Transmission & Drivetrain Gearboxes, Differentials, Clutches
Ctr tranny problem
Old Dec 18, 2008 | 05:31 PM
FastLife617's Avatar
Default Ctr tranny problem
The reverse gear on my ctr tranny started popping out when i try to reverse all the other gears work fine no pop outs or grinds really smooth shifting. I checked my shift linkage and everything is perfectly fine i even put in reverse manually with the car raised to see if that will work and it still pops right out. But i am able to reverse if I keep my hand on the shifter keeping it from popping out and balancing the clutch but even during that if i release the clutch fully it will pop out
any ideas on what it can be?
Old Dec 18, 2008 | 06:35 PM
Aquafina's Avatar
Synchro/synchro spring.
Don't hold it in gear.
Old Dec 18, 2008 | 06:44 PM
Synchro in reverse gear ? ? ?
Old Dec 18, 2008 | 07:10 PM
Mista Bone's Avatar
D Tranny Guru
yep, it is mount next to 5th gear.
Old Dec 19, 2008 | 04:41 AM
Alright thanks guys . . . i am completely clueless when it comes up to tranny's most i did is change the clutch and flywheel is there anything else it could be?? im opening it up this following monday
Old Dec 19, 2008 | 03:54 PM
bump
Old Dec 19, 2008 | 06:43 PM
bump..
Old Dec 20, 2008 | 08:31 AM
bumpppppppp
Old Dec 20, 2008 | 02:56 PM
Aquafina's Avatar
Questions been answered.
No need to bump, this is a slow forum.
Old Dec 20, 2008 | 09:05 PM
Mista Bone's Avatar
D Tranny Guru
Thought I was on D-series.org for a minute!!!!!!
Old Dec 20, 2008 | 09:39 PM
Aquafina's Avatar
You are...
Old Dec 20, 2008 | 09:57 PM
B18C7ITR's Avatar
I know the synchro for reverse is next to 5th gear, but how does it work? I mean, isn't the reverse gear part of the 1/2 slider?
Old Dec 20, 2008 | 10:44 PM
Aquafina's Avatar
1/2 slider, mainshaft, and reverse idler gear. What is the R synchro on? The mainshaft... Get it? Synchro doesn't have to be sitting on the gear for it to slow the gear down.
Old Dec 21, 2008 | 05:26 PM
Default Re: Ctr tranny problem
Thnx fellas the tear down is going down tommorow so at least now i know what to look for
Old Dec 21, 2008 | 07:04 PM
Now another question my buddy just told me that he has a very clean 00 b16 tranny and im welcomed to use any part of it i need now my question is the Synchro/synchro spring. interchangble with the CTR one ? if not would be the a GSR one? because i highly doubt i can get my hands on CTR tranny or ITR parts well at least in the time frame i gotta get this done...
Old Dec 22, 2008 | 06:48 AM
Aquafina's Avatar
Both are interchangable.
Old Dec 22, 2008 | 07:38 PM
Mista Bone's Avatar
D Tranny Guru
B16 vs. GSR/ITR, the 3-4 slider and hub are mounted different.
Also GSR/ITR use a double synchro second, never tried to interchange that.
I don't swap parts like that on B's, I fix what is broken, maybe why I don't work on as many.....which IMHO is a good thing!
Old Dec 22, 2008 | 07:54 PM
Aquafina's Avatar
B16 is dual cone 2nd as well.
I'll test fit a ITR 1/2 hub on a GSR shaft. Don't see why it would be any different.
I don't see why you dislike working on B's, I love working on them. A lot of interchangability that I've found playing around with them.
jdmej814
Jul 26, 2009 05:05 AM
FastLife617
Dec 18, 2008 05:01 PM
AzntstyleZ
Jun 27, 2005 08:21 AM
chris408
Apr 22, 2004 03:51 PM
TurboIntegra
Sep 8, 2001 09:48 AM
