to stop all the confusion this is the parts list for swapping k20a2 into ek and what
so first thing u need
1.k20a2 full swap engine/tranny/ecu/shifterbox/cables/axles/wiring harness/charge harness
2.ekk2 mounts/k swap header/fuel setup
notenly need ekk2 mounts if using eg subframe
3.k swap conversion harness/rad relocate kit/kswap rad hoses/coolant temp adapter
4.clutch line/throttle cable&bracket/k tuned shifter plate/heater core hoses if keeping heat
5.k pro or immobilizer.note:k pro is the best option also alot more expensive
Re: to stop all the confusion this is the parts list for swapping k20a2 into ek and w
wtf kind of list is that? If you gonna say parts list for swapping k20a2 in ek, at least be more specific in what you are talking about. Cause your post is still confusing me. Example, you are saying k20a2 axle will fit my 32mm civic ek? please do a better write up, instead of posting junk.
