Recomendations for a bead blaster??
Im looking for one just to do random parts like valve covers wheels etc. Is any of the harbor freight ones any good? If some one can post a link of a decent one I would appreciate it
thanks
thanks
http://www.harborfreight.com/cpi/cta...emnumber=30979
I have that one. I used it to clean a rusty axle, and it worked perfectly. It's very cheap and works pretty good, but it uses more air than HF claims and it makes a huge mess out of your space. Make sure you cover up well and use it outside.
One very important thing is the type of media you use. Most media cause serious health problems, including cancer. Use a good respirator; a dust mask is not enough! I use play sand in my blaster. It's very cheap and works great, but it contains silica which causes cancer. Like I said, use it outside with a good respirator to avoid health complications.
Good luck!
Good luck!
http://www.harborfreight.com/cpi/cta...emnumber=93608
http://www.harborfreight.com/cpi/cta...emnumber=42202
What kind of air compressors do you guys use? I'm looking to get the 40lb standing cabinet for my dad and his air compressor definitely needs to be replaced. I assume a $150-200 compressors are typically inefficient/ineffective.
Get a compressor with the right volume (CFM) not just the right pressure. If you are going to run a media blasting cabinet, it is critical you move enough air. Many medium sized compressors are fine for small air tools but can't move enough air to properly run a blasting cabinet. It doesn't have to be huge, 15-20 CFM for a medium cabinet and 6-10 CFM for the small ones. Obviously, if you only use it intermittently, you can get by with a smaller compressor.
Good luck!
Good luck!
I have two different HF media blasting cabinets and I am happy with both of them. I recommend calk or some other sealant on the seams of the smaller one if you are going to use a fine media. It needs no additional work with standard abrasives.
Walnut shell is too fine to remove rust and paint effectively. Most of the low grit media are going to be toxic one way or another. I used play sand because it was $4 for 50 lbs. You'll be fine as long as you're using a sealed cabinet or are doing it outside with a good respirator.
I have used some walnut blasting media before. It does work well and it is supposed to be more gentle on the parts being blasted. I know some restoration shops use walnut media on classic car chassis's.
96supercharged
Welding / Fabrication
36
Jan 23, 2008 02:17 PM
TurbothisLS
Aug 25, 2002 05:46 PM
