Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
Old 07-10-2017, 01:07 PM
ksr111851's Avatar
Default Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
I have a 2006 RSX Type S. If the car idles for more than 10 minutes, the battery light comes on. If I turn the car off...it will not start unless given a charge. New alternator was installed to fix the issue. This did NOT solve the problem. The battery is new. What the factors could be causing the drain on the battery in idle.
Old 07-10-2017, 01:26 PM
DCFIVER's Avatar
Default re: Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
Alternator, ELD, fuse or its associated wiring. If you are certain the alternator is good(its a reman unless you bought from Honda)the fuses are good, then it could be the ELD. Youll need some tools to do some checking.
Old 07-18-2017, 03:51 PM
thewrai6th's Avatar
Default Re: Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
What is ELD? Google is not cooperating.
OP, does it drain after you charge it while off. Or, does it only drain while running?
Do you have any aftermarket stuff, like a 2000 watt Rockford amp or anything like that? Dash cam?
Old 07-20-2017, 08:09 AM
DCFIVER's Avatar
Google Honda ELD. Its been used for decades.
Basically its the go between for the alternator and PCM. The PCM uses the ELD input to determine how much alternator out put is necessary.
The ELD gets its info from monitoring battery current.
SpoonEk253
01-05-2022 09:23 PM
lmike6453
01-16-2009 06:55 PM
jauldredge
07-22-2008 06:40 AM
EG6[B16A1]
06-28-2003 09:03 AM
pstutz
04-26-2003 12:05 PM
Quick Reply: Diagnosis needed: Power drain while in idle: Alternator, Battery, or ELD?
