Transmission & Drivetrain Gearboxes, Differentials, Clutches
2nd gear problems
Old Oct 23, 2008 | 10:11 PM
helixform's Avatar
New User
Default 2nd gear problems
Hi, I recently finished a B16 swap on my 91 CRX. I am having a problem with second gear. When making sharp right turns I can not shift into second, or if I am in second when making the turn it will pop out of gear. Any ideas on what could be the problem, and possible solutions?
Old Oct 26, 2008 | 10:21 AM
megatoninduk's Avatar
Default Re: 2nd gear problems (helixform)
stock shifter? has the tranny been apart recently?
Old Oct 30, 2008 | 05:32 PM
slowcivic2k's Avatar
Make sure your shifter has no interference first off.
I've seen this a many a few times and the culprit ends up being the snap ring bearing on the counter shaft. Excess play in the bearing allows the shaft to move, and pull you out of gear/prevent you from going in.
John 07
Mar 26, 2009 01:46 PM
92civiceg9gsr
Feb 6, 2009 08:53 PM
crxmex
Nov 4, 2007 01:33 AM
Bond
Jan 31, 2005 07:14 PM
Jeager521
Aug 11, 2003 09:25 AM
