Transmission & Drivetrain Gearboxes, Differentials, Clutches
obd code P0717 and shifting isues
Old Sep 3, 2012 | 03:07 PM
george taylor's Avatar
Icon2 obd code P0717 and shifting isues
Ok I know there is a tread that discusses the P0717 code bt not sure if my 2 problems are related. I have changed the Pickup Assy/sensor that would gie the code and thught that tha would solve he problem. Nope. When my wife was driving the ar home, the "D" indicator stared to flash. I have checked the fluid level and it does seem to be a little low. The trans wasreplaced a few yers back after a accidednt she had (long story) and was told it had 30k less than the car. the car has 99k on it now. Any clue as to where I should start, I hope I do not have to have the trans rebuilt.
Old Sep 3, 2012 | 07:27 PM
slowcivic2k's Avatar
Default Re: obd code P0717 and shifting isues
A P0717 will result from an electrical failure of that sensor circuit. Meaning you have either a bad sensor (do a resistance check), or open wires going to and from the sensor to the PCM. If those check out with a multimeter, the PCM will require replacement. Are you sure you replaced the right sensor?
Need to know what car you drive to help you more.
Old Sep 4, 2012 | 01:10 PM
As for replacing the correct sensor ??????. I was going to test the old one, but I broke it trying to get it out. The one I changed was the one that is closest to the engine, firewall side. I checked the wires that were pluged into the sensor and got 4. something volts I think from the 2 outer pins, but nothing frm the center, again ?????.
Old Sep 5, 2012 | 07:55 AM
Gearspeed-Performance's Avatar
Feel free to call us and talk to our specialist, we can square you away.
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
boltnut
Jan 7, 2006 08:43 PM
Mastuh4
Nov 3, 2004 09:49 AM
BAZ
Apr 26, 2004 01:45 PM
