rear diffuser
Old Jan 8, 2010 | 08:45 AM
feriotypeR's Avatar
Default rear diffuser
can i fabricate a s2000 rear diffuser to fit a 99 civic coupe?
Old Jan 8, 2010 | 10:15 AM
lsef's Avatar
Default Re: rear diffuser
you tell us.....
Old Jan 9, 2010 | 02:35 AM
feriotypeR's Avatar
ok, i'll tell u after some1 else tells me, dont reply if ur not gonna answer the question
Old Jan 9, 2010 | 04:14 AM
-RedneckDave-'s Avatar
Working
His response was as useful as your question. What diffuser? What do you know about fabrication? Can you actually do it? That is a question you have to answer yourself. Also leave the attitude at the door when you come in here. It will help you in the future.
Old Jan 9, 2010 | 07:09 AM
DESTROYER's Avatar
The point is, the diffuser is just a piece of plastic or fiberglass; how you affix it to your chassis is up to you. There isn't exactly a right or wrong way to make it work (in a fabricator's rhetorical sense) just make sure that it can still function as originally intended.
Where do I go for aero tech?
http://www.mulsannescorner.com/
Old Jan 9, 2010 | 07:57 AM
dumpster's Avatar
another post without a answer
Old Jan 9, 2010 | 10:34 AM
Bakeoff's Avatar
Exactly what these guys said. Its like you just asked if you could turn a metal bowl into a strainer. Sure. Its possible. Can YOU do it? If you're asking, it means you're second guessing yourself and the project may be over your head to begin with. It would take having the piece in your hands and seeing if things fit correctly on the chassis, and how much modification it would take to get it mounted.
Old Jan 9, 2010 | 10:35 AM
feriotypeR's Avatar
thank u destroyer, only 1 who kept on topic, i see u got an A in english class, and i dont have an attitude, if u just keep on the topic, everything will run smooth
Old Jan 9, 2010 | 10:43 AM
chaoscube's Avatar
This is the Spoon S2000 rear diffuser...fitted on a 96-00 Hatchback.
Old Jan 9, 2010 | 10:47 AM
madblkscientist's Avatar
can a s2000 style rear diffuser be fabricated to fit a 99 civic coupe?
probably can b(answer)
then everthing every1 else said comes into play
it will b hard but it will look kickazz if done right
will u b attempting it on ur own? or r u gonna send da work out?
what about gettin a 1 off piece made pacifically for ur car from onr of these guys that fab carbon fiber pieces from molds
Old Jan 9, 2010 | 01:02 PM
c jackson's Avatar
threes
no.
Old Jan 9, 2010 | 03:06 PM
anything can b done with time and money
even more money with no experience
Old Jan 9, 2010 | 05:48 PM
Bailhatch's Avatar
Fabricate means that you actually build it from raw materials. Taking a pre-made part and modifying it to fit something else is hardly fabrication.
As far as making whatever difuser you have in mind fit...if you have to ask. No.
Old Jan 12, 2010 | 04:17 PM
140sx's Avatar
just sell me the diffuser lol, save u some time
Old Jan 12, 2010 | 04:41 PM
Top Ramen's Avatar
I wonder if that english [sic] class covered the concept of irony.
agentorange11
Oct 24, 2011 11:49 AM
Shaun
Suspension & Brakes
Mar 30, 2005 11:48 AM
99civic99
Audio / Security / Video
Dec 7, 2004 07:58 AM
RustyRex
May 10, 2003 06:09 PM
