Transmission & Drivetrain Gearboxes, Differentials, Clutches
shift linkage
Old Nov 12, 2008 | 08:21 AM
craz4speed's Avatar
Default shift linkage
okay i own a 96 civic hatch with a b16a2 from a 99 si and i have a question.
my shift link bar on the back side of my tranz fell off and was on the ground. i looked at it and it looked like it was only missing a bolt... its just a rod with round pease at the end that you put the bolt through right? i ask crown honda to order this bolt and they gave me one that was 8/45 witch was not the right one im guessing!!!!!!!!! because i tryed to put it in and it put a hole in my tranz casing someone please help. i need to know if this is right so i can take them to court. i am open to everything at this point throw em my way
thanks
Old Nov 12, 2008 | 10:19 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: shift linkage (craz4speed)
1. Learn to use correct punctuation and spelling.
2. You can't take them to court for ordering the wrong part, especially when you have no idea what you are talking about.
3. You need a spring pin...aka, "bitch pin" as some refer to it.
Old Nov 13, 2008 | 06:49 AM
craz4speed's Avatar
Default Re: shift linkage (Evs-One)
Okay that's no help at all. Someone else please
ps. Sorry i was in a hurry mabe you should teach english.
Old Nov 13, 2008 | 07:41 AM
Evs-One's Avatar
Solbros Owns Me
You don't need a bolt....you need a spring pin for the linkage. What else do you want me to do? Fly over there and install it for you?
Old Nov 13, 2008 | 07:56 AM
craz4speed's Avatar
Okay man your talking about the rod that actualy moves the gears.i'm talking about the other rod that has the round end. now maybe you can help me now that you k now what im talking about. also no need to be an *** just because i dont know much about this ****.
Old Nov 13, 2008 | 08:07 AM
Evs-One's Avatar
Solbros Owns Me
http://www.hondaautomotiveparts.com
Modified by Evs-One at 10:28 AM 11/13/2008
Old Nov 13, 2008 | 09:11 AM
craz4speed's Avatar
Guessing it's not called the Shift linkage...
i'm lost
Old Nov 13, 2008 | 09:30 AM
Evs-One's Avatar
Solbros Owns Me
The B series uses a 8x18 bolt. Your stock D series uses a 8x45 bolt. #27 is what you need, #28 is what you got.
Old Nov 13, 2008 | 10:06 AM
craz4speed's Avatar
Okay thank you, now dose #15 go on the end of #13? If so i don't see how.
Old Nov 13, 2008 | 10:29 AM
Mista Bone's Avatar
D Tranny Guru
bolt number 27
Old Nov 13, 2008 | 10:42 AM
craz4speed's Avatar
Default Re: (Mista Bone)
Okay from what EVS said the B series uses a 8x18 bolt. Your stock D series uses a 8x45 bolt. all i know is i need to get #13 back on the tranz and i dont see any room for #15. I'm not sure what to do here it looks like you just push it on to the tranz and then put bolt # 27.
Old Nov 17, 2008 | 11:30 PM
bryse68's Avatar
there is no 15 on the trans. b-series has a cylinder that sticks out near the clutch cover plate, and the linkage slips over that cylinder. that pix doesn't show the trans, if you look at the attachment, its between #3 and the axle seal
william bonnie
Dec 19, 2017 10:51 AM
Dice21
Oct 2, 2005 02:11 PM
HondaRexBoi
17
Sep 6, 2005 09:36 PM
976
May 16, 2003 02:46 PM
allmotorls95
Sep 10, 2002 09:00 AM
