Trans Snap Ring
Old May 24, 2019 | 02:34 PM
ksnRock's Avatar
Icon4 Trans Snap Ring
So I'm assembling my tsx transmission and we can't manage to spread the damn snap ring the seats the countershaft bearing into the outer casing! I'm sure that the culprit is marring from metal pieces getting into the area around the groove in which the snap ring seats in the casing, and likely the groove itself. However, I feel as though I can get away with using it still. Considering drilling holes for my snap ring pliers to pry the ring, as I've been using random tools. Can't find a proper tool anywhere. I'm so close to having a running car. Ideas?
Old May 25, 2019 | 09:15 AM
Ryanthegreat1's Avatar
Default Re: Trans Snap Ring
Take the ring out and debur and clean out that groove. That looks pretty rough in there and being a magnesium case it is going to be finicky.
Old May 28, 2019 | 09:36 AM
ksnRock's Avatar
Update. I believe my issue to be from the mainshaft ball bearing getting stuck in the casing in a crooked manner. I wasted enough time trying to remove it from the upper casing. Please look closely to determine which side of the bearing to tap for it to come out in a straight fashion. After closer inspection, I was able to give one side a tap with a piece of wood to get it out. Originally, I thought the bearing was stuck in the housing lol. It's all part of the learning process. Regarding removing the snap ring, I tried removing it, but didn't see it possible without scratching the magnesium even more or snipping the ring and waiting for a new one to arrive at my local dealer.
I'm picking up a new bearing tomorrow and, hoping it stays, will insert the bearing into the upper casing before trying to reassemble. I will also lather the snap ring in MTF to reduce the friction that I believe there to be.
Disclaimer: Yes, 2x4 elevating bellhousing. I haven't yet tried 'dropping' the transmission. Also, running the transmission to get the ring to seat sounds disastrous, I don't see how your casing could even mate without those 2mm of closure.
sirtef9
Transmission & Drivetrain
May 17, 2025 04:53 PM
martn53
11
Jan 6, 2010 10:20 PM
aWeimaraner
Mar 5, 2009 07:26 PM
MR_FIX_IT
Feb 29, 2008 04:38 PM
Aquafina
Mar 2, 2006 10:33 AM
