Problem with my tranny case
well i just pick up a D16Y8 motor/tranny. So when i remove the tranny from the motor i notice that there was a piece of the case broking off from the bottom. Now is there any way i can fix this or can i use the tranny case of a HX tranny??
As long as there isn't a crack running up the case you should be fine to use it. If you bottom out on it though, it will crack open a lot more easily.
If you want to use a different bellhousing, you'll have to shim the diff and mainshaft.
OG SHG_EM1
25
May 4, 2005 12:41 PM
