Transmission & Drivetrain Gearboxes, Differentials, Clutches
DA jdm B16 trans problem. help needed
Old Nov 30, 2008 | 11:42 AM
90SiReX's Avatar
Default DA jdm B16 trans problem. help needed
ok i have a b20vtec with exdey stage 1 clutch stock flywheel. i had my stock 91 LS trans on the car worked fine no problems i just chaged over to my S1 b16 trans and the problem im having is when i press the clutch all gear go in smooth perfectly fine. i put the trans into first gear i let off the clutch to roll and i have a rough grinding noise.. idk.. wtf it is if i let the clutch all the way out IN GEAR the car WILL NOT stall it stays on the throw out bearing is good the axel is installed correctly i dont no what it is? maybe need a different clutch? please give me some input.
Old Dec 1, 2008 | 11:19 AM
90SiReX's Avatar
bump..anybody?
Old Dec 2, 2008 | 01:19 PM
dcvt16's Avatar
are you using the right clutch disc for the trans your using? there are 2 different clutch discs for cable tranny's.
d16efsedan
Apr 9, 2013 12:02 PM
alscrx
Nov 3, 2008 04:27 PM
crizx
May 19, 2006 09:51 AM
BrokenRex
Oct 22, 2005 03:23 PM
DA6Iceman
Sep 13, 2005 06:48 PM
