Transmission & Drivetrain Gearboxes, Differentials, Clutches
Grinding/clutch problem
Old Dec 9, 2008 | 03:46 PM
sipolt89's Avatar
Default Grinding/clutch problem
alright so today i was leaving college and my clutch was to the floor. i put fluid in,drove it and 2nd gear grinds now. i figured maybe it was cause it needed to be blead so i did that,still grinding. my trans did grind at 7500 rpms or higher before in 3rd and 5th,but iduno why second is doing it now. also my fluid seems to keep getting lower,im guess that can be the master cylinder but my question is can this be causing the grind? the clutch still does feel strong like it has pressure build up? btw. gsr motor b16 trans in eg hatch. thanks
Old Dec 9, 2008 | 06:10 PM
FerreiraCompetitions's Avatar
Could be the syncros going. Rebuild should be on the to do list.
Old Dec 9, 2008 | 07:59 PM
sipolt89's Avatar
yea i know i was just wondering if that could be the possibility,i was driving today and my clutch keeps losind pressure.i really really hope its not the syncros
Old Dec 9, 2008 | 09:03 PM
Evs-One's Avatar
Solbros Owns Me
If your hydraulics are leaking you are not getting full disengagement, which can definitely cause a grind.
Take care of the leaking slave and/or master, bleed the system, and see where you're at.
Old Dec 10, 2008 | 12:59 PM
sipolt89's Avatar
it looks like there is a leak on the resevoir,how can i fix this?because i know i am losing some pressure which im hoping is causing that grind.
Old Dec 10, 2008 | 04:13 PM
Evs-One's Avatar
Solbros Owns Me
the actual reservoir is leaking? There's no reason for that to leak, unless it was hit. Possible the line from the res to the master.
Whatever is leaking, replace.
Christian_Chand
Jan 4, 2012 07:15 AM
sipolt89
Dec 10, 2008 02:34 PM
hpimichael02
Oct 31, 2008 09:46 AM
civicandr6
Mar 16, 2007 07:18 PM
mjb240z
Dec 18, 2003 09:55 PM
