PDA
View Full Version : Acura Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 [245] 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335
  1. anybody know where i can get a JDM SRS steering wheel?
  2. gauging interest in techno spirit c-pillar bar
  3. What is a good compression setup for 2.0 N/A?
  4. AJracing networks
  5. brands of baffled oil pans
  6. Passenger side airbag tray part number?
  7. Best 195/55/15 tires??
  8. Test pipe!!
  9. Blue Si with B18C missing post?
  10. Where can i find this gasket(b-pipe to cat)?
  11. Where can I order OEM badges from?
  12. Anyone try the new A-Sports adj. short shifter yet?
  13. Oil Pan
  14. New pics of my R...(dialup beware)
  15. Sprint Hart CP-R?
  16. Plugs for Wing holes.
  17. Ummm, sparks from brakes under *heavy* braking - normal??
  18. Turbo Motor Install
  19. ACURA Dealerships in NJ/Tri-state Are
  20. how can i tell if i have a B18C5 block????
  21. list all the jdm conversion parts
  22. Any ITR's tried some of the bright yellow headlights? (almost like the GT series Porsches)
  23. Got my car back, JDM front end looks sweet
  24. car suntan?
  25. Ordering a header! Need as many opinions as possible.
  26. Acura is giving me a new motor
  27. Warrenty work please help?
  28. Anyone else know of, deal with, or have any Moriss Suspension componants?
  29. Clock Removal
  30. Honda With 205whp and 237lb/ft. Of Torque? BELOW 4000rpms?!?!
  31. ITR tranny same as....
  32. Where is the best place online to find JDM parts?
  33. Any R's for sale around Pacific Northwest?
  34. Are 195/50 too small on stock wheels???
  35. where to find pix of Black ITR with stock black ITR rims
  36. What lines run in fron of the radiator....
  37. JDM 4-1 header with aftermarket cat vs USDM 4-2-1 header with stock cat
  38. What gear are you guys in??????????????????
  39. Searching for pics help ... DC5R
  40. valve adjutment?
  41. Hot center console -- exhaust problem?
  42. Is OBDI legal in the states???
  43. What is "privacy glass"??
  44. EF ownZ j00!
  45. Team City Limit...need your help
  46. ATTN: Chris/SoCal itr
  47. Falken Azenis expected lifespan..How long has your lasted?
  48. Need some Torque Specs please...
  49. Harnesses Help
  50. Disconnecting V-AFC
  51. Toronto R's
  52. turbo tune in G-boro...
  53. Looking for Ground Control Advance Design Aluminum Shock Mounts
  54. Where do you get the rear wiper arm replacement parts? Please help!
  55. 3.2 type S vs ITR
  56. My Broken ITR Tranny
  57. anyone know if we can fit smaller brake calipers on the r , look inside why
  58. OT: For my b-day, my girlfriend got me...
  59. No front plate.
  60. shift nobs?
  61. How Soft Are Regamaster Rims?
  62. Wiseco 82mm and eagle rods. PICS
  63. what do our cars wiegh stock?
  64. OT: But somewhat enjoyable... Teardown of 4G63 (DSM) motor (Pics)
  65. ITR Clutch Comaptibilty Question ???? Help Me Out ?
  66. JDM fog light and high beam wiring instructions.
  67. Airbag blocker tray Part number
  68. Are any R owners putting there R in ..............
  69. Top speed TRANNY vs AutoX TRANNY
  70. Topspeed record of ITR
  71. Isnt the rev limiter suppose to save you from miss-shifting damage?
  72. Jun 2
  73. Springs that lower an R 0.75" to 1.00" Inch?
  74. OT: got an '03 TL Type-S for the wife...
  75. Carsound Cat Group Buy - OT
  76. Waxing the R?
  77. URGENT! ITR Door wind deflectors from Europe??
  78. 195/50 or 205/50 on Stock 15/6 wheels??????
  79. OT: Check these news out...
  80. Compliments Behind My Back
  81. NSX calipers?
  82. Did it come with BUSHINGS?
  83. what is the flow rate ITR fuel pump?
  84. special question about speed sensor!
  85. Mud guards...
  86. i love my car but this is stupid...
  87. Carsound Cat????
  88. old Apex AFC question....
  89. Theory on belt snappage using high-lift cams
  90. Differences between USDM & JDM ITR TB's ? ? ?
  91. is this anyone here? take a look
  92. myrtle beach
  93. How much would it be to buy individual ITR gears?
  94. need help from someone in the ANNAPOLIS area asap!
  95. Anyone selling... JDM....
  96. Aftermarket wheels with acorn lug nut seat?
  97. HELP!! someone hit the front of my car......
  98. Running temp of built HC NA motor - EGT gauge installed
  99. How do I check my tranny fluid?
  100. Here is my bad dyno and bad run, but it will get better again
  101. Rota rims..stock acorn lugs ok?
  102. OT: 4th of July Fun + :FIRE:
  103. OMP 6-point bolt in cage for the Type R (pics)
  104. anyone have side exiting exhaust for the track?
  105. Identifing the b18c? calling all JDM experts
  106. Is the USDM ITR available in 4 door?
  107. Pulley question
  108. is it possible i can find...
  109. need pic of pillar bar installed
  110. Shift Boot
  111. learning how to post pics
  112. What does everyone do to prevent oil from leaking out of the cam seals?
  113. Are b series axle seals interchangable?( the ones that press into the tranny)
  114. Advanced Ign. timing? few questions
  115. WTB: ITR Stock Spring will pay or trade with my RSR Race Spec Spring
  116. check out this 4dr integra with 4dr type-r everthing but the front end
  117. Is it better to sell a Type R fully modded or in a somewhat stock form
  118. Sounds like im taking a chain saw to my motor coming out of first
  119. buying cold air intake
  120. Overheating...could I have blown my head gasket?
  121. Looking for websites that talk about suspension tuning.
  122. double clutching
  123. New brake products from Mugen
  124. :o Is this someone here?
  125. ITR with tow-hitch....pic request.
  126. JDM header vs USDM header
  127. anyone is selling there used ITR cams?
  128. Pics of my daily driver
  129. Just did a couple of pulls on the dyno....
  130. market price on mint type r front seats?
  131. OT: We-Todd-Did-Racing.com gets an upgrade :) and some stats
  132. Re: Does anyone know the part number for a rear ITR sway bar?
  133. What are the best cams to use with oversized valves?
  134. Q? to all the Wingless R's
  135. Cryogenically freezing brake rotors?
  136. Putting car on dyno right now, need gear ratios please...
  137. need close up pic...
  138. 2 Brand new Azenis 205/50/15
  139. USDM Rad support...
  140. Running open header on the street.
  141. Is there an X-Pel bra avalible for the Type-R
  142. whp who has seen the most
  143. Aussie type R dyno.
  144. DYNO: Spoon 4-2-1 Header, 2.5" Carsound Cat, Mugen Twinloop Catback
  145. is there anything special about the 98 type R?
  146. 98 itr with 16" itr wheels spotted
  147. REAL JDM Red Suede Seats
  148. Anyone can post a 12-sec. n/a setup for an ITR.?
  149. Fuel Injector flow rate question
  150. pics pliz
  151. New ITRsport Server Test! Please View - Many Pics
  152. $2 brake/clutch cap socks...
  153. ot: who has sparco hood pins (red) in stock right now?
  154. whats up with the randdmotorsports web page
  155. How do i put pics on this site?
  156. 1985 Porsche 944 Turbo
  157. taillamp question
  158. Milano Red ITR for sale!
  159. So what tires to get next?
  160. 98 itr tranny different from 00 itr tranny
  161. Buying in Japan?
  162. Damn, the one time I don't show up to an AutoX...
  163. can a 4-2-1 header out perform a 2.5" 4-1 header
  164. Show me CW R with...
  165. Any of you guys using the Hondata Gasket?
  166. FS... 7 Nine spoke Millenia rims, four with slightly used Falken Azenis tires.
  167. Who has an ITR for sale?
  168. PY ITR @ Sierra Acura in Alhambra...
  169. Cat O2 sensor...can it be bent?
  170. miss shift
  171. Reason not to sell your ITR????
  172. Feedback on LHT MC braces?
  173. PY SGT ITR Sighting...
  174. Spoon 4-2-1 (2piece) question
  175. what oil pump to get?
  176. Will the stock ITR header fit an Integra RS?
  177. stock piston size
  178. Project Mu brake pad?
  179. BF G. Drag Radials/Nitto 555's/Falken Azenis
  180. Interesting, Yet Educational Thread in Road Racing Forum
  181. For Everyone Who Sold Their Stock ITR Exhaust
  182. Maint Reqd Light
  183. need pics with reservoir covers
  184. Aqua blue
  185. Anyone know the paint code for gunmetal TE-37's?
  186. SoCal: Sparco Dealer ? ?
  187. Anyone has experience with Dunlop FM901?
  188. I made a shirt!
  189. Where to buy: Porterfield pads?
  190. weres the place to buy a roll cage?
  191. Would someone do me a favor?
  192. OT: Where's the best place to buy stock rotors and pads?
  193. Type-R muffler - different part number for '97 and '98+ ???
  194. What kind of gains can I expect?
  195. Falken Azenis...
  196. OMG! Tested 18" vs 17" rims GMETER!
  197. Weird Noise from Tranny
  198. buddy club ecu or chipped p28?
  199. Tires for track events
  200. APEXI N1 question??
  201. Long Island Meet!!!!!! Whos Down
  202. Type R gearbox
  203. Is it safe to advance the ignition timing??
  204. Accord Type R discontinued in the Euro market for 2003
  205. Good news, got the Wiseco pistons and the Eagle rods.
  206. Help from someone who can check a part number?
  207. Can I use my spoon air filter on an comptech icebox??
  208. Weekend Road America pics
  209. Anyone in the market for a Yellow ITR??
  210. Anyone have prelude rims on their itr??
  211. Newly redesigned website
  212. will disconnecting battery reset the VAFC?
  213. How hard is to change the clutch on 4 jack-stand.....
  214. jdm itr in my 89 si hatch?
  215. NEW JDM PARTS PERFORMANCE SHOP in TORONTO !! Authorized Spoon Distributer!!
  216. Unplugged my vafc and turned on car wtf?????
  217. what kind of recaros are these?
  218. lube for rear sway bar???
  219. AVS-i or Azenis for daily driving?
  220. Owners of European ITR, come here !!!
  221. Just got my Azenis' put on this weekend
  222. what would be the best suspension for an itr ???????
  223. Gopt a little squeak in the brakes...
  224. Summer Slam this weekend
  225. R-compound shelf life?
  226. For those with cam gears installed.
  227. Never thought i would see this....
  228. Edmund Review....
  229. ECU = 10hp?
  230. HP gain ?
  231. Hmm...USDM spoon ITR
  232. Damn car jackers....
  233. Toda A Cams???
  234. Rear shocks-busted?...
  235. www.ogracing.com....wtf?
  236. ATTN: Motherf*cker in schaumburg at blockbuster @11:40pm.
  237. Running V-AFC n/a
  238. something happen to my R
  239. thanks to AutoX experience!
  240. anybody need sparco rails n sliders?
  241. Black ITR with 17" Volk GTN's
  242. Check out this short video, and sound of my crazy loud exhaust.
  243. which head package....
  244. Question about valve adjustment procedure
  245. Just posting a pic for the first time. Do you see one?
  246. My review of driving without a powersteering belt
  247. My Realtime,Roadamerica thumbnails **56K friendly**
  248. Stock Exhaust and Header for sale
  249. Rear suspension uneven?????
  250. Any of you at Englishtown today?
