Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is there something wrong with my diff ?
Old Aug 11, 2008 | 03:40 PM
EdSiXxXrR's Avatar
Default Is there something wrong with my diff ?
hey whats up, i have a 91 ed6 with a jspec 97 itr in it. for axels im using integra da ones and also the intermediate shaft as well. at first my problem was the passenger side axel kept popping out from the tranny, no matter how many times i replaced it the same thing happened. finally i replaced for the 3rd time and after i was done from getting the car of the jacks i tried pushing the car backwards a little to clean up the mess and the tranny just locked itself. the car wouldnt go forward or reverse. i tried pushing it again and finally it moved. i drove around the block and it felt like crap,as if the car wanted to lock again. so yea any help would be appreciated it. sorry for the long paragraph.
p.s. a couple days before replacing the axel the gears felt rough going in.
Old Aug 12, 2008 | 03:15 PM
LastGenEK's Avatar
Default Re: Is there something wrong with my diff ? (EdSiXxXrR)
Ijust last night swapped out my old tranny that was doing the exact same thing... i would be driving and then the axle would just pop out
I never figured out the problem i ended up ordering a 2000 integra r tranny from acura
The only thing i came up with is the diff was stretched and wouldnt
hold the axle in tight
Old Aug 12, 2008 | 03:34 PM
EdSiXxXrR's Avatar
Default Re: Is there something wrong with my diff ? (LastGenEK)
yea i dont know bro i cant figure it out. ANYBODY ELSE HAVE ANY INPUT ?
Old Aug 13, 2008 | 05:24 AM
cpl rampage's Avatar
did you install it with a new clip ring, and make sure that the old clip ring didnt stay in the tranny?
Old Aug 25, 2008 | 11:02 AM
EdSiXxXrR's Avatar
Default Re: Is there something wrong with my diff ? (cpl rampage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpl rampage &raquo;</TD></TR><TR><TD CLASS="quote">did you install it with a new clip ring, and make sure that the old clip ring didnt stay in the tranny?</TD></TR></TABLE>
i checked all that bro and everything was cool, i just ended up swapping the tranny out for now. ill take apart the other one and figure it out later. thanx for the input.
Old Aug 25, 2008 | 03:46 PM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdSiXxXrR &raquo;</TD></TR><TR><TD CLASS="quote">
i checked all that bro and everything was cool, i just ended up swapping the tranny out for now. ill take apart the other one and figure it out later. thanx for the input. </TD></TR></TABLE>
Thats what id did too, I think our diffs are steched and not holding the axle tight cause when my axle was installed i could move the axle up and down with it in the tranny no good good luck
Old Sep 3, 2008 | 02:17 AM
BlazinSlowHonda's Avatar
Dunno had tha same prob on a 93 Integra B16 / S1 setup... Turned out ta be bad suspenssion geometry ! Too low, Turn it ta lock, or hit a bump just right an pop out it came!
2Nyce
Mar 19, 2011 11:06 PM
EdSiXxXrR
Aug 25, 2008 11:00 AM
blueb18c
Jan 5, 2006 12:57 PM
90AcuraIntegra04
Apr 4, 2005 02:54 PM
josh green
Aug 3, 2004 07:51 PM
