Transmission & Drivetrain Gearboxes, Differentials, Clutches
cable tranny help
Old Nov 4, 2008 | 03:06 PM
rexfan's Avatar
Default cable tranny help
ok, so I have a 99 b16 mated with a 91 b16 cable tranny, i think its the ys1. there are a few problems with it. first, it grinds on 3rd, and I took it to a shop and the told me that it WAS the tranny messed up and not the linkage or anything else. It doesn't down shift to 2nd and it grinds when I put it in reverse. I was going to fix it and put an ls 5th, but oh yea and when I go to first gear and actually drive, it makes a whistling noise when i let go of the clutch. so should i fix it or just get another tranny with new linkage and clutch?
thanks.
Old Nov 4, 2008 | 04:39 PM
Mindgamez's Avatar
Default Re: cable tranny help (rexfan)
First you need to open it up and see how much money you'll need to spend to fix it. From the sound of it You need a new 5th Gear Syncro, as for the whistling noise i have no idea what that is. If it grinds 3rd its also probally your 3rd gear syncro and maybee the gear. All the Trans that i get that are used i open them up to see what is wrong with them and they always need new bearings... Like i said you have to open it up and find out. Your linkage shouldnt be the probelm but you could try a diffrent one and if it works itll save you some money.
7rrivera7
Apr 22, 2013 12:39 PM
88HATCH(:
Oct 20, 2011 10:40 AM
01_em2
Sep 30, 2010 02:37 PM
teler86
Feb 15, 2006 09:21 AM
bob06
Jul 6, 2005 10:34 PM
