Transmission & Drivetrain Gearboxes, Differentials, Clutches
Final Drive/LSD install
Old Nov 19, 2008 | 08:16 AM
kornerk12's Avatar
Default Final Drive/LSD install
I have a few questions dealing with this install. First off, is it nessessary to check the preload ? In the Evans Tuning article on YouTube i believe he does not check it, or he said that most trannys he has done dont need to be shimmed. Secondly what else should you check ?
Also dont gears create a wear pattern and by swapping in a new ring gear wouldnt that mess with this ?
Old Nov 19, 2008 | 08:51 AM
gunnerman's Avatar
you should recheck the shim just in case if you dont and you're clearance is too tight something will in the tranny eventually
Old Nov 19, 2008 | 12:02 PM
Mista Bone's Avatar
D Tranny Guru
H22 uses tapered bearings, PRELOAD Must be checked or you will destroy the bearings very quickly. Likely in the Evans tech tip the tranny was using the more common caged ball bearings.
Old Nov 19, 2008 | 12:35 PM
kornerk12's Avatar
nope it was taper roller. Also what about the wear pattern on the teeth ?
Old Nov 19, 2008 | 11:21 PM
Mista Bone's Avatar
D Tranny Guru
wear pattern??????
That is only a worry on hypoid gears like in RWD cars.
Old Nov 20, 2008 | 10:29 AM
kornerk12's Avatar
it still uses a ring and pinion, why wouldnt it wear ?
Old Nov 20, 2008 | 12:13 PM
Mista Bone's Avatar
D Tranny Guru
Not a hypoid design, where pinion depth and contact pattern is critical.
Go research it.
Old Nov 20, 2008 | 06:55 PM
Evs-One's Avatar
Solbros Owns Me
On top of that, final drives replaces both the ring and the pinion....new parts for each, so wear is not an issue anyway.
boostedb20ek
Jul 21, 2009 06:28 PM
Crakadic
May 9, 2008 11:05 PM
dnatrance
Jan 24, 2005 02:10 PM
au-gsr
Dec 27, 2002 10:49 AM
krbobcat
Dec 20, 2002 05:16 PM
