K20A Block Compression
Old May 28, 2019 | 04:05 PM
Handel Spencer's Avatar
Default K20A Block Compression
If I change the compression on my K20A base block to 12.5.1, would be as powerful as the K20A Type R block which has 11.5.1 compression?
Old Jun 5, 2019 | 07:40 AM
svmpower's Avatar
Default Re: K20A Block Compression
What do you mean by k20a base block? LIke k20a3?
Do you have a vtec head?
Rule of thumb, when you jump 1 whole compression point, that should be around 10HP increase if everything is done right.
Old Jun 5, 2019 | 02:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
No, a K20A3 doesn't have enough camshaft for 12.5:1 compression. You will pick up some power over a stock K20A3, but you need more aggressive cams to go with the increased compression to really make power. You will need a way to tune the engine... like KPro or something similar. The good news is that if you build it right, you CAN make a K20A3 base engine make more power than a JDM K20A Type R engine.
JDM_ego2033
Jun 25, 2019 05:30 PM
dumbkid
Aug 17, 2004 11:21 PM
Thrashin
Aug 10, 2004 02:41 PM
