View Full Version : Acura Integra Type-R
- '98 Honda ITR #2113
- Speed Sensor effect VTEC?
- VEGAS!?
- Mickey Thompson Street Radials ?
- 98 SPEC ITR OBD2???
- Is it bad to get Tranny wet while its off block?
- Help needed with JDM 98 spec motor vtec install
- Trunk Issues with my 00 R
- USDM ecu and harness with JDM motor?
- Are these Real Deal USDM ITR seats?
- Mugen Thermostat doing damage??
- Help me figure out engine stuff
- Cat heat up light
- a little sound check from germany 'mugen & video inside'
- Want to kill some time?
- B18C5 Build Throttle Body Size
- Well I did again got another Type R today
- Need a mechanic in central FL area for advice!
- What are the pros and cons of honing your ITR intake manifold
- #01-1094 are you out there
- Front LCA problem
- attn type r owners....possible stolen engine/ fake r in my car?
- Ink Stamp on LSD transmissions
- ITR FRONT END: Rad support T-bar part number
- 9k RPM
- ITR 4x114.3 axle size
- Greddy SP2 Muffler
- Best place to buy a new jack?
- Speed/Rev Limiter on ITR
- What to replace while motors apart and getting built (ie bolts, gaskets, water pump)
- 2 10mm bolts holding wire around oil pump/t-belt pulley, missing?
- type r rims itr wheels 5lug notires
- ROLL CAGES? Pic of your cage set up whether its road racing or drag racing
- JDMsh*t.com Seats...any good?
- anyone know of any good auto appraisers?
- Broke Clutch , AND Tuning !!
- temp gauge not working??
- In dash TV problem in my ITR? need help
- NEW CMP track day this past weekend pics/comments :)
- difference between us and jdm tail lights
- rollbar in Canada
- minimum thickness on mugen active gate rotors??
- Crank pulley bolt interchangeable between ITR & LS cranks?
- Distributor Rotor Notchy When Spun
- stock itr flywheel weight...
- Lets poke a stick at these idiots!
- Help with tire pressure cap
- its been awhile and I wanted to let you all know...
- Venturi Carbon Fiber Intake from memoryfab
- LS/RS/GS cat on itr
- Best Way To Store Seats
- Cheapest place to buy a harness bar????
- need 4 to 5 lug adapter to put itr rims on my ek stok susp.
- It's a GIRL!!
- Clutch Noise ????
- ITR 1997 Model
- POST your pics of your STOCK ITR Rims on slicks or drag radials
- fujita short ram intake 3" ?
- New Owner to the ITR community - 2000 Black R #1429
- What do you guys think its worth?
- Anything I shoud be aware of before pulling tranny off block?
- Points to lift motor out with?
- TPS plug
- Itr with Gsr
- OT GO GIANTS !!!!! SUPERBOWL CHAMPS !!!!!
- 01 PY Type-R For Sale - 95K mi
- fresh oil on my half shaft SUGGESTIONS??
- ---Last Photoshoot for my '98 Type R---
- Open tracks to the public
- RIMS FOR SLICKS?
- Please take a look at this itr swap...
- 2 front lower motor mounts - I ripped the rubber part?
- clutch line running into tranny removal?
- ....In the Market, YAY!
- 2000 PY Type R For Sale
- Looking to purchase my 1st Integra Type R - would like some advice !
- hid cutoff line
- Spoon Caliper + Brake Pad Compatibility
- Specifying stock spring replacement?
- ITR SPOTTED !!!!
- jdm hid installation
- Rear LCA bolt/stud same as?
- where can i get the itr 4 lug suspension?
- Looks like we have a scammer in the group.
- WHERE TYPE R's MADE IN 1999????????????????????????????
- Clean my ITR's?
- expletive TYPE R
- Custom Spring Rate Retrofits for Coilovers - Few Questions
- West Coast ITR Track Day
- Cars for Sale: Integra TYPE-R's ONLY
- For Sale and WTB for February
- SONUVA!!! NEED HELP!!! Insurance trying to screw me.
- SMSP header and exhaust about to be for sale off my R
- Which IACV are interchangeable?
- Anyone in MD wanna help me pull my motor?
- Valve Size
- Draconian Virginia Resident Drivers Civil Penalties Law REPEALED!
- DataDot DNA for theft prevention?
- Brake Master Cylinder is it possible to rebuild it?
- if anyone is looking for spoon twinblock calipers
- [PICS] Sydney Australia Photoshoot! - JDM yO!
- less positive offsets /fender flares flush /w wheel and tires
- any body selling type r
- b16
- Mugen engine mounts
- Slight pulsating in brake pedal..
- Trade? Tein Rear strut bar
- is there a certain way to tell type r internals
- Tranny code
- Spark plug gap for NGK BKR7E-11
- Anybody selling there ITR wheels
- JDM OEM HIDs on a 97?
- AHHH DAMMITT BROKE MY CLIMATE CONTROL!
- Shafted
- Honda Integra Type R DB8 (4 door) Buddy club Spec 2 Exhaust????? Do they make it for 4 dr?
- JDM itr emblem question?
- J's Air Duct w/ Ice Box...
- Passing caRR emission question
- Got my ITR back!!! :)
- My new KONI yellows - problem!
- need help asap on type-r and a code
- BREAK MASTER AND BOOSTER
- ITR + MUGEN + SPOON + LOVE = LUCKY
- can somebody please confirm their front caliper bracket number?
- Finally Lowered 00-501 , **PICS**
- Gas guage stop working ITR cluster
- Lowest sliders/rails for DC2/DC5 jdm recaro seats
- jdm experts, is this an amuse exhaust?
- manual transmission fluid?
- OT: Thanks to Mrlegoman/FullEP/Yack, Expo 8 will be a complete success!
- JDM Headlights original
- OBD2 A OR B??
- How does a quick release steering wheel work?
- Its Happend again Stoen ITR in Phoenix Area
- New owner of 00-0891!
- Happy Birthday, Opie
- Transmission problems... please advise
- VIBRATION FROM MY ITR
- Plug for TPS sensor
- How to tell which year JDM ITR cluster?
- anyone patched cigarette holes before?
- Yellow recaro thread! where is it!!
- black itr i saw...
- OEM Type R Seats...
- Rear Brake pads how important are they?
- 12:10 in the afternoon THEFT ATTEMPT ?!?!
- anybody had this issue with a SOLID CEL - check engine light on with jumper in?
- CDN Acura Dealership For RED REARS ????
- Wing Talk
- Dynapack Dyno results...=o/
- shift points
- Need Help with Vtec
- 96-98 spec b18c
- P73 datalogging program
- Type-R tranny??????
- OT... supra meet yesterday NC (pics)
- Jazmad0sa = No ITR no mo :(
- Check engine light!? (evaporated emissions system leak detected)????
- Christmas in January - Santa Doostur delivered this....
- New Zealand Trackday at Taupo Raceway (A1GP track)
- OT car's before your R??
- can someone help me out with this?
- mugen front brake kit??
- 98 Spec JDM Gauge Cluster and CF console
- Clunking sound when stoping at lower speeds?
- Help How to tell a JDM p73ecu from a USDM p73
- Most awesome site of all sites
- DC AREA: expo train rolling.......choo choo
- who's CW ITR on 40 between chapel hill and southpoint?
- Need help with parts numbers
- itr seat cleaning...
- clunking noise from steering rack?
- Price Check please * pics *
- Mugen Bushings questions and LCA
- looking for 2 piece stock replacement rotors for theitr
- ITR Wheels and Suspension..Is this a good deal?
- Whats wrong with my itr?
- ***Checker Floormats***
- Type R Catalyic Converter
- Free JDM Type R? and a hot chick....
- Injector qustions
- Need help with tire search!!!
- Who's going to the Koni Challenge / Rolex 24 hours?!
- ***Expo 8 @ VIR - June 9/10 - Event is a GO and Registration is OPEN***
- My new project -> jdm 96 dc2
- the Kaaz LSD: good or no?
- Needed: '97R USDM specific engine bay pics
- b20vtec BUSTED thought the type R guys would want to see this
- 3-4 syncro problem
- Rear Swaybar
- smoke in your ITR
- SPOON 37760-EK9-G00 Thermo Swith install on DC2
- Missing Year in ITR badge * pic *
- Anyone use traction bars?
- What are you listening to in the car? (Driving Music, FTW!)
- jdm foglight switch question
- Any JDM Places Around Philadelphia?
- Header Tech Question
- Help me! My ITR is leaking oil...
- FREE parts off ITR...
- How about a JDM TYPE R swap pic topic
- New ITR Owner looking for suspension advice
- type R floor mats
- DC Area Members! Meet me Tomorrow at the DC Auto Show (Free VIP Sneak Peek at new GT-R)
- PAINT CODE FOR GUN METAL 16s
- Valve tick
- help on head build?????
- ==Name that OG==
- ITR Memorabilia
- Type R identification
- UPS arrived with this....
- for you all trying to find mugen intake
- advance timing
- Pic Request ** Rear OEM Strut bar plastic piece?
- 25.5K for an 01 R!
- Pics: My trip to the Xavier Institute for Higher Learning
- Winter Track Time - Sebring Jan 19-20 Pics
- OEM ITR SPRINGS, how to identify ?
- Crap load of new shots of ITR138 =P
- Las Vegas, NV. "JjuuN R" where are you?
- New Walmart dedicated to selling only ITR related products!!!!!!!!!
- new type r owner
- I need axle help...
- more pix of the R...
- do i need a baffled oil pan if i am auto-crossing?
- ** ITR Help please !!
- Mini JDM Recaro Type-R Baby Seat :P
- Well It Starts!
- SPOON FED All Day (luv this car mang)
- finally got my Hondata tuned, wanted to share numbers and some pics
- New addition to the family
- Dyno'd yet again today... New numbers/videos...
- Cheap Expo Helmet!!! :)
- Any ITR owners in Nashville, TN.?
- CF add on spoiler.
- Free cams: would you use?
- 29 today
- Stuipd THIEVES, SEMI happy ENDING!
- quetestion about Hondata s200
- To take my R to work with me in Wyoming?
- WTB: spoon twin block calipers or trade...
- So who from Texas is going to buck up this year and drive to Expo 08?
- type-rx
- #2225 Type R stolen
- 96 jdm type r(original showed no love:()
- OT: Calling Out SMSP...
- Calling black 2000 ITR #1537, where are you?
- itr horse power
- Are all ITR's 5 lug?
- Walbro in ITR JDM 99
