H2B Low Profile Valve Cover
Gauging interest in how many H2B'ers are interested in a low profile valve cover.
I know some of the newer kits dont require hood the hood to be spaced higher...But mine does, a few other I have built or help build do, and I know I have seen several others that need it.
Thus far, I am in the process of modifying a stock unit to gain the clearance required to eliminate the need for hood spacers (cutting the webbing may still be necessary). I am wondering what, if any, interest there is in this kind of part?
All my preliminary cuts have been made and pics will follow as to how much clearance should be gained.
Is there any specific requests for further modifications?? (pcv, location of oil fill, etc)
Thanks for your time and all POSITIVE input will be greatly appreciated!
Re: H2B Low Profile Valve Cover
I am currently in the process of doing the same thing for a customer, its a lot of work...if its done correctly. I don't know what you are charging for it, but I hope you didn't under cut yourself. I'm thinking now I may as well have just built him a complete new valve cover similar to the B-Series Moroso. Fun, fun, fun :-)
I'm really 2slow
I'm really 2slow
I have more pics in my flash drive that I will upload later.
and a guy in NorCal was talking about doing something like this but never came through.
Took a similar route...
Initial Cutting:
Template for coverplate:
Final squaring and finesse:
Template set in place to show idea of finished product:
And just for fun:
Initial Cutting:
And just for fun:
1st cuts were with an air cutoff wheel...Waste of time.
2nd was with an Electric Grinder w/cutoff wheel...MUCH fast but slightly less controll.
Finished with table belt sander to square and smooth.
Already working on another method... Large bandsaw w/custom jig/feed.
Alum sheet came in today...so templates should turn into actual coverplates tonite/tomorrow...
I'll keep posted as soon as I get more.
awww....I am cutting mine (customers) with the milling machine, and milling down the excess material needed to lower the height of the cover...then welding back together. I still think at some point I may make a cover from scratch for one of my duece-dueces.
im interested in a valve cover to shut my dad up. he wont stop complaining about my hood sticking up and says it looks stupid.
also will this make enough room so we wont need the hood spacers?
I have an extra VC and have been contemplating on doing this for a while, would like to see this when it's done! Makes me want to do mine
The band saw is for sure the better idea...
Still aquiring the large tools to make better turn around time.
On a similar note, my Tig guy fell thru... 1 delay after another. LOL
Still trying to get at least 1 finished by Saturday.
heres the one I am working on, need to hot tank and bead blast it before I do anymore welding on it...it is uber contaminated, never had any valve cover weld this bad :-(
Also, 90% of valve covers i've welded are a really low grade of alloy, mostly bottom of the bucket stuff that's high magnesium content
I too have done a couple of these...I mill the top down and weld a flat sheet of aluminum on the top and a new low profile oil fill cap. Here are a couple pix of one I'm working on now. I'm also curious as to what others are charging?
