Transmission & Drivetrain Gearboxes, Differentials, Clutches
mtf
Old Jul 14, 2012 | 01:30 PM
91grape's Avatar
Default mtf
are there any substitutes for honda mtf? everywhere ive been theyve been sld out, and its lookin like its gonna be gear oil before its over with...
Old Jul 15, 2012 | 01:45 AM
david974's Avatar
Default Re: mtf
you can use
torco mtf or rtf
amsoil mtf
Old Jul 15, 2012 | 08:04 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: mtf
10w30 motor oil.
DO NOT use synthetic motor oil
DO NOT use gear oil
Old Jul 16, 2012 | 09:56 AM
lassek20's Avatar
Default Re: mtf
GM synchroshift synthetic . helps hondas with worn synchros shift much better
Old Jul 16, 2012 | 11:39 AM
EddieCRX's Avatar
Default Re: mtf
Just used Torco RTF in place of Honda MTF-3, was suggested by many people.
Old Jul 16, 2012 | 05:18 PM
Ryan96GSR's Avatar
Default Re: mtf
I'm using Amsoil MTF for my trans swap
Old Jul 16, 2012 | 05:57 PM
MonkeyMagic's Avatar
Default Re: mtf
Originally Posted by spAdam
10w30 motor oil.
DO NOT use gear oil
Originally Posted by david974
you can use
torco mtf or rtf
amsoil mtf
this.
pennzoil synchromesh works very well too, and even better it's available at any autozone, napa, etc.
DO NOT use gear oil
Old Jul 18, 2012 | 03:20 PM
91grape's Avatar
Default Re: mtf
well, i almost used gear oil. glad i got back on before i did anything. so 10w-30 regular motor oil is good to use then?
Old Jul 18, 2012 | 03:22 PM
91grape's Avatar
Default Re: mtf
also my transmisiion will not fill through where the speedo cable goes in at. am i filling it throught the right spot or??
Old Jul 19, 2012 | 04:07 AM
MR.johnson's Avatar
Default Re: mtf
torco RTF for high horsepower, its very expensive for a stock application.
Old Jul 19, 2012 | 05:20 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: mtf
Yes. Unless we're talking newer Hondas, that is what your owners manual recommends. I'm guessing from your next post that its an EF?
There is a plug on the passenger side, above the drain plug and toward the rear slightly.
Old Jul 19, 2012 | 06:41 AM
Default Re: mtf
no, you're essentially filling the vss with oil. remove the cable, then the vss (which is potentially a bad idea since it's likely siezed to the trans case), then fill.
this is how it's supposed to go.
but be aware, if the car is not level (ie, jacked up from the front) the trans will not hold anywhere near what it's capacity should be. otherwise, just fill till it starts to run back out the hole.
Old Jul 19, 2012 | 08:25 AM
lassek20's Avatar
Default Re: mtf
10w-30 is approved by honda as a "temporary fill"
Old Jul 19, 2012 | 01:37 PM
metaphor51's Avatar
be water, my friend
Default Re: mtf
You can't go wrong with Torco
Old Jul 20, 2012 | 11:43 AM
91grape's Avatar
Default Re: mtf
Thanks for ths feedback and I appreciate the help too. Im gonna finish it up today and post later to let talk know I didn't mess it up haha
Old Jul 22, 2012 | 01:38 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: mtf
10w30 as cheap as you can get it or synthetic if you wanna blow some bills.
A customer of mine claims 6+ seasons on his 92-93 Teg tranny after LSD/FD install using only Mobil 1 10w30.
Old Jul 22, 2012 | 10:19 AM
lassek20's Avatar
Default Re: mtf
mobil1 10w-30 if you like whining gears
Old Jul 22, 2012 | 09:19 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: mtf
You are misinformed.
He has several national championships to prove it.
Old Jul 22, 2012 | 09:21 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: mtf
Approved as NORMAL fill for 88-95 trannys. Once Honda made the switch to metal caged bearings their MTF was ok to use. Sadly you can no longer get the original Honda MTF, the latest fluid is pisswater thin.
Old Jul 23, 2012 | 02:53 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: mtf
I'm glad you said that. I thought it seemed different. When did they change it?
Old Jul 23, 2012 | 04:53 AM
lassek20's Avatar
Default Re: mtf
i didnt say it wasnt possible. just speaking from experience..
Old Jul 31, 2012 | 11:48 AM
extralargenog's Avatar
Default Re: mtf
You should post less and be quiet when grown folks talkin
83rolla
Dec 28, 2011 07:46 PM
enoker001
Jun 25, 2009 11:09 PM
phyzJunkieCivic
Jul 31, 2006 04:15 PM
ApolloSpeed
38
Mar 13, 2006 11:22 AM
wizzards581
12
Mar 6, 2003 11:15 AM
