Ep3 chassis dc5 subframe?
Old 04-22-2018, 06:23 AM
honda_12V's Avatar
Default Ep3 chassis dc5 subframe?
Hey everyone.
I have a ep3 with the d15 engine.
Looking to go k swap. Can I use a dc5 subframe will it fit??
Regards
Old 04-22-2018, 08:47 PM
JRCivic1's Avatar
Default Re: Ep3 chassis dc5 subframe?
Yes, the subframe bolts right up. You will need the lower A-arms as well.
Old 04-23-2018, 04:47 PM
Sanji
toyomatt84's Avatar
The LCA's are the same, though. You don't necessarily need them.
Old 04-24-2018, 10:11 PM
JRCivic1's Avatar
If you are referring to the USDM EP3, I completely agree with you. However, the OP states that he has a D15 engine in the said EP3 (this combination is not found in the US market), so I would assume that this means that the subframe/cradle and lower A-arms are more like those that are found on a USDM D17 SOHC Civic Coupe or Sedan. These part numbers differ from the RSX (DC5) lower control (A-arms)... are they still interchangeable ??? What is different about them ???
Old 04-25-2018, 07:20 PM
Sanji
toyomatt84's Avatar
The only real difference between them is the knuckle that attaches to them. The IT-R LCA's are different, due to being aluminum and having a slightly different ball joint seat, but that's not a US-based item either.
k20a_joe
08-11-2015 07:35 AM
RED_90TEG
12-10-2009 11:41 AM
CR91X
26
07-21-2007 12:46 PM
PIntegraMP
04-09-2006 02:25 PM
yagotrice
05-11-2005 06:53 AM
Quick Reply: Ep3 chassis dc5 subframe?
