PDA
View Full Version : Acura Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 [138] 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335
  1. Fuel Pressure stuck on 50psi. Help
  2. Azenis, 260 for 4. Good deal? then take a look
  3. Help:Installing USDM crank angle sensor and oil pump
  4. FS: 2000 FBP Type R #660
  5. Letter G on my ITR muffler?
  6. Back from the Dyno/Tuning - Results Inside...
  7. ITR Spotting IL
  8. FS: Comptech Icebox, ATS FD, Skunk2 cam gears, and Rota Slipstreams
  9. shift knob install
  10. FS: Fujitsubo RM-01A, Mugen Intake, JDM OEM 4-1
  11. JDM ITR Front End Install - The Part Numbers for Parts that Most of you probably didn't know to use.
  12. Melted dipstick!!!
  13. ITR clearcoat question posed to anybody who has done it before...
  14. ITR owner's opinions needed!
  15. ITR spoiler removal?
  16. Just got Axxis ultimate pads in.. Do i need different fluid?
  17. Edelbrock exhaust system for ITR?
  18. Please Help!!! what should I do with my type R
  19. Apexi N1 Coilovers for my Type R
  20. 97 R that needs some work, thinking of selling
  21. OT: Another standalone customer converted (B18A-T)
  22. Need to buy USED/100% working O2 sensor for my 00 ITR .......
  23. First complete SMSP exhaust system in Europe! (56K)
  24. Variations in imported Type Rs?
  25. Check engine light after DC JDM header install
  26. jdm-r upgrade
  27. Upper pillow mount problem - Buddy club RS dampers
  28. SPC Rear Camber kit installed, comparative pictures
  29. O2 extention
  30. Kinda off the topic, but involves a ITR regardless...
  31. Anyone want to sell their GM OEM ITR wheels?
  32. Tuning the Car Tomorrow - First Time
  33. Anyone using S2000 HIDs?
  34. SW388 vs. Slipstream question for ITR owners...
  35. brake lights dont work
  36. ITR SUSPENSION - good set up?
  37. HELP! Oil Leak
  38. snaped off a 99 white type R ek
  39. FS: 2001 Phoenix Yellow Integra Type R #801
  40. I need an ITR MC and prop valve
  41. Will Axxis Ultimate fit JDM Brake pads?
  42. What seat rails are you guys using with Recaro's in your R's
  43. blown headgasket but good compression results?
  44. Quick opinion needed-Tranny related?
  45. WTT Rear GSR sway with bushings + cash for rear ITR sway with bushings
  46. Spoon Coilovers...what springs????
  47. Laser Cut JDM Valve Covers...not bad...
  48. problems with your itr
  49. ITR EXPO in Honda Tuning
  50. 97-98 versus 2000-01 ITR shocks?
  51. ITR rear brake help
  52. Taillights are not working!!!
  53. where to find the oem sides and rear skirts?
  54. need help with starter and flywheel!!
  55. motor problems continued: solved?
  56. OT: Any good mechanic in San Diego, CA?
  57. Greetings from an old member... but im BACK! **AUSDM Pics Inside**
  58. type R alexs
  59. Thomas Jeremy Truong: 1981-2004
  60. Pic of my AUDM '00 ITR
  61. Vibration?
  62. 2nd o2 sensor (?)
  63. will changing 4 lug hubs for 5 lug hubs work>????
  64. Another FS Link: Skunk2 Arms (front)
  65. OT: Good Japanese (Honda/Toyota) mechanic in Seattle/Bellevue/Alderwood, WA?
  66. Koni Yellows on JDM 98 Spec R.
  67. Recommended Starter Modifications?
  68. Fun in Black ITR 231
  69. Pics of usdm carbon fiber lip on FBP Type R anyone?
  70. semi OT: GSR block fit our ITR head with no modification?
  71. the difference between a jdm & usdm tranny
  72. At what engine temperature should OIL LEVEL be checked at......?
  73. Expo4: What date is everyone reserving their room for?
  74. Used R - expected expenses?
  75. Best place to buy ACT Clutch and Flywheel?
  76. OT: I need tires for my coming beater, Odd size... where to get them???
  77. Koni/GC -- Suspension Tuning
  78. Any recharge their a/c yet?
  79. hood pop cable for jdm conversion
  80. jdm foglight switch
  81. DC2R Synchro??
  82. FS- Comptech Rear Tie Bar
  83. Looking for dealer - OMP parts
  84. Some nice wallpapers I found
  85. USDM ITR CF Lips: Let's see 'em
  86. why cant i reply in some topics???
  87. Is the IACV specific to the type-r, or will one from a gsr work?
  88. odometer
  89. Valve Spring Retainer Dropped During Install
  90. Need cheap wheels or borrow some!!!
  91. What is this?
  92. CrowHouse and INGS +1 Aero Kits
  93. Troubleshoot: Transmission whine at a specific speed (stupid new-b track story)
  94. Mugen steering wheel
  95. Comptech Race Header vs Toda Competition Header
  96. EXPO 4: OK it's time!
  97. Dealer problems- should I even bother trying to do something about it?
  98. Would this be an easy install........?
  99. Azenis at Vulcan
  100. SPARCO EVO Install Dilemma Help?!
  101. Type R vs. Evo video
  102. Pls. help pick which final drive is best for me.
  103. Expo 4 campers please check in. (second try)
  104. Anyone know where to get some JDM ITR overbore pistons?
  105. Inlinefour.com??
  106. Share UR experience with IPSracing?
  107. How to wire JDM HID headlights?
  108. EXPO - Co-driver wanted, driving from Nor Cal and back...
  109. FS link: Mugen 26mm sway and Mugen gen2 front strut bar
  110. Has anybody tried replacing your Acura sign with the JDM Dc5R rear Integra badge
  111. For those who use gauges on their R, Got a question.
  112. Need help on TQ specs
  113. What shoud the compression across the board be for a b18c Type-R Motor???????
  114. Question about Oil Block Adapters
  115. R spotting in Tallahassee
  116. Expo 4 - Sponsor Deals.
  117. How long should my DENSO IRIDIUM plugs last ???
  118. Cackling (B18C)
  119. OT: Survivor Winner from Beaver PA..(R-related inside)
  120. Dyno'd my R today - 172.8 WHP
  121. case anyone needs an OEM ITR JDM Bumper/Lip I have one for sale cheap!
  122. ITR bottom end revlimit
  123. shifter sitting low...?
  124. how much are you paying for insurance?
  125. fwiw: I'm over 14k on azenis and still going.....
  126. 205/50/15 azenis vs 225/50/15 dunlop fm901's.....
  127. Question on Buddy Club Spec Dampers
  128. First time pics of my DC2R
  129. Removing the ecu for security
  130. OT:Problem with account
  131. Looking for original owner of a 97 ITR built by SPEEDSTAR in Tornonto.
  132. VTM signal on vafc
  133. 00' PY ITR ... FOR SALE.....
  134. Socal: Streets of Willow SOW May 23 Caravan (leaving may 22, sat)
  135. Getting creative with the stock intake
  136. Type-R headlight assembly??????
  137. Type-R headlight bulbs??????????
  138. OT: Crime doesn't pay, but it lets me drive really cool cars....
  139. SoCal->AZ (tucson)->SoCal in 24hrs *phew*
  140. Results from a day of tuning w/ Yack @ P1 (awesomeness inside)...
  141. Oil leaking from turbo
  142. Hey guys, WTB the Rear Strut Plastic Cover... cant post yet on Classifieds
  143. J's Racing CF Air Duct???
  144. Some new "bling" for the R... (question for you spooners)
  145. Worthy ITR replacement?
  146. CW paint code???
  147. Will ITR rims fit on an S2000?
  148. Vibrating noise coming from back seat
  149. brake question
  150. PY R spotted in Greenville SC on 5-9
  151. Who's 98 R pulled over on I-4 between Lakeland & Tampa this morning?
  152. Supercharged
  153. Race rims
  154. mugen and spoon headgasket..
  155. Anyone got a USDM ITR ashtray and lighter for sale?
  156. My JDM 1996 ITR Picture
  157. Man, I'm idiot ITR owner of the month.
  158. Camshaft CTR new,ITRs change
  159. Need prices for my accident, can you help?
  160. Quick Hondata question
  161. OT: Need help from the FL peeps! making trip to FL 04/12-4/16
  162. can someone help me verify......
  163. FS: Bilstein SP shocks
  164. Need help with Full Race kit install
  165. Pic request: Moving ITR shots
  166. Spoon N1 axle back vs. Comptech axle back
  167. Few new shots of the R...
  168. Torque spec for spark plugs?
  169. Port and Polish?
  170. Stock Intake Question
  171. Coolant leaking onto passenger floor
  172. VTEC engagement problem
  173. Pics of my UKDM Integra
  174. Happy Birthday, Eric (NAB20C5)!!
  175. Anyone using a NARDI steering wheel?
  176. Spark plugs and ignition wires?
  177. Tein Flex: Lowest and highest height settings?
  178. Silver B6 S4 vs ITR topend run.... hihi Fun fun
  179. ITR security....
  180. I miss my R
  181. lots of shifter play?
  182. Once again, got jacked
  183. Integra Type R - has it already come and gone?
  184. Good all season tire?
  185. Questions about ITR valves
  186. How do ITRs compare to others from a roll?
  187. ITR motor build input
  188. cam install
  189. FS: 1998 Integra Type R #0450 (Championship White)
  190. Spotted: White Jdm Front end R Long Island 347
  191. motor problem: broken sparkplug
  192. [Search] Integra Pix
  193. CW Stock Wheels Repainted (4 Pics)
  194. Best 195/55/15 Tire For Under $100.00 (Each)
  195. the aRRR is blooding out *wrecking time*
  196. Replacement air filter?
  197. Weight reduction: Undercoating
  198. Apexi V-AFC monitoring
  199. OT: Spain GP
  200. Video from MapleGrove Drags tonight
  201. Hmm looks like its time to tune...
  202. Mugen M7s (Link) PCD 114.3, 5 Lug, +45
  203. F.S. toda and mugen
  204. compression test results
  205. ITR ownership cycles...
  206. New track times
  207. OEM HID to aftermarket HID?
  208. Should I use Denso Iridium or NGK platinum.....for my ITR.
  209. Dyno numbers with cams?
  210. code 41 searched help please
  211. Please help... Engine problem
  212. Any tips appriciated......
  213. Tire Shop Won't Install New Tires
  214. bolt on GSR Rear LCA interchangeable with Type R?
  215. QT: Anyone wanna help a fellow il itr owner out
  216. Pics of 0072 - finally
  217. HELP ..... Need a picture of an Eibach rear alignment kit
  218. Bassani Cat converters, Have you heard of them?
  219. High Flow Cat is it worth it?
  220. Torque Specs Needed
  221. I think I spotted Yoshi234 in Brooklyn, NY
  222. Air Intake
  223. Is it ok to start cranking?
  224. MotherF*cker Tried to pry my door open with a crow bar
  225. type r cams?
  226. who would be interested in a traction bar/crossmember bar for cheap?
  227. IMPORTANT! Socal, who can go tonight to visit Thomas.
  228. ITR CENTER COUNSEL PLEASE HELP!
  229. Do aftermarket pedals help?
  230. cel 41 + 43
  231. where can i find spoon stickers?
  232. Crashed! Yep I got hit.
  233. F/S link: 1" spacers for 5x114.3
  234. Finally got my new ( used ) fd and 5th gear swap done..
  235. ITR Expo Coverage in Honda Tuning
  236. Camber question?
  237. College Paper you Hype R guys will enjoy reading, I promise
  238. Hytech setup finally came
  239. Difference between an ITR and a GSR?
  240. Anyone selling a stock axle back type R exhaust?
  241. a really really cool video!!!!
  242. PY Insect Humpa?
  243. Central Topic for Catback WEIGHTS
  244. Let the Fun Begin.... Goodies Arrive.
  245. p73 keycode
  246. Anyone know where I can get ITR pistons?
  247. wingless PY spotted in coconut grove , tuesday night
  248. Difference between JDM b18c and USDM b18c5 tranny
  249. Question on purchasing an R
  250. Any fast N/A R's
