Mandrel Bend?
Old Jan 18, 2010 | 06:39 AM
Jenkinsal2's Avatar
Default Mandrel Bend?
I am looking for a bend and having a really difficult time finding the size I need to make a CAI. I would prefer to use something afordable material wise as this is a budget solution. I need a 2.5OD 180* bend on a 5" radius. The problem is finding the leg length of at least 18 inches. If anybody has any ideas where i could get this bend it would be much appreciated. I already tried most of the places in the materials sticky and google to no avail.
Old Jan 18, 2010 | 12:58 PM
Bakeoff's Avatar
Default Re: Mandrel Bend?
And you can't weld another tube to the bends you CAN find?
Old Jan 18, 2010 | 03:48 PM
yellowrocco87's Avatar
assuming you want aluminum tubing? i would say i could do it but my machine bends 2.5 on a 3.75 centerline radius. and i do not currently bend aluminum in house.
have you tried Woolf aircraft?
Old Jan 18, 2010 | 04:58 PM
Jenkinsal2's Avatar
I could easily do this but If I do It wont look as clean as all I have right now is a MIG. I am planning on simply cutting the sections i need out of the Ubend and using couplers and clamps I have already so it will look a bit nicer.
Old Jan 18, 2010 | 07:22 PM
nowtype's Avatar
Contact: http://www.mandrel-bends.com/catalog/mandrel-bends-34/
They will be able to do something for you.
Old Jan 20, 2010 | 01:03 PM
Bakeoff's Avatar
You could cut and mark everything and have a local shop tig it easily enough.
Old Jan 20, 2010 | 01:30 PM
Jenkinsal2's Avatar
at a min of 65 dollars an hour that would be a bit more then I planned on spending for the entire project.
ANTI_LAG
Welding / Fabrication
17
May 24, 2012 12:54 PM
champLSinteg
16
Aug 18, 2009 03:45 PM
Running925
May 26, 2006 08:43 AM
MatHadder
24
Feb 11, 2006 04:22 PM
Briman2021
Feb 24, 2004 07:09 PM
