Euro r k20 swap
Old 07-06-2019, 11:28 AM
Default Euro r k20 swap
Hi.
I'am trying to swap a k20 engine that comes from a honda euro r (cl7) in a 96-00 civic .. I have a problem with the engine mounts. I have an Eg subframe but I can not find a way to properly position the engine in the car. someone already tried to do this swap? What should I choose as engine support?
Thanks
Civic 974 is offline
Old 07-06-2019, 04:03 PM
Ryanthegreat1's Avatar
Default Re: Euro r k20 swap
Hasport and Innovative both make K series mounts for an EG. Or you could fabricate your own.
Ryanthegreat1 is offline
Old 07-06-2019, 09:45 PM
Sure I saw it. I tried the ekk2 and ekk4 from hasport but they both doesn't work.
Old 07-06-2019, 10:32 PM
Which part doesn't work ???
JRCivic1 is offline
Old 07-06-2019, 11:22 PM
I tried ekk2 with ek subframe and ekk4 with eg subframe.
Ekk2 with ek subframe put the engine Realy close to the engine bay and I can't put any radiator.
Ekk4 with eg subframe I can instal. Transmission and rear mount are ok but I cant fix the last mount
Old 07-07-2019, 08:42 PM
It sounds like the engine bracket is wrong... can you post a pic of the engine bracket mounted to the outside of the timing cover please ???
JRCivic1 is offline
Old 07-08-2019, 09:48 AM
I have the k-tuned k20 bracket mount on the engine.
On the pictures this is the EKK4 kit.
Old 07-09-2019, 07:21 PM
scottcraft's Avatar
Shouldn't you use the ekk2 mounts with the eg subframe?
scottcraft is offline
  • Ask a Question
Question Title:
Description:
