C27A Pistons on a K24?
Re: C27A Pistons on a K24?
If the following are the same dimensions... then in theory, they should work:
Bore size
Wrist pin diameter
Rod small end width clearance
Compression or Install height
Valve relief diameter, plunge depth and center index
I would say it is unlikely that all of this is the same... but you never know with Honda.
Good luck.
Bore size
Wrist pin diameter
Good luck.
