doesn't have the capability to read from a separate ROM like OBD1 ECUs can.
(I can say this as I am currently running over 530whp on a 97 Turbo Honda using OBD2 Wiring and a Power FC. I'm still the only one in the Midwest that still does this.
Aren't the Power FC and EMS standalone engine management systems that replace the factory ECU entirely?
Not trying to argue, I'm perfectly okay with being wrong, forums are for learning. :-)
Yes. They are standalone, which is the only way to stay OBD2(A/B). Otherwise you cannot utilize the factory P73 to make changes without thr FIC or E-manage piggyback.
i guess since i figured it out and never needed to ask you never needed to respond.
yea youre right. the direct answer to my direct question is that its impossible to tune the p73 as is, but the GENUINE answer for my general problem (building a 500hp integra that can pass nys emissions test) would be a piggyback system. if youre just gonna post two words in response to the novel of a post that i wrote then i dont respect you or your opinion. if you have decent reading and comprehension skills you would comprehend that all i want to do is build a 500 hp integra that can pass emissions. sorry if my original post was too detailed. thanks for the "GENUINE" wish for good luck but, dont need your wishes. i need facts. lastly, why would i be better off having to tune the same car twice and switch between two ecus instead of tuning once and not having to touch it again? rediculous.
thank you for your insight! i have a tough road ahead of me, i know.
I agree with the 1st premise, but not with the 2nd premise. Pushing a 500whp on an OBD2 System is very possible, without the need of going down to an OBD1 ECU. AEM EMS, Apex'i Power FC, Emanage Ultimate, and the aforementioned FIC6.
Your road is tougher than you think. When doing my builds I had no emissions to worry about. You, on the other hand are going to have to find some palms that can be greased when it comes to emissions time in the process of competing your project
yea..im looking for palms for the first year at most. i bought the car with an obd1 p28 and no cat but i actually want to pass emissions. im not really trying to cheat the system..i figure i could use an obd2 ecu with fic6 for a decent tune and a cat with post and pre 02 sensors. even after turbo, i figure as long as the AF ratio and ignition timing is on point, and the cat and proper sensors are in place i should be good. i hope thats the only emissions equipment im gonna have to add/modify but i kinda expect other CELs once i install the obd2 ecu..as long as i have an obd2 ecu that can communicate with the emissions tester that all systems are a go with no check engine light i think ill be good. emissions laws just add to the challenge..i dont mind the extra challenge though. climate change is real yall! ☺
yeah i go though the pain of swapping ecu , injectors, 2nd o2 tricker to pass e test on my 2001 itr tuned on obd1 to make few extra hp lol
it somehow can run with no engine check light
flash0124
Engine Management and Tuning
Oct 19, 2012 08:32 PM
Brugalontherocks
Apr 28, 2008 08:10 PM
tour de france turbo
Sep 21, 2006 05:22 PM
MeanGreenEG9
Dec 2, 2002 05:21 AM
