k20a2 rebuilt
Old May 7, 2019 | 02:35 AM
scre's Avatar
Default k20a2 rebuilt
Okay guys,i started fully rebuild my engine and need advice for more questions.
In future i want take turbo.Engine is stock, only will use acl race main and rod bearings,other parts are OEM.I not want make big numbers may be 350-400whp.Now when search most people building engines with more clearance for bearings.I chek my main bearings with ACL STD and my numbers is of loose side of oem specs.Standart or new is (0.017-0.041) service limit is 0.050.My plastigage measure 0.045,will check rod bearings soon when arrive new rod bolts.
What clearance is good for turbo setups and what oil grade is used ?
Old May 7, 2019 | 09:36 AM
1HGEJ2's Avatar
Default Re: k20a2 rebuilt
0.045 is perfect. 5w50 for turbo is good too
Old May 7, 2019 | 11:25 PM
scre's Avatar
Thanks for replay pal.What number to target for rod bearings.Standart is (0.033-0.061) and service limit 0.071 may be somewhere 0.050?
Old May 8, 2019 | 09:22 AM
1HGEJ2's Avatar
0.050 is perfect too. i have this on my k20 turbo hx bearing size ( extra clearence). 0.033 is ****
Old Jul 14, 2019 | 06:23 AM
BoostHatchFreak's Avatar
on any engine .0035 -.004" is the normal for mains and .0025" to .003" for rods. so I hope what you said earlier is missing a zero
Old Jul 14, 2019 | 11:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
In a Honda, those dimensions would make very low oil pressure and you would have rod knock.
OP, are you posting values in "MM" or "Thousands of an inch" ???
Old Jul 15, 2019 | 06:12 AM
don't see where your getting that information from. honda stock is two thounds of a inch on the rods and three thousands of a inch on the mains. so loosing it up some for more "race" will not give it a "rod knock"
Old Jul 15, 2019 | 10:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Ummmm... the factory service manual.
Old Jul 16, 2019 | 01:16 PM
1HGEJ2's Avatar
im in mm 0.050mm is perfect.
Old Jul 16, 2019 | 09:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
For the connecting rods... I can agree with that.
Old Jul 22, 2019 | 01:47 AM
scre's Avatar
Hi,all I Mesured conrods and my numbers are between 0.045-0,048 . What think,maybe is little thick but is good ?
purposebuilt
Jun 25, 2019 08:20 PM
aavtec
10
May 17, 2013 10:07 PM
ELPITUDO
Jul 16, 2007 03:42 PM
Teg15
Sep 1, 2002 01:12 PM
Brian_92GSR
Apr 2, 2002 01:53 PM
