welding 'booth'?
Old Feb 28, 2010 | 12:30 PM
russianvr4's Avatar
OG Fabricator
Default welding 'booth'?
has anyone ever done something like this?
a sealed room thats filled with argon for welding whatever metals(mostly exotic stuff).
any advantages/disadvantages to this?
argon doesnt have any effect on skin does it? so wearing a mask with oxygen would suffice right?
Old Feb 28, 2010 | 01:24 PM
project dc2's Avatar
Default Re: welding 'booth'?
you sure you want to run a BOOTH ? thats a LOT of argon and in most cases not needed. you could do a BOX filled with argon if you please.
Old Feb 28, 2010 | 01:31 PM
SD_Lurker's Avatar
HT White Ops
arczone sells a small enclosed unit but its freakin pricey. You slide your hands inside of it and weld.. Your actual body doesn't fit inside of it but like he stated above that's a **** load of argon..
Old Feb 28, 2010 | 01:36 PM
each time you weld itll probably be 200+
Old Feb 28, 2010 | 02:46 PM
JDMCRX's Avatar
wow that would be uber exspensive.
Old Feb 28, 2010 | 05:28 PM
9bells's Avatar
OG Fabricator
Biggest disadvantage is heat. Argon is a terrible conductor, so everything gets really hot, including you. It's even a PITA when using a purge chamber, couldn't imagine a room!!!
Nevermind the huge cost, and inherent leaking of a wooden structure.
funvtec
Welding / Fabrication
19
Jun 17, 2005 01:44 PM
qksl2
Mar 11, 2005 10:21 PM
baonest
Jan 17, 2005 08:08 AM
