View Full Version : Acura Integra Type-R
- BC Spec 3 exhaust for 97 R
- Help out with some pics of OEM parts.
- Installed Some Goodies!!! (56k ComeON ...Get Broadband Already!)
- What exhaust would you recommend??
- I've decided to give my Expo spot to .... Aquafina!
- ITB'S.... Where to buy and what to look for?
- ITR vs SI Sway Bar question
- Anyone Rebuilt Apex-i N1 coilovers?
- b16 tranny in DC2 clutch line question(plz help me so i can order the part)
- Question about JDM Itr cluster...
- Price jump for itr motors
- 80mph feels like going 60mph
- K20A2 Swap
- 96-97 JDM ITR 4 lug conversion...cant find it in search
- Has anyone else gotten in on that 15x8 5 lug slipstream groupbuy in the sponsors section?
- JDM ITR conversion to US OBD2 compatibility
- SCCA Logbook in hand!
- weight saving Exhaust?
- if you had to go quiet
- Mugen n1 and fuel pressure
- Where to buy heat/header wrap? (searched)
- thinking of selling her
- anyone put a flowmaster on an ITR before?
- question re: installing axles on a type R
- Suspension Question - Look at Picture
- ITG Air Filters
- FS - '98 CW Type R #191
- T1R Bmax vs. Koni/GC Setup
- Anyone selling his/her R in vancouver, canada?
- so it finally happened to me......!!!!!!!!!!!!!
- DC2R TPS?
- worst R ever
- check engine light trouble
- Will rear S2000 Wheels work on an R
- OT: Driving home in my Type R 56k go away
- Expo 6 - Gingerman Raceway June 12th & 13th
- my 1998 ITR For Sale
- Did anyone sell a '98 with JDM 16's on ebay in the last couple of months?
- Came to my senses, keeping my 1998 Integra Type R
- Out of ideas. Need help with ITR throttle body.
- Hatch shock replacement
- LINK: 98 ITR stock bits and pieces available in PA
- Another insurance option for us 2 car type r owners.
- Header question
- Fidanza Cam gears?
- I am thinking about installing a ATS final drive
- drive shaft problem
- NY/ NJ 1998 Acura Integra Type R Salvage Certificate Found ( Heads Up for anyone Interested)
- Broken bolt
- Idle adjustment
- Can someone give me the link to the vid of the itr beating the german m3?
- Are Ebay headers killing my sale?
- OEM ITR Tweeters same as other models?
- PowerFC tuning
- Found ITR for sell.
- wheels spin when in neutral?
- Any Type R Owners in New Orleans?
- inside ITR ecu - plz help
- Help!
- So my friend has some rounded off flywheel bolts..... :o
- Photoshoot of the re"fronted" repainted R
- Rounded 14mm hex plug
- ITR for low price?
- Name dis song..It's a ITR vid so it's too off topic..
- Toda header cracked any advice repair or replacement
- ITR Brake Lines Replacement - Subframe Drop
- something i came across
- Thinking about buying
- how is this for a theft deterrent system??
- Apexi VAFC, SHOULD I GET ONE???
- Type R sticker flaked off at the car wash
- Welcome, Skelly; From the ITR Forum.
- Help...got some weird TRANNY problems.
- 2008 Integra 2.3L turbo 280hp!
- iacv problem maybe my ecu? p73
- Are the integra type R injectors the same as the ctr injectors and what size are they????????
- INJEN COLD AIR INSTAL !
- K20A Stock or B18C5 NA Build Up??
- Broken Sensor
- Update of OPIE'S ex.
- Great HID KIT
- Evap purge?
- Pictures of Wai's EX, 56k sure but I don't care how long you wait.
- JDM ITR 16" wheel offset question??
- S2000 steering wheel fit Integra R?
- What do you guys use to clean your Type R seats?
- heads up for Toronto people
- Insurance advice...
- Nitrous install/ Fuel line question
- all those in NOVA area
- FS: ITR Integra Type R OEM Intake
- -Pulls to one side upon accelrating?-
- carsound cat is dead, should I "hollow" it out?
- Mugen Intake
- Which Size is this ? ( Pic inc. )
- Type R cake
- tranny question
- ITR '00-#1494?
- Just put in 5zigen headers
- Wheel offset question.... Need Help!!
- I think im running a little lean.... HELP
- Acura Integra GS 2000 / h22a-s swap
- Who Wants A K24?
- NSX Vtec Solinoid?
- type r seats i need help they lost colour
- Shift linkage question: removing the spring pin..? any tips?
- OT: WTDR is Back Up!
- USDM ITR Carbon Faux interior pieces, ITR catback exhaust, itr trunk bar
- where did you mount your hondata blue box and ecu?? ***pics plz***
- OEM or aftermarket Lip theft prevention....
- Me and Opie are starting a business...
- Spring rate question??? (Konis or Bilstein's w/ GC coilovers)
- JDM 4.782 final drive + ats 3.077 first gear?
- Godly Alarm!
- motor mounts
- Still clunks a bit when going over potholes
- question for ITR DC2 guys with OBD-I swap
- anyone running a 2inch collector?
- need help identifying engine.
- Suspicious Type R engine for Sale in Houston - Link
- MY ITR - Its been a while since I posted pics
- those with type r i need a pic..
- those with a type r i need a pic....
- itr bars?
- Does anyone have these?
- New guy with a type r soon
- 13:1 comp ratio... ways?
- What rims......
- any decent suspension (coilover) setups around $800?
- OMG 2007 civic type r
- Type-R spotted in Boca Raton, FL
- J's Racing 60RS Titanium Exhaust?
- question about ITR tranny
- Koyo radiator
- R for a Daily Driver?
- wear on valvesprings
- Rare ITR Crank Pulley?
- Need help finding a ITR to buy
- Anyone have a 97-98 ITR they want to sell?
- Any regret in selling the ITR?
- Where to buy AMUSE R1 Titan exhaust
- Spitting flames?
- Someone photoshop me some racing stripes!
- Problem with car stalling
- Vidio: My 2.0L ITR at the strip
- d16y8 type r parts??
- Hytech exhaust owners, need help on separating b-pipe from muffler
- what cam shaft+ gears..
- spoon head gasket
- type R brake calipers
- Happy Birthday To Me!
- Tires..??
- bitburg test rally
- CHG / Engine on signal?
- How do you remove interior plastic...
- integra sir g
- Should I keep the LMA's
- itr suspension question
- insuring the most stolen car in america?
- OT: 2006 CTR Concept
- looking for a hub
- Engine Stamp Help
- Jdm Itr Tranny Fluid
- what ngk spark plugs
- just want to make sure- tein basic dampers.
- What is the Inner Diameter of OEM ITR springs?
- 96 spec vs 98 spec JDM header q's
- ECU code help
- Is this a DC2 Mugen Exhaust?
- ITR transmisson how to tell?
- WANTED: JDM ITR HEADLIGHTS?
- NEEDED: set of 5th gears(main and counter) from LS model..
- wtb: oem itr muffler...
- Tunning need help
- ??OEM ITR Header what size Flange do i need for my cat??????
- FS/ ITR trunk mat....
- Little dots of oil on bumper: symptoms?
- ZYGspeeds R 151 in new hands....
- LSD INSTALL QUESTION
- expected WHP on a dynapac dyno from JDM ITR
- Firing order?
- OEM ITR Exhaust.
- OT: Smile for today
- Pic request: ITR coming out of Suzuka assembly plant
- Need Apexi VAFC2 wiring diagram for 96 JDM ITR
- Batoutahell is getting older - Happy B-Day!!
- I've been gone too long - I need a vouch!
- question with 96 type r suspension (brake rotors)
- What do I need to hit 8600? (valvetrain)
- Torque Specs on ITR Motor
- How to identify ITR transmission?
- Vtec solenoid bolts
- Hit and run on my Type R!!!
- 6 speed transmission for ITR?
- Finsihed stripping the R =(
- Postcards from the edge... (No 56k)
- Rear Capliper Slid Pin.
- ITR tranny vin # or code?
- Help here please!
- Need help ASAP bout spoon exhaust!!
- Honda PACT (Degree/Cert)
- how can i tell if they're itr cams?
- WTB JDM Carbon Fiber Hood or Lip
- fs/ft ITR JG Elelbrock Intake Manifold...
- Whats the Difference from JDM Type R & USDM Type R Bottom End??
- My next Type R
- please help 4x114 conversion
- Kenji and Phearable ECU
- NEED APEXI VAFC2 WIRING INSTRUCTIONS
- Mugen Brake System Question
- Anyone have Slipstreams with polished lips?
- vtec not engaging
- Suspicious seller on Ebay with an ITR head for sale in NJ
- Link - JDM RHD 98 Silver itr for sale *registered*
- hey what bumper is this?
- Smells like syrup.
- Md Guys i need My Hood Painted Can anyone Help??
- New pics from bodyshop!
- Xbox 360 Type R! I've got the only one folks!
- Totaled or not?
- Pics of 00-055 Finally washed it!
- steering wheel sizes
- Jerks and Hesitates
- JDM ITR NOT STARTING!
- Buddy Club cams and cam gears
- Should i get more shirts made?
- n00b questions...
- help with tranny
- Jspec Headlight Lenses
- which o2 sims actually work? i've searched with no luck
- So here is an interesting story I'd thought you guys might like to hear.
- Happy B-Day Civic Sista
- am i asking too much?
- coolant line off of thermostat housing
- <sigh> Amber lighting - head units/iPod interface
- 2/28 Happy B-day to me :-)
- P73 ECU Gone bad ... any experiences ?
- ** pic request - Takata Green ITR rims **
- ITR cam confirmation
- Help w/Rear Main Seal Replacement
- Pic Request.. Need a car for a logo.
- Part number for Energy front swaybar bushing - JDM 25mm swaybar?
- 3rd gear grinding.. help
- Want to upgrade grounds, what parts should i consider grounding
- Black volks on ITR. What do you think
- Probably Selling My R :o/
- would dc2 rear lower control arms fit into ek?
- Roll Cage?
- Koyo Radiator Users, What Coolant are you using?
- Homestead Speedway 12hrs
