New to the forum. Map issue. 2.4. 4 cylinder 2003
Old 06-24-2019, 12:40 PM
Micko699's Avatar
Default New to the forum. Map issue. 2.4. 4 cylinder 2003
Im having a MAP issue. The car is running off
, missfire and no power. The reading is stating:
Bad MAP sensor
Running rich.
I replaced the MAP sensor. I just changed the plugs and valve cover gasket. But still running bad. Any ideas?
Old 06-26-2019, 04:48 AM
Loves Tossing Salad
09chaplak's Avatar
Default Re: New to the forum. Map issue. 2.4. 4 cylinder 2003
Compression test it.
Old 06-27-2019, 09:09 AM
Dublocivic's Avatar
Bad MAP sensor
Running rich.
What chassis/engine/ECU/harness etc..?
Make sure your IACV and MAP harness plugs are not reversed. Check MAP voltage and compare it to the service manual's voltage requirement.
Old 06-27-2019, 10:06 AM
Micko699's Avatar
Thank you all for your response. I found the issue. It was the catalytic converter. I had one installed today. Runs great.
