need some feedback
Old Apr 1, 2010 | 08:00 PM
mikesrex's Avatar
Default need some feedback
I was having problems welding something and decided to test it on this piece of metal before going back to my project. The bead on the edge had some problems, and I changed out my gas lense and tungsten before trying to run the other beads. I think the tungsten got polluted while welding earlier. I figured I would take a pic to see what kind of feedback I could get to improve my welding. I decided to pick up a welding machine and learn how to weld as a hobby after finishing up my bachelor degree. So far the welds I have done are I guess decent but nothing like the good stuff I see here.
I am using a Syncrowave 180SD and the current was around 105ish amps when welding this flat bar. I think it was about 3/16 or 1/4" thick. I was using 3/32 mild steel filler metal and I believe the tungsten was the same diameter.
here is my pic. I put a wire wheel to the flat bar after welding to be able to get a decent pic.
Old Apr 4, 2010 | 03:15 PM
mikesrex's Avatar
Default Re: need some feedback
anyone?
Old Apr 4, 2010 | 04:13 PM
CSaddict's Avatar
I had an issue that was similar and it turned out to be contaminated argon.
Old Apr 10, 2010 | 01:25 AM
rolledteg94's Avatar
I would for sure try changing out your nozzle cup that might help too... or try different size filler rod...
Tbone
13
Jun 26, 2005 04:32 PM
GettaluvR
Oct 22, 2002 10:04 PM
DJHan
Jul 10, 2002 12:20 PM
jonsteR
Jun 20, 2002 08:32 PM
R0476
May 1, 2002 09:35 PM
