Transmission & Drivetrain Gearboxes, Differentials, Clutches
EP3 Clutch pedal stays stuck
Old 09-06-2012, 04:35 PM
favd21's Avatar
Default EP3 Clutch pedal stays stuck
Help!!! I have an 02 ep3 stock except for some aftermarket clutch. I press the clutch pedal put it in first gear and the when i release the clutch a tiny bit the car starts moving but the pedal doesnt release i have to pull it back up with my feet. After the car is running sometimes i gotta help it in second gear because the pedal doesnt pop back up. When im at a full stop and i put the car in reverse the car after 3 seconds moves with the clutch fully engaged i dont even have to release it, it just moves back by itself and usually stalls on me. Can someone please help me have an idea of where the problem is.
Old 09-06-2012, 04:44 PM
jdmh22eg2's Avatar
Default Re: EP3 Clutch pedal stays stuck
Clutch master/ clutch slave
Old 09-06-2012, 09:58 PM
a.k.a. Komodo
Kozy.'s Avatar
I've just had (well, still have) this issue with my EDM Accord Type R. What I can tell you, after expending a LOT of money, is that your clutch is absolutely fine. Just spent a couple hundred pounds replacing mine with a brand new Honda unit and the problem is still there!
Garage who did the work said it was most likely the master cylinder, but I'm going to replace both.
Old 09-07-2012, 05:45 PM
favd21's Avatar
Yea im definitely sur ethe clutch is fine cuz it grabs strong n the shifts are smooth its just like a spongy feeling to the clutch and looses pressure problem is i see no leaks or nothing so im wondering if its air
Old 09-07-2012, 05:46 PM
favd21's Avatar
yup most likely cuz everyone tells me the same thing bro.. I just bought an omni power master cylinder i hope this works
Old 09-08-2012, 01:21 PM
a.k.a. Komodo
Kozy.'s Avatar
Same here, no visible leaks but there's definitely something losing pressure. I think it could be the internal seals on the MC, probably bleeding fluid back up into the resevoir.
Old 09-08-2012, 03:00 PM
97accordbuildlx's Avatar
start fixing the small things first then deal with the clutch the very very last after youve knocked all the small **** out first. nothing worse than spending a bunch of money to find out it was only the master or slave cylinders, which it 98% is. the clutch system isnt that elaborate it basically consists of the pedal, master cylinder, clutch line, slave cylinder and from their engages your clutch.
SlammedEH3
12-12-2007 05:50 AM
ac_attak
06-07-2006 11:12 AM
iwreakhavoc
06-03-2005 10:47 AM
92BlackSi
10-26-2004 03:51 PM
gsr camel
09-13-2001 12:05 PM
Quick Reply: EP3 Clutch pedal stays stuck
