Transmission & Drivetrain Gearboxes, Differentials, Clutches
help!
Old Aug 15, 2008 | 07:53 PM
ED9man's Avatar
Default help!
I am in the process of reassembling my 93 GSR transmission after replacing the entire third gear set. The mainshaft binds using the original shim from the case. I want to measure the clearances so I can order the right sized one however I do not understand how I am supposed to measure the "A" clearance as seen below. With the case together how are you supposed to get in there and measure that clearance?! I had no problem finding the "B" clearance. I have rechecked my mainshaft assembly and I do not think it is the problem. Please help this is driving me nuts!
Old Aug 16, 2008 | 05:55 AM
blkb18's Avatar
Default Re: help! (ED9man)
you could try plastiguage
Old Aug 16, 2008 | 06:06 AM
ED9man's Avatar
how does that work? Also I think this clearance is going to be a lot bigger than you find in engine bearings.
Old Aug 16, 2008 | 06:12 AM
blkb18's Avatar
Default Re: (ED9man)
Plastiguage is a really thin piece of plastic, any parts store has it, make sure you buy the one that will cover your clearance needs. (they have different thicknesses). You will cut your self a small piece and put it where the book tells you to measure the clearance. Then assemble the case (dont bother with the hondabond). Disassemble and inspect the plastiquage, it will be smashed down. Compare the width of the smashed plastiguage with the chart on the plastiguage package. It will tell you your clearance.
Old Aug 16, 2008 | 08:33 AM
ED9man's Avatar
ok i figured out how to measure it but I am coming up with the mainshaft being higher than the edges of the case. I installed it without the thrust shim and oil guide plate. It is supposed to be fully assembled right? I also did not have the spring washer on it but I did have the 28mm thrust washer.
Old Aug 16, 2008 | 03:15 PM
ED9man's Avatar
anyone?
Old Aug 16, 2008 | 07:28 PM
eda6's Avatar
IMO mainshaft thrust clearance shouldn't have changed after replacement of 3rd gear.
when the case was together, did you hear the c clip on the countershaft snap into place?
did you tap the mainshaft towards the outboard side of the tranny housing making sure the bearing was fully seated against the thrust shim?
when checking clearance "A".... you've removed the hex head plug on the case and made sure the bearing is fully seated?
Old Aug 16, 2008 | 10:03 PM
ED9man's Avatar
yes all of the above
the mainshaft still binds when in the case alone when I put the halves together.
Old Aug 17, 2008 | 07:06 AM
ED9man's Avatar
no one has ever had this problem?
Old Aug 17, 2008 | 07:23 PM
ED9man's Avatar
Does anyone know if the spacer coller that goes on 4th gear is supposed to have a certain orientation? It looks the same either way.
jdmdc2yadigg
Apr 22, 2010 10:52 AM
IntegraKid_88
Mar 21, 2010 08:50 AM
kcokla
Jun 1, 2009 08:21 PM
Smallpox33
May 2, 2007 06:35 PM
vtec25
Feb 25, 2006 04:45 AM
