A very non Honda header/build up
Old 01-04-2010, 03:40 PM
BMCRace's Avatar
Default A very non Honda header/build up
and exhaust.....
This is my personal car, well I haven't driven it in 2 years now but it is still my car
I am finally getting some time to work on it again so here it is
1971 Datsun 240z with Chevy 350 sbc swap (mounts made by me)
I had just finished off the drivers side header and side pipe and will be starting on the passenger side hopefully this weekend. Don't worry about the hack job on the wheel wail the car will be getting fully caged soon and we will cage the engine bay a bit to reinforce the suspension and just overall help counteract 39 years of rust.
Well enough talk here are the pics
The headers and complete sidepipe exhaust will be ceramic coated by Polydyn here in Houston
Aldo from 1320 Racing Houston Tx will be the mastermind behind the roll cage of the car as he and I have been good friends for quite some time now.
I don't expect the car to be done anytime soon however I will update this thread as progress is made on the car. I am hoping to have the car painted and drivable by my birthday (Nov 27th) of this year as I haven't driven a car faster than a 15 second for close to 4 years now
The header is a 34" long primary with 1.75" runners. All runners are equal within 2" of each other. Yes it does clear the tires just fine however when I swap over to a wider tire in the front (car is being built for road racing) I will have to put on some steering stops. Also I will build a very nice heat shield to both protect the tires from too much heat as well as protect the header from flying rocks/mud/debris...
-James
Old 01-04-2010, 04:17 PM
OG Fabricator
weiRtech's Avatar
Default Re: A very non Honda header/build up
i don't see any joints anywhere... how do you get that sucker in and out?
Old 01-04-2010, 04:29 PM
RC000E's Avatar
That's saying it's not equal length. Within 1/4" is one thing, within 2" isn't really worth mentioning.
I'm not feeling the sidepipes on that car, though I know styling of that car was modeled and influenced by Corvette, so maybe on the finished car I'd feel different. A lot of work there for sure.
Old 01-04-2010, 05:04 PM
d16sandrail's Avatar
Looks like aluminized header tubing? that stuff is a B%tch to weld! looks good considering...nice work, should be a fun car when finished.
Old 01-04-2010, 05:11 PM
Jared's Avatar
Will it still turn lock to lock without a ridiculous wheel offset?
Old 01-04-2010, 05:44 PM
BMCRace's Avatar
The header is 1 piece and it does come in and out through that hole.
The final install will be done with me having taken out the suspension because it is major tight and would scratch it up if I dont do that for the future.
Yeah I am cheap when it comes to my own stuff and projects lol. I will rock the cheapest bends I can get from summit (those aluminized bends are 10$ each there) and the formed collectors I had laying around from some other shop going to throw them away long ago.
All things considering I would consider 2" very equal for the amount of room I had been given to work with.
I had liked the way this guy did his Z
The car has the Bre kicktail spoiler on the rear which was molded into the body and cut so that the outer pieces would remain in place while the rest of the spoiler came up when the trunk is opened. It looks like it was factory on the car now...
I have the same front end as this one
and even the Bre fender flares. Those will be installed last after I have the wheels and tires for the car so that the flares can be spaced out if needed to cover the big beefy tires (going to run a 255/50/16 in front and 305/50/15 in the rear) The wheels of choice are diamond racing steel wheels stock car series. Will be a 16/8 in front and 15/10 in rear
Next years project (if all goes well this year) will be to put a dana 36 rear end in the car (late 80's corvette). I prefer it due to the nice low auto gearing as well as it is all aluminum including the axles so it will be very easy to shorten and modify to fit, last but not least at $1250 shipped for a complete rear subframe with brakes it is a good price for what you get
Old 01-04-2010, 05:49 PM
BMCRace's Avatar
At the moment it will turn all the way, the wheels on it though are the very old school original Western wheels ( 0 offset ) and the tires are only about 8" sidewall to sidewall.
When I change to a much larger wheel tire combo it will need to have some added offset to help clear the header as well as even some steering stops..
Old 01-04-2010, 06:01 PM
RC000E's Avatar
Oh man, I remember this car from a mag feature. I LOVE that car...so sick.
Old 01-05-2010, 06:02 AM
OG Fabricator
weiRtech's Avatar
i'd think equal length doesn't necassarily always mean equal flow anyway.
Old 01-05-2010, 11:38 AM
RC000E's Avatar
Well, equal length is more about resonant scavenging making power at a target rpm window to match a cam design or build purpose. For true potential lengths must be within about 1/4" maximum. From there you lose the potential to scavenge all cylinders equally at given rpms. Within 2" is certainly better than within 10", but 1/4" is a whole lot better than 2".
My point was, that were it the intention to create a true equal length system, then I'd call 2" a failure. Were it built to best fit the application and logistics, while attempting to maintain as equal a length as possible, then I'd say its a good result.
Now, my question is, how was this 2" determined? Length should be determined by measuring short radius centerline lengths. Generally you'd measure each section as you build the header, then write the length on the piece as you build it, allowing calculation at the end.
Either way, this is looking far deeper than necessary. It fits, it's clean, the steering works...done.
Old 01-05-2010, 12:14 PM
Timmah!!'s Avatar
Should have built a set of 180* headers Nice long read about em on hybridz.
VtecKiDD
89
04-03-2009 08:10 AM
JG-Fabrications
Welding / Fabrication
49
01-30-2008 12:43 PM
onefstek
11
12-13-2006 06:51 AM
itr1244
11
04-17-2006 01:47 PM
itrdriver1071
12-09-2005 08:07 PM
Quick Reply: A very non Honda header/build up
