Rotors
Old Feb 28, 2010 | 02:38 PM
jonnyt1130's Avatar
Default Rotors
Just out of curiousity has anyone ever made a program to drill and slot their rotors on their own? I always thought about it when I'm using the CNC mill. I just thought of buying basic rotors, drill and slot them on the CNC machine, then use a brake lathe the make the surface smooth of burrs again. Just a thought fill me in on your thoughts, and if anyone else has tried it.
Old Feb 28, 2010 | 05:25 PM
Jenkinsal2's Avatar
Default Re: Rotors
If you have the tooling and experience I don't see why this would be a problem. There are a good number of arguments over slotted/drilled/blank and what is best though. I personally just prefer blanks. Cheap and easy to change out when they should be changed.
Old Feb 28, 2010 | 06:22 PM
93supercoupe's Avatar
Default Re: Rotors
ive found that drilled makes them too thin and warp real easy
kornerk12
Apr 24, 2006 10:09 PM
Bbasso
Jul 31, 2004 06:49 AM
tmekjian
May 10, 2003 04:04 PM
Sephro
Dec 31, 2002 07:31 AM
98_Accd
May 27, 2002 10:55 AM
