PDA
View Full Version : Acura Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335
  1. Which motor?
  2. FS: My 2001 Integra Type R
  3. Cost of Legalizing a RHD car?
  4. Integra DC2 Diagrams
  5. need help with aftermarket c&r raidiator tying to utilize the ac while havign the full size radiato
  6. ITR 98-01 orig. brochure
  7. Are these ITR seats?
  8. what radiator are you guys using?
  9. Trust issues!
  10. Climate Control Bulb
  11. Good exhaust in the Market Place for Toronto people
  12. About how high above the top of the mainshaft should the bearing rise?
  13. Purchasing a Type R motor, have a question
  14. Coolant flush.. without hassle of taking off drain bolt
  15. OT: Evians shop burned.
  16. OEM Fog light install ???
  17. OT: Time for a house..
  18. integra type r vs. sentra se-r??
  19. Clicking noise coming from inside steering column?
  20. Lets See CANADA Represent...
  21. Food for thought: Audi RS4 v8 runs static cr at 12.5!
  22. type-r exhaust
  23. New Rocker to replace VTEC? Bueno or no?
  24. Pleaee list you ecu in your R
  25. anyone know where I can get a new rocker arm assembly set for my new rhs gsr head?
  26. FS USDM 2001 ITR front red seats MINT MINT.
  27. DIY Warning lights
  28. cant get hose off thermostat housing.....HELP!!
  29. VTEC Solenoid Problem only when cold
  30. Blk ITR in nyc streets
  31. expo 7 northeast caravan?
  32. ******* AEM V2 induction systems ...... or better?????? *********
  33. spotted: jdm front cw itr in newburgh yesterday
  34. FS: Used Hondata S200 and Invidia Catback Exhuast
  35. Type R #1049.. first time posting pics of her... enjoy.
  36. 6speed ITR tranny???
  37. OT: Anyone need directions to London?
  38. No oil holes on big needle bearing in transmission housing?
  39. B series versus CRV axles..........
  40. boggin problem with my type r dont know wat it can be need HELP!
  41. Code 7 : Throttle Position Sensor : Questions
  42. black soot, searched, still confused
  43. OEM JDM HID.... problems... the bulb's connector BURN
  44. what is the head oil control orifice and o-ring?
  45. How much torque will an ITR clutch hold?
  46. reason why apexi would have two part numbers for JDM ITR header?
  47. JDM ITR TRANS ISSUES: ADVICE NEEDED
  48. Spoon 2007 Civic Type R vrs. Spoon DC5 Integra Type R
  49. NEED SOME HELP ON THIS
  50. Instruction Manual for Acura Fog Lights?
  51. OEM RICE or NICE?
  52. Head Shield Rasping Noise?
  53. heel-toe pedals?
  54. JDM A/C System work in USDM?
  55. hydraulic lift experience?
  56. USDM vs JDM itr front strut difference?
  57. max SC boost on itr motor
  58. I've Betrayed all of you and Honda
  59. type r internals ?
  60. CF doors
  61. ITBs Worth it or Not?
  62. interested in buying a black type r..
  63. Honda ITR
  64. problem after installing new shocks
  65. Quick question bout 96 OEM JDM front lip
  66. OT: Something for the We Todds
  67. My 2001 PY ITR recovered...gutted...
  68. JDM Headlights Wiring Question
  69. yup ricer-ism still in the blood- new wheelz w/ flavor!
  70. kinda OT: Salvage title questions
  71. My Speedo Doesn't work on 94 integra type-r
  72. any itr owners in orlando florida?
  73. question on itr number ?
  74. Hiflow Cat
  75. blox vs. jdm oem
  76. picked up a new set of wheels for the '97 R
  77. Anybody have a set of OEM rear shocks/springs available near Greensboro, NC?
  78. Rare Windscreen decal on ebay ( Heads Up!! )
  79. jun stage 4 cams
  80. Happy Birthday to Ferrell!!!!!!
  81. JDM Type R motor vs GS-R motor
  82. Mugen 4-1 headers ITR Received
  83. Supercharger ? ? ?
  84. JDM ITR Headlight Hazing. . . Help
  85. Happy Birthday Bradstard!!
  86. *** OT - VIRGINIA TECH shooting 22 killed *** ITR related
  87. Installing a Spoon diff.
  88. Suspension installed, making squeaky noises, a little concerned!
  89. Where to find this type of connector for JDM turn signals?
  90. USDM ITR heatshield onto JDM header?
  91. Which tranny fluid do you guys recommend?
  92. 205/40/16 tires
  93. For all you ITR guys that DD...
  94. Will JDM length header+ JDM CAT + USDM B-pipe match the length??
  95. Oxygen Sensor Heater - CEL
  96. OT: Formula 1 Brake Discussion video
  97. The rice-boy in me is alve and well!
  98. Got some NEW shoes for Pikachu....Lots of Pics
  99. Upcoming weekends CMP prep. 56k warning!
  100. Energy suspension bushing kit (searched)
  101. Black R owners and rock chips.
  102. rubbing issues??
  103. Front sway bar? 17mm vs. 22mm?
  104. Oil breather chamber question.
  105. Is there more than 1 filler bolt for the transmission?
  106. Which are the washers for the filler/drain bolts? See Diagram...
  107. Some pics of my JDM ITR in the UK
  108. Need help finding Top Fuel product...
  109. Inner cv joint on my ITR
  110. What Bolts/Gaskets do I need for a Fujitsubo Power getter?
  111. Trying to locate a lower bush for coilover?!
  112. - - - - - - JDM Length Header to USDM cat back Question - - - - - -
  113. Help!!! Car performance Fu#$ed...Added oil
  114. jdm b18c
  115. 97 jdm b18c anyone interested?
  116. collection of ITR dyno sheets?
  117. Need some opinions
  118. Maybe the type r guru's can shed some light, ctr b16b throttle body size?
  119. What are the first mods recommended?
  120. Opinions on exhaust piping..
  121. ITR Tranny rebuild need parts etc.
  122. do JDM ITR's have black seperator on the back w/ PCV line?
  123. Question about SNK and their dyno
  124. Clicking noise when turning steering wheel?
  125. evo, best front-driver of all time
  126. Pictures of everyones ride and wut springs they used
  127. Free Intake?
  128. it was a decent day so I took a few pics
  129. Rear performance rod pic
  130. 2000 Black JDM Integra Type R F/S Connecticut
  131. Wheel Spacers
  132. Losing Power!!!!
  133. ...Considering of Power Steering Removal?
  134. What are the first mods recommended?
  135. Need opinions::: Take a look at this radiator. POLL TOO !
  136. ITR OWNERS!! what seat you prefer? BRIDES or RECARO?
  137. Stupid question help! (maintenance required light)
  138. Old member new caR
  139. Guess your weight!
  140. thermostat and fan operation questions (LONG)
  141. all type r owners must help!!! 96 b18c jdm motor in 2000 itr...runin obd1 how to past inspection wit
  142. type-r for sale
  143. F.S 2001 PY ITR 0674
  144. Are all B-series starters compatible?
  145. Does anyone here have a CTR Rear Sway on their ITR ?
  146. Bad news, motor shot in my 95 Rs beater;(
  147. ATL ITR.............Anyone here?
  148. WHAT REAR END IS THIS?
  149. all type r owners must help!!! 96 b18c jdm motor in 2000 itr...runin obd1
  150. Front Sway bar End Link for the ITR - swaybar endlink ???
  151. pressue plate ?
  152. Transmission problems
  153. Where to get itr swaybar bushings?
  154. Help diagnose me please!!!
  155. ordering OEM parts (cylinder head & block kits)
  156. Any ITR owners here have (NICE) Daily beaters? Need Opinions..
  157. Arizona Type-R Stolen Today from North Phoenix, be on the lookout
  158. Integra type r side stickers
  159. where can i find.
  160. taking out the side impact beam under the rear seat
  161. Finally
  162. Another R Stolen :( from Harriman, NY
  163. ITR Shift Boot
  164. Question on OEM Fog Lights
  165. help looking for VISIOn TYPE TC YES TC not dc mirrors
  166. Anyone good with physics?
  167. Loud Squeaking Noise When Reversing!?
  168. some pics of my 01 type-R, with jdm front end
  169. probs with jdm conversion
  170. Anyone have issues with Energy Suspenion inserts popping out?
  171. Erratic idle, missfire, momentary power loss...PCV?
  172. wrecked 2000 fbp type R part out
  173. i need the 01 black r in atlanta
  174. Mugen front aero kit
  175. Tach issue
  176. Any way to check a distributor?
  177. Importing ITR?
  178. ITR Checkered Trunk mat Taking offers
  179. eBay Racing radiator vs. Koyo Racing radiator
  180. Does loss of serial number lower the value?
  181. Intermediate shaft
  182. Fuel injector clean/test - anyone use Injector Services?
  183. need Help?
  184. Are there any TODA Spec C2's or D's in stock?
  185. rebuilding theft recovery 2000 ITR, need help with no spark, immobilizer?
  186. Exhaust Question : Is EG Spoon Axle back same as DC2??
  187. SEAT RAILS THAT FIT RECARO SPEED SEAT
  188. tranny experts needed - will an ek9 ats 4.9 fit my 98 spec tranny?
  189. Fake spoon N1 axle back??
  190. ***EXPO 7 @ VIR on June 11-12***
  191. pics of my 00 ITR BLACKNESSS!!
  192. what is the diffrence these parts (OEM)
  193. A/C Bypass
  194. Is the OEM kit (side skirts/rear lower lip) still available from dealerships? Where to buy?
  195. She said she's extra thirsty lol
  196. Bump stops w/H&R sport springs
  197. Where to find JDM white 16" type r wheels?
  198. New Pictures of 00-0346
  199. CTR steering wheel?
  200. How much stronger are the jdm 36mm axles over the 32mm usdm
  201. ~* 2nd Annual NE/PA ITR meet *~ (Memorial Day weekend)
  202. Access to radio antenna?
  203. Help with speakers in the R...
  204. Blox exhaust
  205. neuspeed upper strut bar
  206. K Series or Spoon B18c5 or used B18c5
  207. Question on JDM fender liners ??
  208. ENGINE MOD-ING
  209. Type R worth owning?
  210. My ITR # 370
  211. Want to know B18c5, jdm b18c & usdm h22a injector lag/latency value
  212. Went to the dragstrip on Saturday...
  213. Drag radials
  214. emisissions suck i need help
  215. Did a Compression test on the r
  216. Congrats to Marshall Hagen
  217. ? what type of rails do you guys use
  218. OT:Snow in south texas in April
  219. NY-NJ-PA-WV-MD-VA-TN-AK-TX
  220. I am new and just wanted to see if anyone........
  221. I've got a question for all you type R guys.
  222. jdm 99 itr comp check #'s with eta 60k miles
  223. Wiring Pinout Information Needed (and CAN Protocols?)
  224. ZERO 1000 TOP FUEL PRODUCTS
  225. What you guys think of Magnaflow exhaust on the R?
  226. looking for race header
  227. ITR 0032 needs help
  228. ITR Parts for Sale (link)
  229. Water in trunk
  230. FS: SOCAL: NIB Apexi WS2 Full Exhaust System for 94-97 Integra LS / Type-R $350
  231. noob trany help
  232. OT:Nurburgring
  233. FAQ: Engine Specs of the ITR...
  234. Motor is IN, Throwing Error Codes... Need some help
  235. cams: '97 vs '98 vs '00
  236. my first R
  237. Do ITR calipers come with the 25t or the 23t brackets?
  238. quick fuel pressure questions
  239. smsp customer service
  240. bumper plugs
  241. New to this Forum
  242. Some pictures of Rebecca
  243. Centre wheel caps
  244. will a type r shiftknob fit my automatic Rav4?
  245. what's stock C5's head flow rate CFM ??
  246. type r cams on a gsr motor
  247. Broken Speedo
  248. Torque Settings
  249. JDM ITR Sway Bars
  250. 15x8 45mm, 225/45/15 hoosier on ITR
