Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need Help With Clutch issues
Old May 23, 2012 | 06:54 PM
ryan_'s Avatar
Icon3 Need Help With Clutch issues
so all day today the clutch was perfect to slips no nothing. no issues. i get out of work start my car then go to put it in first the clutch is all loose to almost the floor, barely have to push it. then right before the floor(1-2inches) it gets hard. then its super difficult to put into first gear and when i finally get it in, it continues with all the other gears all the way home. i dont know much about transmissions. or what this could possibly be, so any help would be greatly appreciated..
thanks in advance
97 civic, 4 door lx if that helps
Old May 23, 2012 | 07:51 PM
B and B's Avatar
Loved
Community Favorite
Default Re: Need Help With Clutch issues
Prolly the slave cylinder on the tranny bellhousing area..or the master cylinder on the firewall where the fluid goes...speaking of fluid, is there any in the clutch reservoir?
Old May 23, 2012 | 08:45 PM
ryan_'s Avatar
tbh its dark as hell out right now and ill check the reservoir in the early AM. im not 100% familiar with all the bells and whistles of the transmissions and clutches things.
i should start with the reservoir first, and make sure there is fluid?
Old May 27, 2012 | 11:46 PM
truckboy's Avatar
I think this is just because of oil contamination, poor friction point. so kindly check the same.
jdmstyleg
11
Sep 27, 2009 06:16 PM
LudeCris
May 21, 2006 09:47 AM
es_squared
Sep 21, 2004 08:10 PM
Aceman64
Dec 18, 2001 07:23 AM
