PDA
View Full Version : Acura Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335
  1. Wedssport TC-005
  2. Question about one of my Mounts
  3. ** UPDATE: Annual ITR Thanksgiving Meet: PLEASE RESPOND ASAP **
  4. custom airbox
  5. Spoon Shop CA Good Choice For Type R
  6. Couple PICS From Aloha State Rs
  7. j's racing fx60rs
  8. what would this do and can it be dun?
  9. ITR rear lower arm 98 JDM?
  10. JDM ITR rear trunk bay
  11. What else different between GSR short block & ITR short block?
  12. clutch slipping ????
  13. Exhaust Fitment Question
  14. anybody have pics of black ITR rims with polished lip
  15. Ignition Timing
  16. Wing or wingless? Kills the orginal style?
  17. Removing door panel
  18. Who here has Air Conditioning??
  19. Time has come to sell my 98 ITR
  20. Do I Have Bad Wheel Bearings?
  21. How to tell difference between front and rear speakers???
  22. Titanium Rotors.
  23. TODA Header question...
  24. ITR Carbon Fiber INterior
  25. ITR Oil / DC Manifold
  26. OT-HKB Steering HUB for ITR
  27. Cobalt Friction (They're Almost Ready!)`
  28. Where to buy springs?
  29. Battery Choices and Options
  30. List of 2000 ITR's
  31. My past weekends event at Sebring.
  32. whats your mileage???
  33. 96 ITR brakes with accord rim ?
  34. Fail emissions Test - will running the car for 15mins before test help alot???
  35. New ITR owner here....question about gauge placement
  36. Cheapest/Best Place to Buy Custom Rate Ground Controls and Koni's?
  37. Question for owners that have had a stolen ITR
  38. Missing Vacuum hose? Causing Idle Problem?
  39. Aluminum AC mount
  40. some lo jack questions
  41. Collector Size?
  42. Do I need special pads for my AP Racing Calipers?
  43. turbo kit?
  44. carbon fiber trunk
  45. Link to my Clean Title ITR
  46. Octane in the US with a jdm motor/ecu...does running 91+ improve anything?
  47. Checking out an ITR shell: I need advise
  48. the best oil for ITR tranny?
  49. Want Custom License Plate
  50. tranny question
  51. rear sway bar bushing collars?
  52. Fuel pump prime
  53. HELP!!!! ITR won't start???
  54. Painting the headlights
  55. JDM ITR - OEM style CF Front lip??
  56. Last time as a full out member...ITR goes tomorrow! :(
  57. Tranny Question
  58. Distributor coil tested bad, replaced it and now the car still isn't firing?
  59. Exhaust Manifold bolt / nut issue
  60. 1997 vs. 1998+ ITR cams
  61. good idea?
  62. Intake Whistle?
  63. anyone have any tricks to removing govenors....
  64. i need a fast answer
  65. Question on shift points on VIR-North
  66. Photo request: PY JDM ITR with gold wheels
  67. Alternative to HONDATA IM gasket that is not compressible?
  68. ITR suspension on EG Civic [coupe]
  69. ITR Center Console... HELP.
  70. Mugen Factory Worker Button Down Uniform What do you think it's worth? & RWD Integra at Expo 7
  71. T1R test pipe
  72. Need carfax for ITR
  73. serivce interval on the fuel filter
  74. Stalls at lights!
  75. jdm r manifold and usdm manifold same?
  76. fuel cut
  77. What type of oil/filter do you use for your ITR?
  78. exhaust question
  79. S2k steering wheel in an itr?
  80. Toda cam gear wear - is there a warranty for this?
  81. In-car camera mount for recaros
  82. spoon sports street exhaust
  83. Boosting a Stock B18c5
  84. ECU pin for canadian spec ITR????
  85. B Series Tranny Gearing Compatibiliy (since other forums are useless!)
  86. Buying a new house and '98 ITR has to go.....
  87. Dented headers....loss of performance and how to repair?
  88. How many of you guys still have the original paint on your itr?
  89. pennzoil synchromesh
  90. k20a2 type s motor and 06 type s tranny $2000
  91. failed VA inspection for stupid reasons. (yes there is a question)
  92. Research/ Report Hottest Nor Cal area with honda/acura(especially R) thievies
  93. 4.7 FD
  94. Sqeaking in reverse
  95. Bleeding Brakes Question
  96. valve clearance
  97. Volk Racing "TIME ATTACK" Wheels -- Interest?
  98. where to find wheels?
  99. Attaching the shiftboot to the knob on an 00-01 ITR
  100. All R come with titanium shiftknob/red stitchin boots? exceptions?
  101. The Replacement R For the Stolen R
  102. How many of you guy will be at NOPI ??? The LHT Guys will be.
  103. Curb Mark
  104. New ITR owner here...
  105. Type R interior?
  106. Have a question about a 2000 type r
  107. looking at an ITR tomorrow...
  108. Build..
  109. new time for the turbo R
  110. Twin Girls on the way, ITR on the way out
  111. contacting hytech or John@ hytech?
  112. Check engine light Fuel trim malfunction HELP
  113. last day out at the drag strip... vid
  114. help new to integras!
  115. hid itr headlights
  116. jdm hids questions
  117. forgot to post it here thought the R guys might like to see it
  118. Going to Illinois for a race. Does anybody want to go?
  119. Leftover Type-R Stuff for sale...
  120. Some pics from my first HPDE.
  121. All muscle with funkmaster flex
  122. JDM IM
  123. 2007 Acura TL-S @ Mid Ohio!
  124. OT: The R finally sold. Here is the replacement.
  125. What is the diameter of the rear stabilizer bar for EDM (or JDM) DC2 ITR ?
  126. correct me if i'm wrong,no vtec, cel
  127. dc2 jdm shiTz, and moRe..
  128. clicking sound
  129. Brief Question
  130. Black lug nuts for extended studs on OEM wheels?
  131. ATTN: ITR Owners with Mugen Hood the JDM vented one y0 mad tiite JDM y0 HELP
  132. Another PY paint problem - damp cloth removes paint!
  133. JDM ITR 5 lug 36m axle spline HELP
  134. New here (pics)
  135. question about ignition timing
  136. What cars does a Jackson RAcing ITR supercharger fit???
  137. 18 Yellow Type R's for sale
  138. I love my R!
  139. Rev Hard Stage 3
  140. Installing an Engine Dampener
  141. Itr Suspension question
  142. Car temperature rises when in Vtec?
  143. 100k miles!!!
  144. OT: Flying to Nebraska and Arizona Next Month. Meet up?
  145. typer r pedals pads
  146. "E-Brake Light is always on" I need help!
  147. wierd? all of Bbasso's threads are locked.
  148. Typeee needs some boost..
  149. fail-safe relay??
  150. doluck rear cross bar - how do you tension it?
  151. ITR Door Panel ?
  152. **Where did your R take you this summer?**
  153. is the gsr and itr cat the same?
  154. Sold my Type-R
  155. USDM Optional Skirts/skats
  156. Need badly the partnumber for the 1.gear neeldebearing of the 4.4 finaldrive!!!
  157. 98 JDM ITR pistons ...over sized or standard???
  158. ITR MEET AT HIN VEGAS?
  159. ITR's for sale??
  160. JDM ITR headlight cleaning
  161. Jackson Racing Supercharger on Ebay
  162. Type R parts sale. See inside link!
  163. fitment
  164. Selling ITR sucks
  165. In my V-AFC needed?
  166. I need to make a decision!!! and I need your help!
  167. How much would you pay.. k20a ITR?
  168. Question for the R guru's!!
  169. Anyone sitting on 97 Type R wheels in Champ. White????
  170. Another Stole!!!
  171. 1997 ITR STOLEN.............MODESTO, CA
  172. Replacement Rotors/Pads for 96-spec ITR 4-Lug Spindles?
  173. incorrect torque specs in helms?
  174. OT: ITR floor mat
  175. Will usa run out of b18c5 blocks this year????? ARE they going to be rare like Gt500???
  176. Coted Mild steel Header + Header wrap = ??? bad idea?
  177. Jdm front end legal?
  178. where to find a high compression compression tester?haha.
  179. Help! - check engine light - " 91 Fuel Tank Pressure Sensor low input "
  180. Best wishes to you White Dragon
  181. Cam gears are misaligned...how?
  182. panasonic battery?
  183. Exhaust question (axleback) really
  184. Hello all need some advice
  185. Locating a non-modified Type R.
  186. paint code
  187. wheels
  188. Demon eyes conversion
  189. Exhaust problem
  190. i got a typr r motor can carfax see if it is legit
  191. New to the forum..my ITR
  192. Good deal?
  193. found my 1/4 time slip...tell me if its decent
  194. header purchase help
  195. DYNO day for the ITR, suprising results!
  196. type R "H" Centre Caps
  197. OO #1512 is back
  198. *** Expo 7 Tentative Location and Date ***
  199. ITR tranny
  200. test pipe
  201. jdm front fog light bulb??
  202. Thinking about this type-r... Is it worth it?
  203. Yet Another In-Car from the Spoon Race Car at Mid Ohio
  204. ITR cams with b16 cam gears!
  205. Bay Area ITR Meet?
  206. Got a turbo manifold for sale...
  207. Front Stabilizer Links needed 97 ITR
  208. driverside axle question
  209. speedometer
  210. Bushings: poly vs. hard rubber vs. spherical
  211. NASA Virginia at Summit Point (Videos)
  212. what are the best headers for a type r?
  213. did these come to the us?
  214. JDM RHD ITR 1998 (conversion)
  215. Dilemma: 7psi boost + ATS 4.9 final drive?
  216. OT: some more race car pics!
  217. ITR distributor code = TD-87?
  218. exhaust shakes and vibrates
  219. JUN3 camshafts with ITB?
  220. B18C3?
  221. Door protectors
  222. Crazy idle prob....IAC??
  223. Has anyone tried the Silk Road suspension on their ITR?
  224. rattling in alternator area
  225. OEM foglights
  226. Intake to fit a 70mm TB...
  227. FS and WTB items for September
  228. can someone tell me the difference between an oem itr front strut tower bar and an ebay 1
  229. ? about itr outer valve springs and portflow inners
  230. how far does the castle nut on your lower balljoint go?
  231. need opinions on this buy
  232. OT - little info for the OG we-todds
  233. Over 30K miles on my RE010
  234. Best way to get old cotterpins out
  235. Someone help me post pics
  236. Please help me brothers, ITR problem
  237. Spun bearing - how much to repair?
  238. Raceline 98 ITR
  239. ITR gunmetal rims where to find!?!?
  240. GSR handling compared to ITR
  241. Used ITR Prices...searched.
  242. posible blown headgasket.
  243. How much to pay for a JDM integra Type R
  244. Weighed in my car, got any ideas for 1/4?
  245. how much are these parts worth??
  246. spun bearing? Question why?
  247. Does any have a spare 2000-2001 USDM ITR ECU?
  248. My ITR project: engine build
  249. Anyone still have and want to sell their stock suspension?
  250. Price you would pay for This R
