what affects clutch pedal travel?
what affects how high your clutch pedel is and how far it travels? asuming its properly bleed and has full fluid lvl.
is it the pressure plate or what cause iv been in some ppls cars and there clutch pedal sits lower and travels way less than mine does.
Re: what affects clutch pedal travel?
some different clutches will have a different engagement point.
but typically the adjustment rod on the back of the pedal and the stopper on the pedal bracket. a lot of ricers set it so that the engagement point is 2mm off the floor.. why? idk. pain in the *** if you ask me.
ya im kinda afraid to mess with the adjustment rod because iv herd so many stories of the clutch never fully disengaging and roasting clutch plates that way.
