View Full Version : Acura Integra Type-R
- Are there fake JDM Type R fronts?
- Question about PIC bushing kit
- A/C problem
- itr carpet simple question for all
- Hate me or not, 97' #0347 will live.
- UK based 96 JDM DC2
- Broken wires
- PSA - Check your aftermarket cam gears for wear!
- fluctuating idle and jumpy speedometer needle
- \\\\\\\\\\\\\\\....itr seats....////////////////
- Somebody save this ITR quick! 14k miles
- ITR wrecking party
- Helppp
- help on injectors!
- Good deal on a tranny, what should I do?
- Type-R Motor 96 Spec
- PICS of my 00 PY Type r and Buddy's H22a CB7 56K NO WAY
- Trying to install rear asr subframe breace on my 00 ITR...
- rotas slip stream dc2
- oil pan bolts missing...? confused
- max boost on JRSC on stock motor?
- whos using the toda clutch and flywheel in their itr?
- what do u guys think of these wheels
- Integra Type-R - DC Sports & product of Chinese craftsmen
- Bb can you use mud flaps with optional side skirt and rear bumper
- Please clear up s2k brakes on an itr
- Bolt on turbo kit
- 98 CW-ITR - Stock & Pricing Q's - 46k miles
- Rc_skuby's immaculate 1997 integra type r
- anybody got a pic of an itr with prelude sh wheels??
- Dent in the oil pan...help.
- ECU Chip
- techtom cmx-100, help me out
- ht member cheeze and itr owner
- T1R help ?
- Where can I find Mugen emblems for a Gen 1 spoiler ... ???
- ITR Badging
- i love 97 R's... (pics)
- 98 - ITR for sale #769
- 01 ITR help?!
- jdm honda integra type motor
- Is it worth it to tune with just bolt ons?
- rod and main bearings for jdm itr. where can i get them???
- HELP!! Was in an accident.
- quesion for those with JRSC
- Spotted PY-R in Brampton Area
- Expo a month away!
- Need Help! SPLASH GUARD needed!!
- need HELP with my 5 lug swap!!
- compression?
- Expo 9 Advance spot available....
- Quick Question
- Rebuild questions
- Timing belt replacement = Rape
- Looking for a Type R
- 1997 Integra Type R NEED HELP
- ITR compliance bushings - different than non-R?
- Import cars profiling and harassment
- what are your valve spring colors?
- MY 5th gear is grinding in my itr.
- Need a little advice..What would you do?
- lower tie bar install HELP
- where to get a 2.5 donut gasket for ITR header??
- Is this an stock ITR exhaust system?
- Type R rear bumper cover
- CW color code itr
- Spring installation?
- '97 rear spindle same as '00??
- time for new lower tie bar wich one ?
- Full power + turning over and no start
- Rear Brake Caliper Question
- Documented Factory Show Car
- 2.0L Itr dyno tuned at 113whp!!!WTF!!
- Hub bearing
- Wtf??
- Driver's side axle removal
- best way to put on mugen emblem on gen1 spoiler
- any one have the part number for trailing arm bushings?
- Timing Belt
- Pic request: 2000 ITR booklet and brochure. Help!
- Fellow SFL ITR Owners
- thanks nsxtasy
- Spoon N1 Damper installed - rear is slammed?! help pls!
- Black NSX lug nuts
- R Sighting! (4/11/09)
- Valve springs/colors
- jdm itr front - oem hardware part numbers
- Quick 2 R Questions
- Bridgestone R-11 performance tires..
- Timing belt seized, what to do now?
- want to remove tint from my rear window
- JDM ITR Carbon Hoods...where to find 1x1 Plain weave ones?
- Information Request: warwagons PY ITR
- engine damper (nrg, ingalls, weapon x, etc)
- 00 Itr #679
- new GOODIES for my ITR =)
- What my Type R means to me.
- header choice
- Any of you R owners have a spec sheet for toda a's?
- Transmission Removal: Tranny Weight
- Help with part #'s for timing belt, water pump, ect..
- NZ JDM ITR build: Updated
- Question regarding rsx axles and itr 5 lug 36mm
- Itr has sunroof controls? wtf
- I wanna put an s2000 on my Type R...Need info
- ITR cluster in GSR????
- My Nightmare Has Come To Fruition...
- White R on 95 south before the Gee Dub
- Type R TRUBO? how many pounds?
- optional valence weather stripping
- does a dent on header kill?
- would you get rid of your type r for an nsx??
- Immobilizer in a 98?
- Doostur Sighting
- ITR rear seats
- San Diego is cracking down on Modded cars
- which pcv?
- VIN question
- replacement injectors?
- ITR Shell
- My Itr rebuild thread "Introducing My Itr #0449"
- my new itr
- Do USDM ITR pistons stick out of the block?
- Cleaning your Recaro's seat?
- How do I remove/plug off evap box?
- Most beneficial upgrade for JDM B18C
- Spoon blue and yellow?
- Realtime Racing Type R cars...
- My previous Type R doesn't show up in a VIN search.
- Wanting to Supercharge my ITR
- Throttle problem!!!
- Tranny Question....
- has anyone seen this itr?
- My other R is an Rx!
- Buddy Club Camber kit install
- TRT 'Comptech' Replica Rear Lower Tie Bar Review
- Clutch Suggestions...For 225whp
- PY theft Recovery Rebuild.
- 90k mile service
- Hello kitty (Nardi)?
- Got my ITR, need help with pictures
- please help me find oem parts !!!
- Final drive
- Rear itr shock lenght ?
- -tein type ra ? sell or keep and put it on?anyone have experience with these?
- VOTE Favorite Honda other then ITR
- Type R Rep Wing Different?
- help!!! ITR STUD
- Expo '09: Scales?
- VOTE Favorite Honda Engine other then B18C5?
- Type R Bushing Kit
- block stmaping
- OEM Front lip attachment points? Anyone have pics?
- Is there a comparisson between a real and fake itr rear strut bar? any pics plz
- intake arm, air breather/coolant line question..
- what is this light called?
- License plate Mount?
- Steering problem
- shout out to my dude* highroller54**
- daily driver tire recommendations (again) for jdm 16's
- FS/WTB Thread MAY 2009
- New pics of my ride
- need info on itr knuckel
- Feature ride of ********.com!!
- I think I have an ITR throttle body?
- IACV Problem...HELP!!
- front lip options?
- Skunk pro series turbo cams with jrsc?
- Vortech V-5 G-Trim Supercharger
- Quick Question.....
- whats the casting # for the front jdm 5 lug
- JDM ecu in US car, second o2 is EGT?
- Itr #
- short shifter
- tire ? Dunlop direzza Z1 star spec
- A few new pics...
- whos R
- WHats the carbon fiber lip that you can put on a ITR wing?
- Cruising speed/rpm
- ITR Expo Posters?
- Drag strip
- Wiring up side folding mirrors (searched)
- Oil Coller with or without Thermostat
- thinking bout goin boost
- Someone has to jump on this deal!!!
- best way to lower the R?
- will a obd2b p73 ecu work in a 00-01 integra GSR
- ???USDM vs. JDM Exhaust???
- rittesport
- Where to buy cv boot axle grease?
- MINT 01 PY Type R For sale on Ebay.
- DC2R Honda Access window visor install questions
- Acura Integra Alarm
- AEM CAI vs Mugen CAI
- Samco Induction Intake arm?
- question re: spoon n1
- Armrest Delete. Yay or nay??
- stock type r shifter length???
- Vapor/Charcoal Canister
- Possibly coming back to the darkside- PY 01-0041 anyone???
- 1996 USDM ITR- Acura Press Vehicle
- How to tell if My cams are 97 spec ITR cams and how to tell year on head
- replacing a crank sesor on a obd2 b18c
- where can i buy jdm itr ball joints?
- Dual Pod for RHD
- SMSP High Flow Cat?
- So did I pass up a good deal, or did this R bring all it was worth ... ???
- R1366 gets a makeover...Thanks to bbasso!
- ITR Expo Prep
- engine swap
- Favorite Color Type R's in order? VOTE PLEASE
- JDM ITR - Enkei, Nardi, Benen, J's, Fujitsubo, Bilstein content...
- Sell DC2R to buy DC5R. Would you?
- iso : Type r cams
- OEM Type R Floor Mats $110 Shipped
- Bushing Install
- Gear doesnt go in all the way
- Fs: Built jdm type r motor
- Finally got me some Type R Kool Aid
- ****where can i find...?
- where...?
- Some cool rolling shots of Maxie in Vancouver.
- Yellow Type-R in DeKalb, IL??
- Would you trade your ITR for this.....(pics inside)
- question about usdm itr shifter
- ERR 2 nails in tire!!
- new Typ r clyinder head needs valve job?
- My C5 with no header on
- Vin Locations??
- anyone working for dealership?
- ooohhh yes finally
- OT: Some had the guts to cut this mugen intake, lol
- Recaro seats fit on my LS rails...yes or no?
- fluidyne radiator capacity?
- Anyone knowledgeable of the "spun" converters??
- identify this exhaust
- PY Canadian R #1086 00
- track car
- greddy ez cams?
- getting my b18c back.
- Rear traction issues?
- Password:JDM DC2 '94-'01 Integra Type-R Headlight Jumper Harness ?
- Will NSX-R wheel fit ITR Hub?
- Can I use this for oil pressure / what is this bolt?
- Looking to buy an M3 instead of an R talk me out of it...
- Need advice on a header please.
- just put 2000 type r motor in. what gas?
- New R Owner, just got a 01 NHBP R
- spoon caliper jdm 16 what size wheel spacer
- My ITR won't start . Can anyone help?
