Transmission & Drivetrain Gearboxes, Differentials, Clutches
Can't shift on a cold start!
Old Dec 10, 2008 | 06:06 PM
HanSoo417's Avatar
Default Can't shift on a cold start!
I have a 95 civic coupe with a JDM D15B vtec engine. I'm not sure what kinda tranny or fluid is in there. I just bought the car a few weeks ago. It was shifting fine when I got it but it starting acting up once it got cold.
So here's the problem:
When I start the car, there's not much pressure when i depress the clutch. Sometimes it gets stuck and won't even spring back up. Obviously I can't get into any gears. After a long warm up and pumping the clutch pedal a bunch, it works fine. If I turn the car off, I can put it in gear and then start the car and go.
What's going on?
Old Dec 10, 2008 | 10:09 PM
Evs-One's Avatar
Solbros Owns Me
Clutch hydros.
Look under dash at the clutch master cylinder and see if fluid is leaking.
Pry the dust boot back a tad on the clutch slave cylinder and see if fluid is leaking.
I would replace both...you have hardly any disengagement.
Old Dec 11, 2008 | 06:21 PM
HanSoo417's Avatar
How much do those parts cost and if I had a mechanic do it for me, how much should I expect to pay?
Old Dec 11, 2008 | 06:40 PM
Evs-One's Avatar
Solbros Owns Me
Japanese specialty shop would charge from 2-4 hours labor @ 60-100/hour. So, from 120-400 labor. And parts depend on what they use. Nissin(OEM Honda) units can be cheap, when purchased under the brand "Adler". Parts should be under 100 for both
redacura
Mar 3, 2013 04:30 AM
triple
Nov 16, 2010 11:08 AM
deeweezy187
Feb 26, 2008 01:20 PM
IamPhil
Jan 24, 2007 07:08 AM
