View Full Version : Acura Integra Type-R
- Can't remove crank pully bolt on crankshaft to change my timing belt.
- 73 mm center caps?
- EXPO - Who said where are all the ITRs??
- do the 96 spec itr tranny have lsd stamp on it?
- Wheel hop between 1-2 shift
- Another Comptech IceBox Install
- Big mystery to me, someone help
- the stolen ITR list of 2003
- Awesome race pics
- burning 1 qt of oil every 1000 miles....
- Memories....some pics I found of my old Type R
- JDM Conversion
- Water Temperature Gauge Install?
- Found an easy mod on minicooperonline.com
- anyone with kyokugen lugnuts in the chicagoland area???
- Think I might have discovered a stolen ITR motor, tell me if my suspicions are correct.
- I think I know this R (brickhead)!
- Just got back from the dyno...
- Off Topic But need some help
- Anyone know what's causing my brakes...
- Caliper clearance question.
- Question on determining if JDM ITR block is a JDM GSR block
- Valentine-1, what setting do you use???????
- Anyone attempt a Do-It-Yourself maplight?
- What will it take to get an Integra Type-R in the 13sec range?
- New stuff, came in... i cant wait until after summer.. :P
- ITR exhaust question.
- Spoon paint codes?
- looking for itr damaged in front
- Has anyone ever attempt to take the weights off the stock wheels??
- Warranty void with catback exhaust? (searched)
- how many ITR's didnt go to the expo
- quick itr shift knob q
- Expo no show
- Differential question?Bearings......
- Expo Friday Pics!
- Valve Adjustment Tool....
- Met some Expo bound H-Tech guys!!
- SomeWTDR "early" Caravan, some more pics, rumors killed...
- Thanks Ed (sackdz) and Mike
- Having some trouble on deciding on the next mod.
- how much shorter is the JDM cat?
- Light weight batteries
- which would i be happier with??
- Please Help! Hit and Run in Orlando
- OT: Drove the EVO VIII...It's f*cking wicked!
- anyone have clutch masters stage 0 in your type R?
- Two different type of wheel lugs?
- Where to get replacement fuses?
- I am going Chicago to chill.
- ?'s about the B18C5 block
- If this is real, u don't need turbo or nozzz
- Wiring headlights in JDM Front conversion
- Topping out..
- Car won't start after installing Mugen ECU
- Mushy Brake after Bleeding... Help..
- Whiner-Tech.com???
- EXPO does anyone...
- Whose got the arm rest eliminator? I have some questions for you...
- Would a JDM ITR ECU(P73) work on a 2000 SI?
- expo ride alongs.....helmet requirements?
- 16" JDM Rear Clearance Problems
- Just finished first leg of Expo drive, now in Indy, anyone want to caravan to PA?
- Mugen Lowdowns – Stiffness Problem FIXED!!!
- how can u tell ur 1.5 way lsd is broken?
- Anyone wanna make some money??
- anyone with yoko parada spec 2 ? i need some help
- Anyone know any shop that can fix bent MF-10s?
- Pic request: broken rota wheel
- what does it mean if "the VIN wasnt there when i took the tranny out"
- EXPO - have fun
- RollBar /Cage -- What kind do you have?
- Look at my driveway.
- Last pic of R #213's before explosion.
- Greetings from the Expo!
- Does anyone have a pump for sleeping matress?
- Lamin-x vs Stoneguard?
- to all those attending the expo
- help please!!!! for apexi springs
- Another Expo Thread (anybody going up via 270 or 70 tonight?)
- what tire?
- 15X7 Rota in 5X114 bolt pattern (Yoshi approved poll)
- EXPO: Just bought my car...
- Expo spot for sale
- Deisel compression gauge..
- Installing Rotors
- GPS Navigation for ITR?
- any Hondata tuner in Toronto area?
- OT: California Residents... Please Help.
- Can someone post scans of Helm's tranny section?
- 4 Reasons Why I Might be in a Mental Ward by Friday (No Not Really, I'm just venting)
- anyone running 200+ N/A with JDM or ATS FD?
- Expo expo expo!! the 20th expo thread...
- How to build a JDM ITR
- OT Type R Sighting
- Problem
- Asahi make sure you wear something that stands out in a crowd other than a name tag.
- Expo, I'm ready
- Ultimate abuse for my ITR
- 01 ITR jdm front end conversion
- fs: Mugen, Spoon, stock wheels, pads & stuff
- ITR donut gasket?
- OT: New TypeR club track day pics took @ Zhuhai, China
- Any stores out there that can get brand new jdm recaros
- re: stolen tegs
- Hi all
- Type 1 Racing Testpipe
- Spoon N1 Silencer?
- passwordjdm seats...
- cool jdm type r book up on ebay
- sorry, cant make expo..few pics of the moobile
- JDM TYPE R gauges into a 2000 Type R WILL NOT WORK - or do they?
- Last Minute Expo Help, Need a room, and maybe some help on other things as well.
- A.C.T. 's new 8.5 flywheel... too light.
- Spoon or Toda header? and why?
- Best place to support engine...
- EXPO: Fri Morning & Afternoon, Sat Morning Caravans from NOVA
- Mugen Lowdown Suspension – Love / Hate Relationship
- Dumb Spoon Caliper questions
- Type R Oil cooler Bolt Size...
- Expo: hotel party?
- Post your ITR's compression numbers.
- Expo Time schedule
- Pics needed ASAP, canadain 97-00 ITR seats black with red trim
- Arizona R's
- Cars loaded for Expo3!!
- Car overheating.....
- How much do 96 spec Integra Type R wheels weigh?
- the search is down - AEM Break Pads - PLEASE HELP
- Expo: Guys who are installing parts at expo
- Anyone running Individual Throttle Bodys
- Expo: "Hi My (user)Name is: " Stickers?
- Any Orlando\Clearwater\Tampa Rs Going To Expo3?
- Setting up VAFC
- ITR boot!
- sound from break heat shield
- Fresh CTR Buildup Question
- I have a picture request...
- Cylinder Head Machine Work Attn:VA/DC/MD
- I have a transmission question
- Alignment tools or scales at exp0?
- Rear Sway bar
- packing for the Expo
- Hytech Header Question n jun ti retainers
- Black rims?????
- Boost Upgrade Kit?
- Off topic.. I am moving to Virginia.
- EXPO: FL/we-todd-did-racing caravan has begun...
- Are there any good tuning sites for the SAFC?
- 2nd Type R
- Expo: What brake pads are you going to be running?
- Honda-Challenge Pics from Carolina Motorsports Park (April5-6)
- Anyone else have clutch issues?
- 1993-97 hood same as 97-2000?
- New SMSP Cat Back
- Need answer quick....
- need color code for usdm 98 type r !!!
- I drove my first lapping day in the R (vids inside!)
- weight of stock ITR rims..?
- WT: Trade my stock itr oo' seats for red Jdm recaros + $$$
- When warming up your car...
- Are All B-Series AEM Pulley the Same???
- Who's going to RoadAmerica May 10-11th?
- toda forged pistons and spoon head gasket help needed
- fuel pressure psi for type-r motor
- Charlotte Auto Fair
- spoon filter vs aem cai
- aren't type R's stopped in 00?
- Header gaskets question
- A little worried: Surface condition at BeaverRun
- EXPO: Will there be any vendors there selling anything?
- pic request. flat black rota slip's on a yellow R
- mugen twin loop? spoon n1?
- Steering rack ratios for the ITR
- Expo Weather!
- What parts do I need for a Clutch install?
- Did some preping for the Expo
- Would anyone like a room at the Holiday Inn for Expo?
- Expo: should I go?
- Anybody heard of crowhouse japan?
- anyone using a short shifter
- Who can vouch for Ross?
- R owners in Davis, CA?
- Difference bet. Type-R & GSR clutches and flywheels?
- Track day is coming up and need help!
- ITR is for sale for those interested
- Bad News: Need new tranny.
- Expo & Testpipe question.
- hiding nitrous?
- To those w/Mugen Intake
- oem shiftknob
- ITR guys...your honest opinion...
- ? about installing new pistons
- Any rubbing with spoon springs 17" wheels?
- heel toe
- Archive is down. What is the autozone rear rotor #?
- resonated testpipe, anyone running one of these?
- Buying a used Toda Flywheel...
- Type R OEM wheel center caps $30.00 EACH?
- ITR Lip Aerodynamics Comparison
- Whats this??
- New Springs/Tires --- droning deep noise
- testpipe vs. ITR cat
- Expo guests pass
- Expo related buy way OT
- wheres my oil going?
- Anyone want a Mugen wing?
- OT: Bugs in the system?
- OT: Some Ebay goodies (links inside)
- Momo hub 4903 fit on ITR?
- I'm interested in SPEC Ds... What are the PROs and CONs?
- Engine mounts for ITR
- Question regarding 2000 USDM ITR frond end???
- Good All-motor pistons and rods....
- JDM integra type R question - Power folding mirror related
- how much would you expect labor to be on.........
- What is the Helms Book Part # for 2001 ITR?
- ot: International Auto Salon
- Expo 3: Reminder, Bring Money for Food and Shirts
- My Modified Mugen twin loop !!!!!(56K warning)
- Why does this happen?
- Factory Recommended Tire Pressure for ITR
- New Skunk2 Mega Power Exhaust System??????
- do falken azenis sports come in 205 45 16 ???
- Expo: Camp we-todd needs a tv :|
- what stage2 cam brand for best mid range?
- B18C4 ?
- Anyone here with Apexi VAFC?
- New Azenis need a break in?
- removing bottleneck
- stock jdm 01+ integra wheels
- exhaust question (mugen twinloop)
- sparkplug wire question
- Need some help (CF interior)
- update of my R. 56k watch out
- Soooooooo nice to be home again... Oh, and butt dyno between an Embraer RJ135 and an ITR :)
- New carbon fiber
- how can I tell real JDM 16" OEM ITR wheels?
- Expo Campers Revisited - Read.
- very OT: best motoring video s2k vs. itr?
- apex coil over wrenches
- Steering wheel alignment?
- what is the color code for the type R PY
- Help!!!!
- Car security, what do YOU use???
- help with timing belt question
- Its snowing at Beaverun
- To those with DC JDM header
- allmotor
- Experience with powercore cat (race version)
