Transmission & Drivetrain Gearboxes, Differentials, Clutches
MFactory LSD Install Question
Old Aug 30, 2012 | 02:27 PM
kellerscobra's Avatar
Default MFactory LSD Install Question
I'm in process of re-assembling a S80 transmission with a MFactory Metal Plate LSD. To the best of my knowledge, I have the bearings and ring gear installed properly; however, first gear is touching the ring gear bolts. I attached a few photos to try to show the space between the ring gear and the case, first gear touching the ring gear bolts and the assembled LSD unit.
This is my first time in a FWD transmission, so any guidance will be appreciated.
Old Aug 30, 2012 | 02:48 PM
David @ Synchrotech's Avatar
Default Re: MFactory LSD Install Question
The 1st gear will lift up when the shaft is in position with the top bearing clip locked but we have still had to grind the bolt heads down on some of the plate LSDs to get the clearance right.
Old Aug 30, 2012 | 04:05 PM
Aquafina's Avatar
Clip the countershaft in place in the case (leave mainshaft and forks out) and tighten the case down with a couple of bolts. Use clay to check the clearance between 1st and RG bolts. Best way to check without a window case (should still use clay to double check).
Old Aug 30, 2012 | 05:43 PM
Synchrotech\Aquafina:
Thank you for the tips. Once the countershaft was clipped in, first gear cleared the ring gear bolts.
Old Aug 30, 2012 | 07:41 PM
Aquafina's Avatar
No problem. Are you going to have this out at VIR in October by any chance?
Old Aug 31, 2012 | 03:18 AM
No. My last track day event will be with TrackDaze at the Shenandoah Circuit at Summit Point. This transmission and a B18C will be going into the CRX over winter, and I hope to make it to VIR next year.
Old Aug 31, 2012 | 06:04 AM
Aquafina's Avatar
Cool. Maybe I'll see you out there next year.
Old Jul 21, 2018 | 04:50 AM
Mark Burt's Avatar
Hi i have the same problem it seems if i clip the bearing in and put together casing it all clears but when driven it does not !
So i have ground 2mm off the gears and put back together and stiil grinds can someone please HELP
Old Jul 28, 2018 | 10:02 PM
Aquafina's Avatar
Sounds like your top countershaft has play and needs to be replaced.
Old Aug 2, 2018 | 02:11 PM
crx121ci's Avatar
nice tip
mach3lude
Aug 29, 2011 07:18 AM
InfamousDC2FI
May 13, 2006 07:59 PM
White_EK49
Oct 10, 2005 07:08 AM
PupaScoopa
Apr 8, 2003 10:01 AM
